Help with undervolting FX-9590 - Overclock.net - An Overclocking Community
post #1 of 19 (permalink) Old 07-24-2019, 11:33 AM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
Hi all,
So it's summer and i live in a house that has no AC and is old wooden floor and its around ambient 32c spiked at 35c outside so cant tell what it is inside my room. And it only going to get warmer!
Idle temp cpu 36c to 38c
Im using a custom water cooling loop. D5 pump top, Koolance CPU-380A, 480 radiator.
Motherboard: TUF SABERTOOTH 990FX R3.0
RAM: Corsair Vengeance 4x4GB
I never done undervolting or overclocking this 220W cpu.
What i want to ask you guys how to undervolt my cpu currently its at 1.5v
I want to lower it but still run at 4.7GHZ
Some guy lowered the voltage to 1,368 V still runs at 4.7GHZ. And also lowered his temps.
Link:
https://linustechtips.com/main/topic...peratures-and/
Can some one tell me what to change in the BIOS in a simple manner without harming my pc. Note i just use stock settings.
Is it just simply lowering the cpu voltage and thats it?
Anyway help is much appreciated
Cobra26 is offline
post #2 of 19 (permalink) Old 07-24-2019, 11:48 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1094 (Unique: 634)
yes.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 19 (permalink) Old 07-24-2019, 12:00 PM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
Quote: Originally Posted by The Pook View Post
yes.
Thanks for the reply,
Could you give the specific option name in the BIOS in order for me to lower the voltage. Just to verify are you sure that's the only thing i need to change no other settings like turn of turbo etc?
Example:
1.5+ VCORE to say 1.368 and disable TURBO as well as LLC?
Cobra26 is offline
post #4 of 19 (permalink) Old 07-24-2019, 12:15 PM
9 Cans of Ravioli
The Pook's Avatar
you're not going to get 1.368v stable on a 9590 without underclocking.
LLC deals with vdroop. If vdroop is fine now, there's no reason to change it.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
Acer XF270HU
Dell E2311H
Keyboard
Mouse
Logitech G502
Audio
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #5 of 19 (permalink) Old 07-24-2019, 12:25 PM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
Thanks again,
Yeah underclocking 4.7GHZ is plenty with turbo it can reach 5GHZ with turbo no need for that. So have to disable TURBO correct?
So what would you do? In order to lower temps obviously lowering the vcore to 1.368 and let it stay @ 4.7GHZ (disabled turbo). Im no expert when it comes down to overclocking or underclocking.
Can you give me a simple setup what to change in the BIOS without to much risk. Maybe lowering to example 1.368 is to low but something a little bit higher is also fine as long as it gets lower temps and stability.
Cobra26 is offline
post #6 of 19 (permalink) Old 07-24-2019, 12:46 PM
Heuchler's Avatar
Rep: 273 (Unique: 192)
FX-9590 was binned for high leakage so undervolting and, as The Pook suggested, 4.70 GHz
I would manually set 4.7GHz (disable Turbo) and start at 1.40 volts and keep on dropping volts after every stability test. keep paper and pen handy.
After finding your chips sweet spot you can switch to offset for vCore in BIOS or try MrsTweaker.
Undervolting/Editing P-States For Piledriver using AMD MrsTweaker (Mini Guide)
https://www.overclock.net/forum/10-a...ini-guide.html
Overclocking History (Click to show)
Intel 386DX/16 @ 20 MHz
CX486SLC/50 @ 50 MHz
AM486DX2/80 @ 100 MHz
AM486 DX4-100 @ 120 MHz
AK5x86-P75 [email protected] 160 MHz
Pentium 90 @ 120 Mhz
IBM 6x86L P166+ [email protected] 160 MHz
Celeron 300a @ 454 MHz
Pentium 3 700 @ 933 MHz
Athlon XP 1400+ @ 1600 MHz
Athlon XP 1800+ @ 2088 MHz
Athlon XP 2500+ @ 2200 MHz
Athlon 64 3000+ @ 2603 MHz
Athlon X2 BE2300 @ 1900 MHz
Athlon X2 4200+ @ 2210 MHz
Athlon X2 5000+ @ 2600 MHz
Core 2 Duo E4300 @ 3000 MHz
Core 2 Duo E6750 @ 3600 MHz
Core 2 Duo E8400 @ 4000 MHz
Xeon C2Q L5408 @ 3200 MHz
Xeon C2Q X5450 @ 3300 MHz
Xeon C2Q E5440 @ 3400 MHz
Xeon C2Q E5450 @ 3600 MHz
Phenom2 X4 B50 @ 3700 MHz
Phenom2 X6 1045T @ 4050 MHz
Core i5-2500K Sandy @ 4500 MHz
X5650 6-Core Westmere @ 3982 MHz
AMD FX 8320E Black Edition
FX-8320E @4.5GHz, X5650 @ 4.0GHz, X6 1045T @4.0GHz, i7 [email protected]
Thinkpad T420p with i7-2720QM overclocked because this is OCN
Heuchler is offline
post #7 of 19 (permalink) Old 07-24-2019, 01:57 PM
cssorkinman's Avatar
Rep: 463 (Unique: 263)
Worst voltage hog I've ever owned surprised it was able to do this. I'll try some other stuff with it and report back. ( the thing hits 1.58 volts at default turbo speeds/core volts without llc boosting it). 240mm clc cooling it , 22c ambient.
Will run Aida 64 stress test for about 20 mins before a cache fail - seems like it would run forever without the cache being stressed. 4x4 mem at 2400 is a pretty tall order for FX.
Pov ray 3.7 completed no problems.
cssorkinman is offline
post #8 of 19 (permalink) Old 07-24-2019, 08:41 PM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
Ok...
So i went into the BIOS disabled AMD turbo core. Must i use "Offset" or "Manual"?
Proceed to CPU voltage current @ 1.512v so i tried to lower it to 1.400v is it 1.512 - 1.400 = 0.112?
Is 0.112 the sequence you need to type or just 1.400? I did on both and got some numbers but i didn't trust it so i used F5 and bring it back to "optimal default" but still disable Turbo. Press F10 save exit.
Gosh i sound like a complete NOOB terrible sorry guys!
I can build pc, do custom watercooling, BIOS update but i never thinkered with overclocks nor underclocks. Even something simple like lowering the voltage...
Cobra26 is offline
post #9 of 19 (permalink) Old 07-25-2019, 08:23 AM
curmudgeon
miklkit's Avatar
Rep: 306 (Unique: 177)
I don't remember how I did it but my 9590 at 4.7 ghz ran at 1.425 volts and was stable. Still have it.
IOKIYAR
Junkyard Dog
(18 items)
Blackie
(17 items)
AMD Ryzen 1700
Biostar X370 GT7
Sapphire Nitro+ Radeon Vega 64
G. Skill Ripjaws ddr4 3200 16 GB 4x4
Samsung 850 EVO 500gb SSD
Western Digital 500gb
Samsung 860 evo 1tb ssd
Optical Drive
Memorex Lightscribe dvd
Seasonic 850 watt
Thermalright Silver Arrow IB-E Extreme
Silverstone Redline RL05
Operating System
Win 10 64bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent vertical mouse
Mouse
yes
Audio
Creative X-FI
Other
Sennheiser headphones HD 599
AMD FX8370 @ 5 ghz
ASUS Sabertooth
Sapphire Fury
G Skill F3-14900CL9Q-16GBXL
Western Digital
Samsung 850 EVO
Optical Drive
Seasonic SS-850KM Active PFC F3
Silverstone Redline RL02b
Operating System
Win X 64 bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent VM4
Mouse
yes
Audio
Creative Soundblaster Z
Audio
Sennheiser 428 headphones
miklkit is offline
post #10 of 19 (permalink) Old 07-25-2019, 02:22 PM
FX-5000
ShrimpBrime's Avatar
Rep: 67 (Unique: 48)
Best way to get lower voltage and higher clocks is going with chilling. The hotter FX runs, the more voltage it will want to consume.
As mentioned very high leaker, so really good for sub ambient and sub zero clocking.
You could also drop it to a quad core to significantly lower temps to utilize a higher voltage to achieve a higher clock speed assuming you don't need all 8 cores.
From some testing I've done, around 0-5c load and 2 cores would produce clocks at 5.6ghz and using 1.560v (bench stable testing - not daily) are some numbers I came up with with a FX-8350. Same cpu at 5.4Ghz was able to test and run benches at 1.464v. 5.2ghz at 1.440v and sub zero.
These are examples with 2 cores enabled under TEC cooling solution.
FX is temp limited, not voltage limited. Find a way to run it cooler.
ShrimpBrime is offline
