Noob needs help with LLC on R5 1600 with X370. - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 07-16-2019, 12:22 PM - Thread Starter
Rep: 0
Hello, my R5 1600 isn't stable at 3.8GHz with anything less than 1.350V on auto LLC (Asus X370 Pro). Though when I'm stressing it with OCCT or Cinebench R20 the SVI2 voltage only goes up to 1.306V, and when setting LLC to level 3 (it goes from 1 to 5) it goes up to 1.331V. I don't really know what to do with LLC, do I want the voltage to be as close to the BIOS setting as possible or is it better when it's lower?
wizzie is offline
post #2 of 4 (permalink) Old 07-16-2019, 01:57 PM
FX-5000
ShrimpBrime's Avatar
Rep: 66 (Unique: 47)
When cpu voltage is lower than the bios setting, that is what is called v-droop or v-drop depending if it's constant or a drop spike.
Ideally you'd want to have voltage stable at what you set it to via bios and LLC to prevent that droop/drop.
My bios is worded like low medium high and extreme. I often more so use extreme to have voltage reading slightly above what I set in bios and on high it holds the setting pretty well.
For your use, you might be better to run 4 or 5 and test.
You're at a good voltage and clock speed though.
ShrimpBrime is offline
post #3 of 4 (permalink) Old 07-17-2019, 05:40 AM - Thread Starter
Rep: 0
Ok so I should use LLC to get it as close to the BIOS setting as possible to improve stability, thanks a lot for the help!
wizzie is offline
post #4 of 4 (permalink) Old 07-17-2019, 01:59 PM
FX-5000
Yes, using LLC to stabilize voltage is a great idea. Try setting 4 and do some testing, gaming ect. If it's more than 0.050 lower than the set voltage at load, then bump it up to setting 5.
If setting 5 runs voltage higher than desired, but runs stable, lower the v-core in one click or smallest amount possible and test for stability.
You mentioned isn't stable. The memory can also play a role here. If your running the Mem on auto, you may want to manually configure that as well.
