Correct Power Plan for Ryzen 3000 CPU's - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 08-27-2019, 06:03 AM - Thread Starter
asefsef's Avatar
Rep: 1 (Unique: 1)
>>>>TL : DR <<<
I just got a Ryzen 3600. What's the correct power plan to choose as of late 2019?
Long version:
Just from my observations on mine and a few friend's 3700x. Ryzen power plan seems to aggressively ramp up cpu frequency to 4.1ghz when sitting idle. Voltages are shown as 1.45v to 1.5v. VSoc is a whopping 1.4v??? Load vDroops vCoreto a safe level at 1.35V. But not liking 24/7 1.4v, I selected high performance power plan instead, and set min processor state to 85%. Now I get 1.0vCore during idle and Load performance remains the same at 1.35volts.
Further, selection window's balanced plan with min processor state 5% drops vcore down to 0.4v at idle, and load performance is the same firestrike performance seems within margin of error.
So what is the "right" power plan to choose now as of August 2019??
asefsef is offline
post #2 of 7 (permalink) Old 08-27-2019, 11:30 PM
rdr09's Avatar
Rep: 863 (Unique: 631)
Test each plan using CPUZ bench. It's quick.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #3 of 7 (permalink) Old 08-27-2019, 11:42 PM
Socks keep you warm's Avatar
Rep: 131 (Unique: 116)
Leave Windows Power Settings to Balanced.
Unsure on AMD Power stepping CPU wise but leave enabled.
You do not want the CPU using a overclocked frequency all day and night with voltage, it's a waste if it's not doing anything.
16 Threads is Good
(10 items)
Intel Core I9 9900K 4.8Ghz
Gigabyte Aorus Elite
Aorus 2080Ti Xtreme Waterforce WB 11GB
Trident Z
Samsung 250 SSD
Cooler Master Silent Pro Hybrid
Watercooling Custom
900D
Operating System
Windows 10 x64
28" ACER 4K Monitor
Socks keep you warm is offline
post #4 of 7 (permalink) Old 08-30-2019, 02:32 AM
Brightmist's Avatar
Rep: 18 (Unique: 17)
Latest Chipset drivers from AMD's site
Ryzen Balanced Power Plan
VSoC 1.1V
VDDG 0.95V
Leave everything else at Auto except DRAM Voltage which you can set using Ryzen DRAM Calculator by exporting your RAM timings summary in nanoseconds from Thaiphoon Burner into Ryzen DRAM Calculator.
Also check your voltage using just CPU-Z, only that one shows the correct values.
Ryzen Master is the only one that shows correct sleep states for cores. Most cores if not all should be asleep when system's idle.
Brightmist is offline
post #5 of 7 (permalink) Old 08-30-2019, 02:44 AM
Tinkerer
RossiOCUK's Avatar
Rep: 2 (Unique: 2)
HWiNFO64 voltage is correct for me.
RossiOCUK is offline
post #6 of 7 (permalink) Old 08-30-2019, 05:32 AM
VPII's Avatar
Rep: 8 (Unique: 7)
VSoC 1.1V
VDDG 0.95V
Thank you, I've done tests with a multimeter back when I used a c7h mobo and the vcore stated by cpuz is correct, the hwinfo64 one not so, usually lower than actual.
Sent from my SM-G960F using Tapatalk
AMD
(9 items)
AMD Ryzen 2700X
Asus Crosshair VII Hero
GALAX RTX 2080 TI OC
G.Skill f4-3200c14d-16gtzr tridentz rgb
Crucial MX300 M.2 SSD
Corsair HX1200i
CoolerMaster MLW-D24M-A20PC-R1 MasterLiquid ML240L 240mm RGB Liquid CPU Cooler
Operating System
Windows 10 Pro
Dell U2717D 27" UltraSharp InfinityEdge LED Monitor
VPII is offline
post #7 of 7 (permalink) Old 08-30-2019, 06:56 AM
Brightmist's Avatar
Didn't really look at HWinfo64's latest beta, they might've fixed that, it gets updated pretty regularly.
AMD stated themselves that CPU-Z shows the correct voltage while Ryzen Master does not
In any case, CPU-Z and HWinfo64 have the smallest observer effects when looking at power consumption from the plug but they still do increase the power usage.
VSOC and VDDG are stock values per The Stilt.
