Is it possible I "won" the lottery by need to RMA my Ryzen 3600? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 29 (permalink) Old 09-17-2019, 04:14 PM
avkdm's Avatar
Rep: 1 (Unique: 1)
fwiw I have seen a bad (incompatible?) power supply do this on an intel 6700k build (it drove me crazy, finally a third power supply - they were all high end - fixed my problem) I changed the ram, cpu, gpu, motherboard, and even SSD.
avkdm is offline
post #22 of 29 (permalink) Old 09-17-2019, 04:24 PM
Stock is too casual~
Veii's Avatar
Rep: 11 (Unique: 9)
Wow what a story~
Just wanting to comment on this
Hopefully the OP should be done with those issues~
Could you track down what it rly did mess up
Plugging a LED into a power on switch / that should make it ?
LEDs if i'm right now not acting dumb ~ shouldn't short contact or ?
Why would that happen o.O ?
Personal Records
SiSandra Inter-Core Bandwith 14nm Ryzen #2 Lost by a 101Mhz FSB OC #1 :>
RAM > Viper Steel @ 3466C14 (64.2ns) & Alt | Hynix-MFR 3333CL14 (72.5ns) & Alt
GPU > Gigabyte 970 G1 @ 1595|1900 (Hynix) | RX 580 Red Devil GS @ 1620|2200 (Micron)
CPU > TR 1950X [email protected]1.2v & [email protected]1.365v[105Mhz FSB](3.23Beta)
#Main: 1700X [email protected]1.365v1.73Ghz IMC CL14 (64.2ns)」+ Dark Rock 3 | X370 Taichi 1.0.0.3 ABBA by The Stilt | Viper Steel [PVS416G400C9K]| Gigabyte 970 G1 | Samsung 850 Evo
Veii is offline
post #23 of 29 (permalink) Old 09-17-2019, 08:30 PM
fastturtle's Avatar
Rep: 4 (Unique: 4)
Veil: An LED = Light Emiting Diode. It's like a one way street in that it only allows current to flow in a single direction. Connected to a Power Switch Connection, it will screw things up because once it lights up, it drops the voltage - the system gets a shutdown/reset signal.
As I'm not an EE, don't take my word for it but most likely. In any case, it's not a good situation and is one of the reasons I prefer individual connections - Yes I've seen a few cases wired wrong but with single connectors you can identify and work around some drunken idiots assembly work.
Hydra
(10 items)
AMD Ryze 5 1600
AsRock B450M Pro
Zotac GTX 1060
Team Elite
NVME
M2 Sata
Seagate Barracuda
Toshiba
EVGA B3
Operating System
Win7-64 Ultimate
fastturtle is offline
post #24 of 29 (permalink) Old 09-18-2019, 01:34 AM
Veii's Avatar
Rep: 11 (Unique: 9)
Thank you , the dropping voltage part did the explanation for me
Personal Records
Veii is offline
post #25 of 29 (permalink) Old 09-18-2019, 05:15 AM
connectwise's Avatar
Rep: 44 (Unique: 42)
unbafudgingbelievable
connectwise is offline
post #26 of 29 (permalink) Old 09-18-2019, 05:22 AM
Old to Overclock.net
papant7's Avatar
Rep: 7 (Unique: 6)
OT: Holy ******* hell that pic
Happened to a pc of a friend who brought it and plugged into a shorted outlet. Causing the connections from the case to cause strange behavior. Try plugging it into a diff outlet
papant7 is offline
post #27 of 29 (permalink) Old 09-18-2019, 07:56 AM - Thread Starter
FZero's Avatar
Rep: 0
Quote: Originally Posted by Veii View Post
Wow what a story~
Honestly I was so disillusioned that I just tossed my case and got a new one. I didn't care to do any troubleshooting. I can tell you guys that all the connectors were plugged in properly on both boards.
The furthest testing I did was run it without any connectors and then plug them all in and it froze. Then I said screw this and got a new case.
FZero is offline
post #28 of 29 (permalink) Old 09-18-2019, 01:13 PM
munternet's Avatar
Rep: 7 (Unique: 4)
This is why, in the past, I have run the motherboard on a counter top with the bare minimum of peripherals when troubleshooting a stubborn problem.
One time when troubleshooting a friends PC we got down to the nitty gritty and it was still switching off after a while. I removed the cpu cooler to see if it was seated properly and it still had the plastic on it . He also didn't seat the ram all the way.
The lesson in his case....don't get blazed and build your pc
9900ks
Asus Maximus XI Gene
EVGA 1080 Ti Superclock 2 Black
F4-4400C19D-16GTZSW
Samsung M.2 1TB 970 EVO Plus
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 1 x 360mm and 1 x 420mm Radiators and Vardar Furious Fans
ThermalTake V51
Operating System
Windows 10 Pro
Asus PG349Q 34.1 inches 3440 x 1440 pixels @ 120 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000x500x3
Audio
Steelseries Siberia800 wireless Headset
8700k @ 5.2ghZ
Maximus X Hero
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Mouse
Mousepad
1000mm x 500mm
Audio
i7-4770k
Asus Maximus VII Ranger
Gigabyte NVIDIA GeForce GTX980
G.SKILL Trident X 16GB 2 x 8GB 2400 Memory F3-2400C10D-16GTX
Seagate Barracuda 2TB
Optical Drive
LG DVD Rom
PSU Coolermaster V1000W
Custom Loop
Case Thermaltake V51 Full Window
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Thermaltake Poseidon Z
Mouse
Logitech G602
munternet is offline
post #29 of 29 (permalink) Old 09-19-2019, 06:29 AM - Thread Starter
FZero's Avatar
Rep: 0
One time when troubleshooting a friends PC we got down to the nitty gritty and it was still switching off after a while. I removed the cpu cooler to see if it was seated properly and it still had the plastic on it [IMG class=inlineimg]/forum/images/smilies/tongue.gif[/IMG] . He also didn't seat the ram all the way.
The lesson in his case....don't get blazed and build your pc [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
This is my takeaway from this crazy experience. To run the board on a countertop before any next build.
FZero is offline
