Need help with 3900X & AIO - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 11-14-2019, 04:14 AM - Thread Starter
ursidae1's Avatar
Rep: 0
I just built the machine from my sig and the temps seem a bit high.
CPU is stock with PBO etc all on auto.
In a closed case 1 front 140mm brings cool air, one back 140mm takes hot out, the AIO is on the top 2x120 taking hot out, room temp 24C and using Thermal Grizzly Kryonaut.
Cinebench R20 all core temps hit 80C.
Prime95 temps only hit 70C weirdly enough.
Battlefield 5 1080p ultra never goes above 65C.
I am coming from 1700 with an AIO and these 3900X temps seem high for the Arctic Freezer II 240 which in all reviews performs like a champ.
Do these temps look normal or should I e worried about maybe installing the cooler wrong or something else?
Any input is much appreciated.
Many thanks!
Asus X570-P | Ryzen 9 3900X @ Stock | Arctic Freezer II 240 AIO | Corsair Vengeance LPX 2x8GB 3600 @ 3600 | Sapphire Pulse 5700 XT @ Stock | ADATA 8200 Pro 1TB | Seasonic 850W Gold | Be Quiet Pure Base 500 | Asus VG279 27" 1080p Freesync
ursidae1 is offline
post #2 of 8 (permalink) Old 11-14-2019, 04:27 AM
cssorkinman's Avatar
Rep: 494 (Unique: 276)
I don't think that's too bad for temps really.
Edit: disregard what i typed below... misunderstood your case airflow . Could try a similar experiment with your radiator fans though - would give you an idea of case pressures.
Might be an interesting experiment to unplug the front intake 140 and see what happens. Left without power, the direction it spins will tell you if you are hindering airflow through the radiator.
cssorkinman is offline
post #3 of 8 (permalink) Old 11-14-2019, 05:21 AM
CDub07's Avatar
Rep: 39 (Unique: 35)
My 3700X runs similar hot and it only has 1 CCD. Other than are you pushing the air through rad(Fans mounted on the rad and rad to top of case) or pulling the air through(fans mount on the top inside of case and rad on the inside.)
White Lightning
(12 items)
AMD Ryzen 9 3900X Processor
ASUS ROG Crosshair VI Hero (WI-FI AC)
XFX AMD Radeon™ RX 5700 XT 8GB GDDR6 THICC II
G.Skill Trident Z Neo Series 32GB (2 x 16GB) DDR4 3600MHz CL16-19-19-39
Western Digital WD BLACK SN750 NVMe 500GB
Optical Drive
LG WH16NS40 Super Multi Blue 16x Blu-ray Disc
Seasonic SS-660XP2 Platinum
Cooler Master MasterLiquid Lite ML120L RGB AIO CPU Liquid Cooler
Cooler Master MasterFan Pro 140 Air Flow RGB- 140mm High Air Flow RGB Case Fan, 3 In 1
Cooler Master Mastercase Pro 5
Operating System
Windows 10 Pro
AOC AGON AG273QCX 27" Curved Gaming Monitor
CDub07 is offline
post #4 of 8 (permalink) Old 11-14-2019, 05:27 AM
Overclocker
JackCY's Avatar
Rep: 352 (Unique: 250)
1 intake feeding 3 exhaust fans, I wonder what's wrong, nah I'm pretty sure, it's the user's fault.
Put the AIO as intake if you want it to perform better.
JackCY is offline
post #5 of 8 (permalink) Old 11-14-2019, 05:28 AM
The last VRM burner
Rep: 44 (Unique: 27)
LF II 240mm is a small unit that performs a bit worse than D15, your temps are very good. You'd fancy use a fan or two more on the front.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #6 of 8 (permalink) Old 11-14-2019, 06:02 AM - Thread Starter
ursidae1's Avatar
Rep: 0
Fans are pushing the hot air through the radiator.
ursidae1 is offline
post #7 of 8 (permalink) Old 11-14-2019, 08:02 AM - Thread Starter
ursidae1's Avatar
Rep: 0
Did play around with it some more and here are the results:
I turned on PBO instead of auto and turned on AutoOC and set it to 200mhz.
To my surprise, it really did bump up the speed by ~200mhz.
So I ran prime95 and it set all cores at 4.0 (prior to PBO and AutoOC they stayed at 3.8).
The CPU used 190W (I checked the wall with a meter not only hwinfo) and the CPU didn't go over 85C.
I think 85C max temp at 190W in prime95 is ok but let me know what you think.
BTW I use Ryzen High-performance power plan.
ursidae1 is offline
post #8 of 8 (permalink) Old 12-03-2019, 03:15 PM
bluestang's Avatar
Rep: 4 (Unique: 4)
Put both (front & rear) 140mm fans as intake and the AIO as exhaust. See if temps are better, they should be.
bluestang is offline
