Ryzen 3000 Cinebench TEMPS - Page 4 - Overclock.net - An Overclocking Community
post #31 of 84 (permalink) Old 07-25-2019, 10:46 AM
zyxwvu4321's Avatar
Rep: 0
Update with new BIOS 3.5 (AGESA 1.0.0.3) that was released last night:
Everything stock: Cinebench R20 = 4964, Temp = 73.9c
-0.05v Offset: Cinebench R20 = 4886, Temp = 68.8c
zyxwvu4321 is offline
post #32 of 84 (permalink) Old 07-25-2019, 12:01 PM
Science
BLKKROW's Avatar
Rep: 260 (Unique: 181)
CPU: 3900X
Cooler: Noctua NH15s (Only using one Fan)
Temps Idle: 41*C
Temps Cinebench R15: 76*C
Score: 3132
www.blackaero.com
Desktop
(12 items)
AMD 3900x
Aorus X570 Pro Wifi
Gigabyte 1660 Ti
G.Skill 3600mhz DDR4, 16GB
HP 920 NVME 1TB
Corsair AX850
Corsair Carbide 400C
Operating System
Windows 10
Dell S2417DG
Keyboard
Ducky OCN Custom Mechanical
Mouse
Steel Series Kinzu V2
Audio
Fiio DAC Amplifier
BLKKROW is offline
post #33 of 84 (permalink) Old 07-25-2019, 06:16 PM
Rep: 1 (Unique: 1)
3900x
X570 xtreme
4.475/4.425/4.3/4.3 at 1.35volt max temp 85c with Noctua 12x25 aircooling. Score 7811cb Cinebench R20
4.45/4.45/4.3/4.3 at 1.375 I was hitting 91/92c x_x! im guessing i shouldnt go that far with those kind of temps but was glad to see it run full and complete Score 7843 Cinebench R20
all of the following done on Ryzen Master with PBO and boost off. XMP Profile no overclock on rams since i seem to suck at it 3200 CL 14. 2x 16gb Trident Royals
I had to RMA my Mobo and ssd cause it kept vanishing from the bios so will see what happens after I really start to tighten down ram timings. I need to remember to check my VIDS and idle voltages. Lottery CPU not sure? Will see if I can duplicate scores and overclocks when I get my replacement parts
Dphotog is offline
post #34 of 84 (permalink) Old 07-29-2019, 09:16 AM
buddywh's Avatar
Rep: 8 (Unique: 8)
Adding another data point:
3700X, PBO, scalar 10X, CoolerMaster ML-240, FlareX 3200 CL14 using XMP
CB 20: 5040 MT, 509 ST
High Temp 74.6
buddywh is offline
post #35 of 84 (permalink) Old 08-02-2019, 07:54 AM
Graphic Card Addiction
Hequaqua's Avatar
Rep: 188 (Unique: 131)
3700X Auto Voltage
3466mhzCL14 DRAM
Fractal Design S36 Blackout Edition
R15 Idle Temps: 35-42°
Spoiler!
R15 Load Temps: Max 63.8° Score 2113
Spoiler!
R20 Idle Temps: 35-43°
Spoiler!
R20 Load Temps: Max 65.8° Score 4806
Spoiler!
Offical Ryzen 7 3700X Owner!
MSI RTX 2070 Gaming Z
Fire Strike 23405 Overall 26125 Graphics 25041 Physics 12459 Combined
Time Spy 10644 Overall 10584 Graphics 11000 CPU
https://www.3dmark.com/3dm/41820044
Gespenst(Ghost)
(29 items)
Rigor Mortis
(20 items)
Lassie
(14 items)
Ryzen Zen 2 3700X [email protected](Lapped)
Gigabyte X470 AORUS GAMING 7 WIFI
GSkill Trident Z F4-3466C16-8GTZR([email protected] 1.38v)
Silicon Power 512GB NVMe(SP512GBP34A80M28)[Benchmarking]
Western Digital Blue 1tb (External)Back Up
Seagate Firecuda 2tb(ST2000DX002-2DV164)[Downloads/Editing]
TeamGroup Delta RGB 1tb 5v Header[Games]
Western Digital WD BLACK SN750 NVMe 500gb w/heatsink[OS]
PNY XLR CS2211 480gb[Music/Video]
EVGA Supernova G3 850w
Bykski DDC Pump/96mm Res(B-PMD3-COV+CT96)
FormulaMod Aura aRGB 120mm*3
Gentle Typhoon Black Edition(Custom Sleeved)
Optimus Foundation Acrylic+Black Aluminum Raw Copper
Black Ice Nemesis 360GTS Ultra
Bykski Flow/Temp Meter B-TFC-CS-X
Bykski MSI RTX 2070 GAMING Z 8G Full Coverage GPU Water Block - Clear (N-MS2070GM-Z-X)
Nidec Gentle Typhoon[2150]
Phanteks Eclipse P600S Anthracite Grey
Operating System
Windows 10 Pro
Acer KG271 Cbmidpx 27" Main Monitor 144mhz
Acer S271HL 27" Secondary Monitor
Keyboard
Gigabyte Mechanical Cherry Blue Keyboard (GK-FORCE K83 BLUE)
Mouse
Redragon M602 RGB Wired Gaming Mouse RGB
Mousepad
ENHANCE LED Gaming Mouse Pad Hard Large Surface
Audio
Mpow 2.4G Wireless Gaming Headset
Other
ENHANCE Pro Gaming Mouse Bungee Cable Holder 4 Port USB Hub with 7 LED Modes
Other
FormulaMod Fm-TBJXQ, Sata Type 5v 3pin RGB Synchronization Hub
AMD Ryzen 2700
Gigabyte B450 Aorus Elite
GIGABYTE GeForce GTX 1080 G1 Gaming GV-N1080G1 GAMING-8GD
OLOy WarHawk RGB 3000mhz MD4U083016BEDA(OC 3200mhz)
Corsair Force MP500 M.2 CSSD-F120GBMP500 120gb
Seagate FireCuda Gaming SSHD ST2000DX002 2TB
Silicon Power Slim S55 SP480GBSS3S55S25 480gb
WD Blue WD10EZEX 1TB
Seagate 600 Series ST240HM000 240gb
EVGA SuperNOVA 750 G2 220-G2-0750-XR 750w
DeepCool Castle 240 RGB
Cougar Panzer-S Transparent Fortress
Operating System
Windows10 Pro
Acer GN246HL 24" 144hz
AOC E2425SWD 24" 60hz
Keyboard
ENHANCE Infiltrate Membrane Gaming Keyboard
Mouse
ENHANCE PowerUP Wireless Gaming Mouse
Mousepad
ENHANCE PowerUP Wireless Charging LED Mouse Pad
Audio
Letton Wireless Headset 7.1
Other
Oculus Rift S
AMD 2600X
Gigabyte B450 Aorus Pro Wifi
Asus ROG Strix GTX1660 Super Advanced
Oloy Warhawk RGB 16gb 3000mhz MD4U083016BEDA
Samsung 970 Evo 250gb MZ-V7E250BW
Kingston SV300S37A SSD 120gb
Seagate ST3250318A
WD 5000AAKX 500gb
Rosewill Capstone 750
EVGA CLC240
Yate-Loon High Speed(Red) 140mm
BitFenix Spectre Pro Solid White 140mm
Phanteks Enthroo Pro
Operating System
Windows 10 Pro
Hequaqua is online now
post #36 of 84 (permalink) Old 08-08-2019, 11:01 PM
Rep: 0
CPU-3900X 1.32volt
43.50 clock speed
Cooler- Kraken X62 AIO
Ram Corsair RGB Pro Cl16 17 17 35 50(3600)
R20 Max Temps 76° Idle 33°
@4.3 I only need 1.29volt same settings yield 70°-72°
gemini002 is offline
post #37 of 84 (permalink) Old 08-09-2019, 12:15 AM
mongoled's Avatar
Rep: 30 (Unique: 23)
Quote: Originally Posted by Gill.. View Post
3900X on X370 Asrock Killer SLI/ac
Thermaltake AIO 280MM
GSkill Trident Z (AMD SKU) 3600 [email protected] 3200 with [email protected] CL16 (WHEA issues!)
PBO on (Advanced) 10X Scalar and Motherboard limit
LCC's offset to 2
Idle temps can get below 30C (28 at best with AC on in the room) Idle package wattage = 25W
R20
After 1 run 48Cish
couple runs 50Cish
VRM after 1 run = 48C
VRM's while [email protected]% = 60ish
CPU while mining = 52ish if AC is on
Peak wattage = 125
Vcore around 1.35 but I saw it spike to 1.36...if you look at the individual cores..it can hit 1.5
One other thing to note (since it seems you guys have high temps)..my case is open..4 fans in the case (1 directly on VRM) all 140mm and 2 more on the AIO venting up out of the case
I cracked 7332 on R20 average 7250
Average 3175 on R15
Tryhard score = 7399 (turn off all monitoring software - change Process Priority to "realtime" *note you will not see it actually perform..be patient*) I added third pic...note max temp was 46 (I left HW Monitor running this time)...and also note all the boost clocks. BLAM!
All cores will stay at 4124 MHz as long as it's below 48C...above that it dips to 4099 I peak boost clocks well in excess 4500 on 6 of the cores (some 4650ish sometimes)
One interesting thing I found - turn off RGB Service in the background (Lighting). It raised Cinebench and Geekbench quite a bit - was stealing around 3% CPU usage (on a 24 thread chip mind you..ridiculous)
Hi, could you possibly post your temps using hwinfo64 ?
The only reason I am asking is that the temperatures you have relayed are way way lower than almost any other person ive found.
Thanks
** EDIT **
Have a look at my screenshot, hwinfo64 and hwmonitor, the temps are completely different on my setup ....
SeaSonic X750 Gold 750W
MSI X370 XPOWER Gaming Titanium | Ryzen 5 3600 2016SUS BCLK @107.5625 | EDC @3
Viper Steel Series PVS416G413C9K @ 3800/1900 mhz | 1.552v | 14-15-14-12-26-38-247-16-1T
Asus GTX 780 DCII OC @ 1332/3522 mhz, 1.3v | Samsung 960 EVO 500GB
EK-FB MSI X370 XPower RGB Monoblock 1/2" ID | Swiftech D5 MCP655 | EK-XRES 100
Alphacool NexXxoS UT60 280 | 4 x Scythe GT AP-15 @ 5v
Thermochill PA120.3 | 1 x NF-A12x15 | 2 x ML120 | PWM
mongoled is offline
post #38 of 84 (permalink) Old 08-09-2019, 12:25 AM
mongoled's Avatar
Non optimized OS, i.e. AV running, all background apps running etc etc
PBO on auto
Custom loop, fans @5v (see sig)
R15 ran first, then ran R20 straight after
Cinebench R15
Max Temp: 68.9 C
Cinebench R20
Max Temp: 69.8 C
mongoled is offline
post #39 of 84 (permalink) Old 08-09-2019, 12:31 AM
VPII's Avatar
Rep: 16 (Unique: 11)
Okay I've been through a couple issues over the past week or so. Firstly used my trusty C7H board to run the 3900X... unfortunately the board said good bey as it lost a memory channel. I first looked at the Gigabyte Aorus Elite X570, but after one day I sent the board back, really not my cup of tea. I've always been an Asus user, but decided to try the Msi Meg X570 Ace.... what a pleasure. But I cannot seem to match the results I got in CB with the C7H board, still good though. Just cannot do any CCX clocking with the board as it increases vcore like crazy which was not the case with the C7H when vcore set manually. Below is what I got with the C7H in CB20, Hwinfo temps on the left.
VPII is offline
post #40 of 84 (permalink) Old 08-15-2019, 06:30 PM
Rep: 0
Here are my scores
Ryzen 3600
Noctua NH U12S
Sent from my SM-N960U using Tapatalk
sigfan86 is offline
