Ryzen 3000 Cinebench TEMPS - Page 6 - Overclock.net - An Overclocking Community
post #51 of 65 (permalink) Old 08-20-2019, 11:39 PM
mongoled's Avatar
Rep: 17 (Unique: 13)
Quote: Originally Posted by Gill.. View Post
snip....................I see what you guys are reading - that's Tcl/Tdie - look at the next chart down. That reading seems to be the same as the Junction Temp on the GPU's - the hottest single spot. That's not your whole CPU - that's the chart below, and what CPUID HW Monitor reads. Yes, Junction is important - but not indicative of the real CPU temp. Correct me if I'm wrong...but it's more in how you read it - just like GPU reviews...and how AMD and Nvidia read them all differently.
Hi!
thanks for getting back to me
OK, so all makes sense now, regards which temperature you wish to read and as you have acknowledged, most people are using the "Tcl/Tdie" as the CPU temperature because that is the closest to the CPU temperature that is being shown in Ryzen Master.
Your 'maximum' 77.5C Tcl/Tdie temp is generally what I would expect from your cooling/cpu/voltage combination
If you check the screen shot for my cinebench run you will see that in hwinfo64 for my motherboard that the CPU temp is almost the same as the "Tcl/Tdie" temp.
Anyhow, now that we are all on the same hymn sheet continue as scheduled
SeaSonic X750 Gold 750W
MSI X370 XPOWER Gaming Titanium | Ryzen 5 3600X 1924SUT
GSkill TridentZ F4-3600C15D-16GTZ @ 3800/1900 mhz | 1.44v | 15-17-10-15-42-28-266-16-1T
Asus GTX 780 DCII OC @ 1332/3522 mhz | 1.3v | Samsung 960 EVO 500GB
EK-FB MSI X370 XPower RGB Monoblock 1/2" ID | Swiftech D5 MCP655 | EK-XRES 100
Alphacool NexXxoS UT60 280 | 4 x Scythe GT AP-15 @ 5v
Thermochill PA120.3 | 1 x SST-FN123 | 2 x Scythe GT AP-15 | @ 5v
mongoled is offline
post #52 of 65 (permalink) Old 08-21-2019, 04:40 PM
Rep: 0
Update to my 3600 post
3600 4.2ghz all core OC using ryzenmaster 2.01.1233
Cpu voltage: 1.29375V
Core clock: 4200 mhz
Cinebench R20 multi core: 3656
Cinebench R20 single core: 464
Max cpu temp: 68 deg C
Idle temps: 37 deg C
Motherboard: MSI x570 pro carbon wifi
Cpu: ryzen 3600
Sent from my SM-N960U using Tapatalk
sigfan86 is offline
post #53 of 65 (permalink) Old 09-16-2019, 08:25 AM
Rep: 0
Ryzen 3600x
OC Mode: Default
Idle: 45C Room:27C
~4049 all core(~1.34) during Cinebench 20, 82C
3518 Cinebench Multi score
Noctua NH-D15s with 2 intake,2 exhaust case fans.
GSkill 3200 CL14 (Fast preset of Dram calc)
Is it ok or should I reapply thermal paste/add extra cpu fan?
Name:	Screen Shot 2019-09-16 at 18.19.46.png
Ryzen build
(10 items)
Ryzen 5 3600x
ASUS TUF GAMING X570-PLUS (WI-FI)
Palit Geforce GTX 1080 ti super jetstream
G.Skill 16 GB (2x8GB) DDR4 3200 MHz Trident Z RGB
nVME SSD ADATA XPG SX8200 Pro
be quiet! Pure Power 11 CM
Noctua NH-D15s
be quiet! Silent Wings 3 140mm PWM High-speed
Fractal Design Meshify s2
Operating System
Windows 10 Pro x64
devian.ua is offline
post #54 of 65 (permalink) Old 09-16-2019, 08:38 AM
Synoxia's Avatar
Rep: 6 (Unique: 4)
Quote: Originally Posted by devian.ua View Post
Ryzen 3600x
OC Mode: Default
Idle: 45C Room:27C
Definetely something wrong, either with thermal paste application or config. I have the same config but with +1 intake and -1 exhaust, my 3700x doesnt go past 70c while running cinebench all core with PBO active, PC is also quite silent with this fan curve.
Update bios to 0002 + the stilt SMU mod, it could be that you have the fan error issue, or either reapply thermal paste with spread method or big blob as ryzen heats up at the edge of the chip, more die coverage = better
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
G-Skill Tridentz OC 16 gb 3800 c14-16-17-16-32-48
EVGA G3 Gold
Noctua D15
Phanteks Enthoo pro TG
Operating System
Win 10 1903 build 18950 64bit
Viewsonic XG2401
Keyboard
Fnatic RGB Cherry mx brown
Mouse
Logitech G Pro Wireless 950 dpi
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is online now
post #55 of 65 (permalink) Old 09-16-2019, 08:52 AM
VPII's Avatar
Rep: 8 (Unique: 7)
Okay, slight update with my so so manual overclock at 4.325ghz using 1.3vcore for my 3900X. My normal everyday I'll post first which is 4.275ghz at 1.25vcore and it will be what I normally use now with summer starting in South Africa. On the 4.325ghz run, look at the previous best also highlighted, only difference is bios from Agesa 1.0.0.3 AB to ABB..... The Dancing Queen ABBA is not that great for me.
AMD
(9 items)
AMD Ryzen 2700X
Asus Crosshair VII Hero
GALAX RTX 2080 TI OC
G.Skill f4-3200c14d-16gtzr tridentz rgb
Crucial MX300 M.2 SSD
Corsair HX1200i
CoolerMaster MLW-D24M-A20PC-R1 MasterLiquid ML240L 240mm RGB Liquid CPU Cooler
Operating System
Windows 10 Pro
Dell U2717D 27" UltraSharp InfinityEdge LED Monitor
VPII is offline
post #56 of 65 (permalink) Old 09-16-2019, 02:57 PM
Rep: 28 (Unique: 25)
CPU: 3800X
OC: Manual Mode
Cooler: Custom Alphacool water cooling
temps Idle: 40-45C
Score R20: 5340-5360
Just something ridiculous for you guys.
R20 ~160Watts ~90C
IBT ~180Watts (very high 10x setting) 95-100C
Name:	R20 4450 1.525V TEMP.png
Gigabyte X570 AORUS XTREME, Ryzen 7 3800X 4.45Ghz, 4266/1900 MEM/FCLK, 16.26.19.48.76.tRFC 650 1T 1.58V
4x8Gb Kingston HX434C19FB2K2/16 3466C19 1.2V (Micron E-die 16nm)
OLD: Biostar x470GT8 Ryzen 7 1700 @ ~4.0Ghz CPU, 3200Mhz RAM ...
Nighthog is offline
post #57 of 65 (permalink) Old 09-20-2019, 05:41 AM
kingzize's Avatar
Rep: 0
Quote: Originally Posted by Nighthog View Post
CPU: 3800X
R20 ~160Watts ~90C
Ouch, what an aggressive overclock. That 1.525v SVI2 voltage can't be healthy for your CPU!
Ryzen 7 3800X
MSI B450I
EVGA RTX 2080
G.Skill TridentZ F4-3600C15-8GTZ @ 3800C16
Samsung 970 EVO Plus
Corsair SF600 Platinum
Corsair H115i Pro 280mm AIO
Streacom DA2
kingzize is offline
post #58 of 65 (permalink) Old 09-20-2019, 06:03 AM
Overclocker in training
ThrashZone's Avatar
Rep: 71 (Unique: 55)
Hi,
If anyone really wants to test cooling systems try blenders open data long or full test
Runs just like any benchmark does.
https://opendata.blender.org/
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #59 of 65 (permalink) Old 09-20-2019, 12:15 PM
kingzize's Avatar
Rep: 0
3800X @ 4.35Ghz Manual OC @ 1.325v
H115i Pro AIO
CB20 - Score 5130
Idle temp: 35C
CB20 temp: 67C
Ambient temp: 21C
Ryzen 7 3800X
MSI B450I
EVGA RTX 2080
Streacom DA2
kingzize is offline
post #60 of 65 (permalink) Old 09-21-2019, 06:26 AM
Spy
Rep: 0
CB20 - Score 5130
very slow for 4.35
my 3800x 4.35 @ 1.3v and other results with noctua d15:
Spy is offline
