Ryzen 3600 hight temps and low boost clock - Overclock.net - An Overclocking Community
post #1 of 27 (permalink) Old 10-16-2019, 11:24 AM - Thread Starter
RichterB's Avatar
Rep: 0
Hello, seems that I have an issue with my brand new Ryzen 3600. HWmonitor reports an idle temperature of 40-50 °c, and after less than 10 mins with OCCT, it's between 90 and 95°c.
Room temperature is 26-28°c
I use stock cooler and stock thermal paste. I know it's not ideal, but this can't be the only explanation.
Another problem, is that boost clock never goes above 3,8 GHz, but it should be 4,2 GHz
I have Gigabyte X570 Aorus Elite bios f5b, with 16 Gb DDR4 Corsair Vengeance. And I enabled profile 1 for XMP
RichterB is offline
post #2 of 27 (permalink) Old 10-16-2019, 12:22 PM
rdr09's Avatar
Rep: 867 (Unique: 634)
If you use a better paste, your load should go down by about 10c.
With a better cooler like the Noctua U12s, your load should top out at 75c depending on your ambient.
Don't worry about your idle temp for now. When i used prime at stock, all the cores went up to just below 3900MHz. In Cinebench 15 or 20 Multi-thread bench, all core should go just below 4GHz.
I would advise you replace the stock paste at least with something like MX-4.
Try CPUZ bench. See if the single thread part will make one or two cores boost to 4200MHz. It could be your motherboard has an older BIOS. Older than ABBA.
Use HWINFO64.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #3 of 27 (permalink) Old 10-16-2019, 01:18 PM - Thread Starter
RichterB's Avatar
Rep: 0
Use HWINFO64.
Thanks.
Tomorrow I will try with another paste I already have, it's a Cooler Master something. Just to see if something changes.
I didn't understand the cpu z suggestion. The single thread part is disabled by default, and if I choose one of that presets already in cpuz, the value doesn't change.
RichterB is offline
post #4 of 27 (permalink) Old 10-16-2019, 02:31 PM
rdr09's Avatar
Quote: Originally Posted by RichterB View Post
Thanks.
Download here . . .
https://www.cpuid.com/softwares/cpu-z.html
There is a tab for the bench. Have HWINFO64 in the background when you bench. checkout the max clocks. Bus clock is 99.8 thus max boost is not exactly 4200MHz on two cores.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #5 of 27 (permalink) Old 10-16-2019, 03:28 PM - Thread Starter
RichterB's Avatar
Rep: 0
Download here . . .
On single thread it says 485.7 and on multi thread 3891.2
Hwinfo has rare peaks on 4100 and something for some cores.
RichterB is offline
post #6 of 27 (permalink) Old 10-16-2019, 04:28 PM
Gamer
paulerxx's Avatar
Rep: 72 (Unique: 62)
I have the same CPU + also using the stock cooler, I just decided to overclock all cores to 4.0ghz and be done with it. Temps hit around 85c with prime95.
swah
AMD 2019
(6 items)
ryzen 3600
x570 Phantom Gaming 4
5700XT
16GB DDR4 3200mhz
m.2 512GB
Operating System
Windows 10
paulerxx is offline
post #7 of 27 (permalink) Old 10-16-2019, 04:34 PM - Thread Starter
RichterB's Avatar
Rep: 0
Ok. Room temp? And just to ask: how did you set the airflow?
RichterB is offline
post #8 of 27 (permalink) Old 10-16-2019, 04:54 PM
Gamer
paulerxx's Avatar
All fans except my GPU are set to max, with the stock cooler you can't hear much even at max. My case coolers are also silent. Average room temps, varies day-day. I don't recall exactly what the temps were when I did the tests.
swah
AMD 2019
(6 items)
ryzen 3600
5700XT
16GB DDR4 3200mhz
m.2 512GB
Operating System
Windows 10
paulerxx is offline
post #9 of 27 (permalink) Old 10-17-2019, 12:00 AM
AMD OVERLOCKER
rastaviper's Avatar
Rep: 2 (Unique: 2)
Wow it seems that the 3600 has a really bad stock cooler.
I use the stock cooler at my 3600x and I have never seen any higher temps than 83 degrees during heavy benching at 4.3Ghz.
  • Ryzen 3600x @4490mhz v1.45, 2nd position at HWBOT
  • Gigabyte Aorus Elite x570
  • G-SkillLL F4-3200C15D-16GTZ Trident Z Series CL15 Bdies @3733 16-15-15-1T 1.39v
Offical Ryzen 5 3600x Owner!
rastaviper is offline
post #10 of 27 (permalink) Old 10-17-2019, 02:25 AM
Bartholdi's Avatar
Rep: 0
Saw similar results with the stock cooler on 3600.
Kraken x62 30-40 degrees and 40-50 degrees on coolermaster 240R.
All default settings.
Ryzen 5 3600, 4.2 GHz Coolermaster 240R
x570 MEG ACE
Vengeance LPX DDR4-3200 C16 BK DC - 32GB
ASUS 1080ti STRIX with G12 & Kraken x62.
Corsair Force MP600 NVMe Gen4 M.2 - 1TB & 850 EVO pro 500GB
Moddet Silencio 650 + 4 SP120/140 corsair fans (11 fans & two pumps total)
ROG SWIFT PG348Q
Bartholdi is offline
