Precision Boost Overdrive How Much Over Max Boost You Have - Overclock.net - An Overclocking Community
post #1 of 52 (permalink) Old 07-14-2019, 06:20 PM - Thread Starter
gerardfraser's Avatar
Rep: 99 (Unique: 77)
EDIT Aug 12 2019:Let me start by saying I was wrong and I apologize for any misinformation I supplied due to my ignorance. I was aware of Third-Party Monitoring Tools not being as accurate as Ryzen Master and I just ignored that fact all together.
I have started testing with Ryzen Master only now to see what the actual clocks on my Ryzen 3600X really is.Although I still get over Max Boost as what is written on the box so I have no recourse to complain to AMD or refund my CPU'S.Also they are still fast little CPU's Still happy.
I have only witness Cinebench20 hitting Max Boost on 2 cores as of testing today.I will test some more with different BIOS and if any change is observed I will post back.
Spoiler!
gerardfraser is offline
post #2 of 52 (permalink) Old 07-14-2019, 06:27 PM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
People are struggling just to get 4.6GHz on the R9 3900X
I think the +200MHz PBO is more of a limit than what is expected clocks
On Zen+ PBO is the limit (i.e. it just allows the cores to turbo to 4.35 on R7 2700X, thermal and EDC/PPT dependent).
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #3 of 52 (permalink) Old 07-15-2019, 08:49 AM
enigmatic23's Avatar
Rep: 0
Reached 4600 on a 3800x with a negative offset of .1. Regularly see 4550 boost on Crosshair Vi Hero.
enigmatic23 is offline
post #4 of 52 (permalink) Old 07-15-2019, 09:04 AM
rdr09's Avatar
Rep: 894 (Unique: 644)
Finally! I ryzen cpu that boost to spec and more. Can you give details of your settings? PBO? Agesa?
By Built-in Benchmark Queen:
My 2.5 years old delidded 7980xe @ 4600mhz all core with 49ns memorylatency (4000c16 twekaed) is faster than 3950x max overclocked on water in every scenario. Pretty good for a ancient cpu
In gaming it has no chance vs my new 10900k @ 5400mhz and 4600c16 tweaked memory. ~35ns memorylatency.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #5 of 52 (permalink) Old 07-15-2019, 12:09 PM - Thread Starter
Nice 3800X on X370 ,do not make me jelly boosting 100Mhz over what's printed on the box.Sweet I should buy 3800X and try it out but I only game and there will be no real difference for me given a few FPS.
post #6 of 52 (permalink) Old 07-15-2019, 12:46 PM
Optics Fiend
Blackops_2's Avatar
Rep: 81 (Unique: 66)
I haven't gotten it to work on the B350 despite having settings for it.
Green Envy
(12 items)
Purple Haze
(12 items)
i7-3770k @ 4.5ghz
Gigabyte G1.Sniper 3
EVGA 780 Classified
EVGA 780 Classified
16GB GSkill Ripjaws DDR3 2133
WD Raptor
Seasonic 850w M12II
Cooler Master Glacer 240L
Phantek Enthoo Pro
Operating System
Windows 7 64-Bit Home premium
Asus VG248QE
Keyboard
Logitech G15
Ryzen R5 1600x
Fatal1ty AB350 Gaming-ITX
Diamond 7970
G Skill DDR4 3200
Western Digital Black
Samsung 850 Evo
Corsair SF600
Black Ice Nemesis L-Series 240 Stealth
EK-FC7970 CSQ
Mayhems X1 UV Purple
Fractal Design Define S Nano
Blackops_2 is offline
post #7 of 52 (permalink) Old 07-15-2019, 03:11 PM
The Stilt's Avatar
Rep: 873 (Unique: 334)
Its not wise to undervolt Matisse, unless you enable the OC-Mode (fixed frequency).
That's because the CPU is constantly monitoring its supply voltage.
When it sees the supply voltage below the desired level, it starts increasing the VID request from the VRM controller.
When the VID request increases above the maximum voltage allowed by FIT, the clock stretchers will kick in. Your performance will decrease, despite the change is not visible
in the frequencies diplayed by the usual monitoring software.
For example on the 3900X sample I have, the default VID request during CB20 NT is 1.3125V.
With the offset set to -25mV the VID request raises to 1.33125V or so. At -75mV the VID request is already 1.36875V and increasing the negative offset any further will trip the stretchers.
There is an undervolting margin available, but it is tiny.
The exact behavior will depend on the silicon specimen and the workload.
Its also the very reason why this guy thinks he is running at > 4.2GHz with just 1.00V...
The Stilt is offline
post #8 of 52 (permalink) Old 07-15-2019, 03:11 PM
Rep: 0
PBO on, Scalar x10, all PBO limits at motherboard max in bios, Agesa 1.0.0.2.
post #9 of 52 (permalink) Old 07-15-2019, 03:12 PM
The Stilt's Avatar
Scalar does nothing on Matisse.
You can change it to 0.5x (not from the bios thou) and there is no change in the behavior.
post #10 of 52 (permalink) Old 07-15-2019, 03:48 PM
⤷ αC
AlphaC's Avatar
Have you tried this on MSI boards? OptimumTech is using a Godlike.
Your theory is that his undervolt dropped performance despite him not realizing it. Power consumption is most definitely down since he dropped 20°C.
AlphaC is offline
