Ryzen 5 3600+MSI B450 Tomahawk Max build for a friend - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 10-28-2019, 09:37 PM - Thread Starter
lokito50's Avatar
Rep: 3 (Unique: 3)
Hi all,
I just completed a build for a friend with the mobo+cpu above mentioned, hp ex920 512GB M.2, 16Gb gskill ripjaws V 3200 CL16, evga 600watt psu and have some questions as this is my first encounter with AMD territory.
I just plugged and play and left all Bios settings in auto except enabling XMP so the ram runs at 3200mhz, is this ok?
I ask because i noticed on the bios and in ryzen master that the vcore is pretty high, 1.40something volts, I can’t remember now because I’m nothing there. All the settings are at auto so I don’t know if it’s normal or what. Also what kind of temperatures should it be getting with the stock cooler? i remember seeing 40-50 during idle and in between installations of initial drivers etc. I can resit the stock cooler and change the paste with some Arctic Ceramique 2 I have. Any tips or recommendations would be greatly appreciated.
Thanks for looking
Cheers
Intel Devil's Canyon Owners Club
AC
(12 items)
i7 4790K @ 4.7GHz
Asus Z97-A
EVGA RTX 2080 Super FTW3 ULTRA
Gskill Sniper Series
HP EX920 SSD
Plextor PCIE SSD
Seagate
WD
OCZ Gold 850
Cryorig R1 Ultimate
Corsair Carbide 500R
Gigabyte Aorus AD27QD
lokito50 is offline
post #2 of 15 (permalink) Old 10-28-2019, 11:03 PM
eBombzor's Avatar
Rep: 42 (Unique: 38)
Yes that speed is good. Make sure to run the FLCK at 1600 to match the memory.
That voltage is normal. My board does the same thing. According to AMD Robert, 0.2 - 1.5 are normal voltage ranges for Zen 2. Under heavy load you shouldn't be anywhere near 1.4 though. Also don't use Ryzen Master to see voltages. CPU-z is much more accurate. I believe HWInfo is good too but the AMD community rep said CPU-z is best.
Idle temps are normal. Make sure to update the BIOS as the latest as the latest AGESA revisions relax some of the boost behavior.
3600x | IF @1866 | PBO disabled | SoC voltage offset: -0.05v (1.05v total) | Thermalright TSP 140
Micron Rev E 2x8GB @3733 CL16 1.35v | (FAST preset w/ GDM on) | BLS2K8G4D30AESBK
ASUS x470 Prime Pro w/ ABBA BIOS
EVGA RTX 2060
eBombzor is offline
post #3 of 15 (permalink) Old 10-29-2019, 07:51 AM - Thread Starter
lokito50's Avatar
Rep: 3 (Unique: 3)
Thanks for chiming in. Yes the first thing I did after installing windows was a BIOS flash to the latest version. I later installed previous versions while troubleshooting the system because the first SSD (HP EX920 1Tb) we got disappeared from the bios after a few restarts. We ended up returning it and getting the 512GB which happened to be in the compatibility list. Anyhow system was running good, but haven’t put it under any stress yet as he has a very old GPU (GTX 580) and wants to wait for a possible black friday sale, so the games now are too modern and don’t even support the drivers. Once I go by I’ll set the FLCK to 1600 then, so you don’t think I should clean the stock paste and add the ceramique 2?
Thanks again
AC
(12 items)
i7 4790K @ 4.7GHz
Asus Z97-A
HP EX920 SSD
Plextor PCIE SSD
Seagate
WD
OCZ Gold 850
Cryorig R1 Ultimate
lokito50 is offline
post #4 of 15 (permalink) Old 10-29-2019, 12:48 PM
eBombzor's Avatar
Nah I think the default paste is fine. You'll see temps jump wildly due to the nature of TSMC's 7nm so don't worry about it as long as the temps stay under 70 C during gaming.
EVGA RTX 2060
eBombzor is offline
post #5 of 15 (permalink) Old 10-29-2019, 01:13 PM
Ha-Nocri's Avatar
Rep: 110 (Unique: 71)
It sets FLCK to match RAM speed automatically, except if you exceed 3600 (1800 MHz). So there is really nothing to do.
I did set custom fan profiles for all fans in my case for near silent operation tho.
AMD
(11 items)
Ryzen r5 3600
MSI B450 Tomahawk MAX
Gigabyte 5700 XT Gaming OC (2070/940 MHz)
G-Skill TridentZ 16GB 3600MHz b-die (3800MHz CL16 1.375V)
Crucial BX100 250GB
Samsung 860 EVO 1TB
Seasonic Focus+ Gold 750W
Fractal Design Meshify C
ASUS MG279Q (1440p) + ASUS 22''
Mouse
Logitech G502
Audio
Kingston HyperX Cloud II
Ha-Nocri is offline
post #6 of 15 (permalink) Old 10-29-2019, 07:21 PM - Thread Starter
lokito50's Avatar
Rep: 3 (Unique: 3)
ok cool, would be able to share those fan profiles?
Thanks
AC
(12 items)
i7 4790K @ 4.7GHz
Asus Z97-A
HP EX920 SSD
Plextor PCIE SSD
Seagate
WD
OCZ Gold 850
Cryorig R1 Ultimate
lokito50 is offline
post #7 of 15 (permalink) Old 11-01-2019, 03:36 PM - Thread Starter
lokito50's Avatar
Rep: 3 (Unique: 3)
I just ran Cinebench and the temp got up to almost 90C and the voltage hovered around 1.33. Is this acceptable?
AC
(12 items)
i7 4790K @ 4.7GHz
Asus Z97-A
HP EX920 SSD
Plextor PCIE SSD
Seagate
WD
OCZ Gold 850
Cryorig R1 Ultimate
lokito50 is offline
post #8 of 15 (permalink) Old 11-02-2019, 02:27 AM
Rep: 1 (Unique: 1)
With stock cooler, yes.
My PC
(9 items)
AMD Ryzen 5 3600
ASUS GeForce GTX 1070 OC
2x8GB Crucial Ballistix Sport LT 3200MHz CL16 DDR4
Crucial MX500 SSD
Seageta Barracuda 4TB
Corsair CX550M
Fractal Design Focus G
Operating System
Windows 10 Pro x64 1903
blue.dot is offline
post #9 of 15 (permalink) Old 11-02-2019, 02:47 AM
PC Enthusiast
VeritronX's Avatar
Rep: 30 (Unique: 30)
Adding exhaust fans to your case would help alot if you haven't done that yet, one in the back and two in the top. Also a $30 cooler would help quite a bit too.
VeritronX is offline
post #10 of 15 (permalink) Old 11-02-2019, 02:01 PM - Thread Starter
lokito50's Avatar
Rep: 3 (Unique: 3)
There is one in the rear already. Once my friend starts gaming hard I will suggest getting a couple of fans or maybe get a cooler down the road.
Cheers
AC
(12 items)
i7 4790K @ 4.7GHz
Asus Z97-A
HP EX920 SSD
Plextor PCIE SSD
Seagate
WD
OCZ Gold 850
Cryorig R1 Ultimate
lokito50 is offline
