Ryzen 3600 - High load temps - Overclock.net - An Overclocking Community
post #1 of 40 (permalink) Old 08-14-2019, 03:47 PM - Thread Starter
Rep: 0
I’ve got a new Ryzen 3600 on a new Strix B450-F board. UEFI and Chipset Drivers are updated and current. The UEFI settings are untouched stock except for enabling the DOCP profile for 3200 RAM.
Running Prime95 (Small fft’s) with the stock Wraith cooler the 3600 temps immediately climb over 95C (and temp monitoring stops). Swapping a CM Hyper 212 cooler brings temps into the low 90’s; and an AIO cooler brings them into the upper 80’s. This seems extraordinarily high; and about 25 degrees higher than a Ryzen 1700X I have. All temps initially measured with HWInfo64 (Tctl/Tdie) and separately confirmed with Ryzen Master.
So, with both running Prime95 and with the same Hyper 212 cooler, I have:
65W TDP Ryzen 3600 temps in the low 90’s,
95W TDP Ryzen 1700X temps in the mid-60’s.
The Ryzen CPU with a 30W lower TDP is running about 25 degrees hotter.
This doesn’t seem right. Can anyone explain why this is? Is my 3600 bad?
Mark_ is offline
post #2 of 40 (permalink) Old 08-15-2019, 01:00 AM
AMD OVERLOCKER
rastaviper's Avatar
Rep: 2 (Unique: 2)
There is no such thing as bad cpu in terms of temperature.
Obviously the cooling is not good enough.
Did u try with the stock cooler of the 3600?
Sent from my ONEPLUS A6003 using Tapatalk
  • Ryzen 3600x @4300 v1.3
  • Gigabyte Aorus Elite x570
  • G-SkillLL F4-3200C15D-16GTZ Trident Z Series 16GB CL15 Bdies @3660 16-15-15-1T
rastaviper is offline
post #3 of 40 (permalink) Old 08-15-2019, 01:07 AM
Graphics Junkie
UltraMega's Avatar
Rep: 30 (Unique: 26)
what is your Vcore?
I just built a 3700X PC and the default Vcore was way higher than it should have been and caused me to overheat. I had to use offset to lower it. CPU is stable and much lower temp.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #4 of 40 (permalink) Old 08-15-2019, 01:26 AM
Senior OCN Member
shilka's Avatar
Rep: 2741 (Unique: 1626)
None of the coolers you have tried are all that great thats why temps are so high
The Cooler Master Hyper 212 is ancient its design go back at least 10 years which means the stock AMD Ryzen cooler is a newer design
Unless the AIO you tested was a 240mm or bigger its not going to be all that much than the stock cooler or the 212
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #5 of 40 (permalink) Old 08-15-2019, 04:15 AM
upgraditus's Avatar
Rep: 8 (Unique: 6)
You're comparing rated TDP not actual power draw.
You'd need to compare the two under the same workloads whilst baring in mind that while there might be less power going to the 3600, that power is being fed to two less cores to begin with and those cores are smaller / higher density. The whole core complex are much smaller again giving less surface area to contact the IHS reducing it's ability to dissipate heat as effectively.
This will likely only get worse as nodes further reduce in size.
= Ryzen 7 3700X 4.3GHz @ 1.3v / Thermalright TS140 BW / Prime X470-Pro / 16GB Crucial BSLT 3733 MT/s cl16 / 1080Ti Amp Extreme 2GHz @ 0.987v / Aerocool Project7 P650 / Fractal Define XL =
upgraditus is offline
post #6 of 40 (permalink) Old 08-15-2019, 05:24 AM
rdr09's Avatar
Rep: 863 (Unique: 631)
^this. Just wait till you get a better cooler. Got a Noctua U12S (Single fan) on my 3600 and my load temp (gaming and benching) never exceeds 65c. System is set to Optimized Default using Windows Power Plan - Balance with minimum processor state of 25%.
I applied two lines of MX-4 paste as shown.
BTW, why do you need to run Prime 95 when cpu at stock? Just use your most demanding task. If it is gaming, then game. Also, a version of Prime does not play well with Ryzen. Probably someone who knows will chime in.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #7 of 40 (permalink) Old 08-15-2019, 01:42 PM - Thread Starter
Rep: 0
Thanks to all of you for the quick responses, comments, and ideas. My feedback below:
Yes, that was the first thing I tried. The temps quickly ran over 95 and temp monitoring ceased functioning.
Mark_ is offline
post #8 of 40 (permalink) Old 08-15-2019, 01:49 PM - Thread Starter
Rep: 0
Quote: Originally Posted by UltraMega View Post
What is your Vcore?
CPU Vcore averaged 1.326v in a 10 min run of Prime95. Measured by HWInfo64 (SVI2 TFN).
The AIO used is the Corsair H80i v2; which is materially better than the Hyper 212.
True. The actual electrical power used by Prime95 was 63-65 watts for the 3600 and 110-111 watts for the 1700X. So the 3600 used ~45 watts less power but had temps ~25 Degrees C higher than the 1700X.
I had not heard of this before and will research this further. If anyone else has info on this please chime in.
I run Prime95 on a new cpu to test if it is operating properly and determine what level of cooling is needed. Every i7, Xeon, or Ryzen cpu I’ve had in the past decade has been able to run Prime95 in the 60-70 degree range when using a Hyper 212 cooler and running stock (non-OC’d). So when the stock 3600 with a much lower power draw than anything I’ve ever owned generates heat much higher than I’ve ever seen I’ve got to question it.
The basic laws of physics call for a direct correlation between how much electrical power (watts) goes in and how much heat is generated. So, there must be something else going on here that I don’t understand. Perhaps the temps are being measured differently??? If anyone can help, please jump in.
Since my original post I’ve run a series of stress tests using Prime95 (Balanced mode for lower temps), RealBench, OCCT, and MemTest86; no faults or problems were noted other than the higher temps. Ultimately, my big questions are:
1. Is this a faulty cpu and should I exchange it for another 3600 with the retailer within the return window?
2. Is this a characteristic of the 3600? If so, should I replace it with another Ryzen (3600X, 3700X) that may not run so hot? Or just live with the high temps and enjoy the exceptional price-performance of the 3600?
Mark_ is offline
post #9 of 40 (permalink) Old 08-15-2019, 03:13 PM
Senior OCN Member
shilka's Avatar
Its better yes but not by huge amounts and since its a single rad CLC cooler it has a tiny amount of surface area to cool with so thats why temps are so high
I am not trying to be rude or insult you so please dont misunderstand but the H80 is not a great cooler since its so small
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
shilka is offline
post #10 of 40 (permalink) Old 08-16-2019, 12:08 AM
Rep: 0
Can you tell what your temps were running CBR20 mt?
MyPC
(9 items)
Ryzen 5 3600X
ASROCK X370 Taichi
Radeon RX Vega 56
Galax HOF 3600
Corsair TX650M
EK FLUID GAMING A240R
Operating System
KDE Neon (Ubuntu 18.04)
Operating System
Windows 10 Pro
Samsung C32H711
PJVol is offline
