Ryzen 3000 Cinebench TEMPS - Page 3 - Overclock.net - An Overclocking Community
post #21 of 52 (permalink) Old 07-18-2019, 10:01 AM
Contagion's Avatar
Rep: 719 (Unique: 494)
3700x PBO enabled
3600Mhz C16 Hynix CJR sticks
CB15 - 2154
CB20 - 4865
Temps capped at about 70C with PBO on for these scores. Custom loop in signature. Temps capped around 65C with PBO off.
Sustained clocks PBO off was about 4050
Sustained clocks PBO on was about 4125
RYZEN 3700x - 2x 8GB Corsair RGB Hynix @ 3600 C16 - GTX 1080 Ti Aorus WB
Asrock Taichi X370 - Corsair AX850 - Phanteks Enthoo Pro M
EK Supremacy EVO - D5 Revo 140 - PE 360 - PE 240
Dell AW3418DW Ultrawide Monitor
Contagion is offline
post #22 of 52 (permalink) Old 07-18-2019, 10:33 AM
NewMaxx's Avatar
Rep: 5 (Unique: 5)
Nice, Contagion.
Using same type of memory - Hynix CJR at CL16/3600. 3700X PBO enabled I'm hitting 76C, 4075 all-core, Arctic Duo 34. Highest run I had was 4812.
NewMaxx is offline
post #23 of 52 (permalink) Old 07-18-2019, 09:00 PM
OCCT Stable OCD
schoolofmonkey's Avatar
Rep: 39 (Unique: 32)
Ok so my temps and runs have changed a bit, I added 3 120mm push fans to my H150i Pro, it dropped the temps a lot and raised my Cinebench scores.
3900x, no PBO or other overclocking settings only ram XMP.
Cinebench 15: 3191
Cinebench 20: 7271
Max temp during Realbench, Cinebench etc was 70c
Lowest idle temp 33c - 37c.
Name:	2019-07-18 23_50_23-Microsoft Edge.png
schoolofmonkey is offline
post #24 of 52 (permalink) Old 07-18-2019, 09:51 PM
Reikoji's Avatar
Rep: 46 (Unique: 21)
Quote: Originally Posted by SsXxX View Post
amazing single core score here! how did u get that? manual overclock or pbo?
Manual with Ryzen Master
Reikoji is offline
post #25 of 52 (permalink) Old 07-19-2019, 09:07 AM
Discovery's Avatar
Rep: 0
I lapped the wraith it was concave, and sanded the edges (Edges only) on the 3600X they where higher than the rest of the lid. I gained quit abit doing that.
Ambient temp is around 75F
3800X & Corsair H80iv2
Gigabyte x470 Gaming7 wifi-50 F42a 1003ABB bios
Evga 850 SuperNova
Gigabyte 2070 OC
32GB Balistic LT sport 3200
Discovery is offline
post #26 of 52 (permalink) Old 07-21-2019, 02:04 AM
Team Red Lobbyist
Gill..'s Avatar
Rep: 114 (Unique: 101)
3900X on X370 Asrock Killer SLI/ac
Thermaltake AIO 280MM
GSkill Trident Z (AMD SKU) 3600 [email protected] 3200 with [email protected] CL16 (WHEA issues!)
PBO on (Advanced) 10X Scalar and Motherboard limit
LCC's offset to 2
Idle temps can get below 30C (28 at best with AC on in the room) Idle package wattage = 25W
R20
After 1 run 48Cish
couple runs 50Cish
VRM after 1 run = 48C
VRM's while [email protected]% = 60ish
CPU while mining = 52ish if AC is on
Peak wattage = 125
Vcore around 1.35 but I saw it spike to 1.36...if you look at the individual cores..it can hit 1.5
One other thing to note (since it seems you guys have high temps)..my case is open..4 fans in the case (1 directly on VRM) all 140mm and 2 more on the AIO venting up out of the case
I cracked 7332 on R20 average 7250
Average 3175 on R15
Tryhard score = 7399 (turn off all monitoring software - change Process Priority to "realtime" *note you will not see it actually perform..be patient*) I added third pic...note max temp was 46 (I left HW Monitor running this time)...and also note all the boost clocks. BLAM!
All cores will stay at 4124 MHz as long as it's below 48C...above that it dips to 4099 I peak boost clocks well in excess 4500 on 6 of the cores (some 4650ish sometimes)
One interesting thing I found - turn off RGB Service in the background (Lighting). It raised Cinebench and Geekbench quite a bit - was stealing around 3% CPU usage (on a 24 thread chip mind you..ridiculous)
I did my build in the kitchen (no carpets in sight) and in underwear to avoid any possible static. My roomates where kinda creeped out. headscratch.gif
he reads Pentiumhouse magazine and gets so turned on by it, he will never use another processor.
Gill.. is offline
post #27 of 52 (permalink) Old 07-21-2019, 10:59 PM
OCCT Stable OCD
Now I've had to go back and re-evaluate my voltages.
I had been getting BSOD on idle with my offset of -0.1000v, which clearly was too low for the idle clocks.
So I've had to up the voltage to -0.00625v, (won't let me use -0.00001v), that;s stopped the idle BSOD, and well brought up the benchmark scores as well as the temps.
So;
Cinebench temp: 77c
x264 Encode temp: 80c
ADIA64/Prime95: As above.
Cooler H150o Pro push/pull
Scores:
post #28 of 52 (permalink) Old 07-22-2019, 06:43 AM
glnn_23's Avatar
Rep: 13 (Unique: 9)
Here's my temps on this CB15 run.
Custom water 3 x 360 rads.
glnn_23 is offline
post #29 of 52 (permalink) Old 07-24-2019, 01:33 PM
zyxwvu4321's Avatar
Rep: 0
CPU: 3700x, all stock except for -0.05v offset
Motherboard/BIOS: ASRock X470 Taichi BIOS 3.43 (AGESA 1.0.0.1)
Cooler: Corsair H100i w/Noctua A12x25s
Cinebench R20 Multicore: 4914
Temp: 71.1c
I feel like that's a bit hot. No reviews got that high unless they were using the included cooler. Although there were almost none run on X470 boards either, so maybe the chipset/BIOS is messing with the heat.
zyxwvu4321 is offline
post #30 of 52 (permalink) Old 07-25-2019, 09:58 AM
killeraxemannic's Avatar
Rep: 224 (Unique: 198)
CPU: 3900X
Cooler: Scythe Fuma 2
temps Idle: 40-50C
Temps Cinebench: 81C
Score:R15 3089 R20 7088
PBO ON
Name:	2019-07-25 10_56_29-Window.png
AMD R9 3900x
Gigabyte X570 Arous Elite
MSI Gaming X GTX 1080
Gskill Ripjaws V 3600
Samsung 970 Evo Plus 1TB
Seasonic Prime 650w
Corsair H110i W/Phanteks F140MP Fans
Fractal Design Define R5
Dell SD2716DG 27" 144hz
Keyboard
Corsair K70 Rapidfire Mk2
Mouse
Glorious Model O
Mousepad
Logitech G640
Audio
Audio Technica ATH-AD900X
killeraxemannic is offline
