AMD Threadripper 3000: 30% faster at 30% lower power - Page 2 - Overclock.net - An Overclocking Community
post #11 of 17 (permalink) Old 11-29-2019, 05:13 PM
FlanK3r's Avatar
Rep: 163 (Unique: 112)
That ares true man words
Ryzen Threadripper TBD ,-), Ryzen Threadripper 1950X, Ryzen 7 2700X, Ryzen 5 2400G, Ryzen 7 1800X, Ryzen 7 1700X, Ryzen 5 1500X, Ryzen 5 1600X, FX-8320E, FX-8370, FX-8370E, 2x FX-9590, 4x AMD FX-8350, 2x FX-8320, 2xFX-8300, 4xAMD FX-8150, AMD FX-8120 95W, AMD FX-8120 125W, AMD Phenom II x6 1100T BE, AMD Phenom II x6 1090T BE 4.3 GHz stable, AMD Phenom II x 980 BE, Phenom II x4 975 BE,Phenom II x4 970 BE, 2x Phenom II x4 965 BE C3, Phenom II x4 965 BE C2, Athlon 860K, Athlon 845, A10-7870K, 2xA10-7850K, 2x A10-7700K, A10-6800K, A10-6800B, A8-6600K, A10-5800K, A8-5600K, A10-3870K, A8-3850, Athlon 5150 Kabini,Intel core i9-7900X, Intel core i7-6950X, Intel core i7-5960X, core i7-3930K, i7-980X,3x Intel core i7-8700K, i7-7700K,i3-7350K, 2x i7-6700K, i5-6600K, i7-4770K, i7-3770K, i7-2600K
AMD AIR cooling challenge Cinebench R10
FlanK3r is offline
post #12 of 17 (permalink) Old 11-29-2019, 05:42 PM
Invalid Media
J7SC's Avatar
Rep: 40 (Unique: 20)
Quote: Originally Posted by elmor View Post
Maybe with 64C
Will be great to watch you (again) with LN2, this time w/ 64c...also, there's that chap who does the Elmorlabs I2c_super (x14+++* infinity / 7nm x 8 ) Oh, wait...
J7SC is online now
post #13 of 17 (permalink) Old 11-30-2019, 12:20 AM
Hwgeek's Avatar
Rep: 14 (Unique: 12)
OMG 3990X under LN2.... We gonna need new Benchmarks to stress it :-).
I see same Max Clock on 3950X/3970X in CB with LN2 WR's, so looks like that even the 3990X could do over 5Ghz... OMG the scores gonna be Epyc!
Hwgeek is offline
post #14 of 17 (permalink) Old 12-01-2019, 05:07 AM
Tyrael's Avatar
Rep: 2 (Unique: 2)
Any AMD Ryzen Threadripper 3xxx owner here? Maybe someone can answer me my question Is it possible to dissable cores in the bios and only enable them if you need them for your workloads? The idle watt usage is very high in my opinion.
Be Quiet Dark Base Pro 900 - AMD Ryzen 1800x - AData XPG Z1 64 GB DDR4 - XFX RX Vega 56
ASRock Fatal1ty X370 Professional Gaming - Samsung NVM 960 Pro- Seasonic 760w Platinum
NZXT x62 Kraken - Pioneer BD-RW - Corsair K95 RGB - Logitech G700 - Evoluent Vertical Mouse
Tyrael is offline
post #15 of 17 (permalink) Old 12-01-2019, 05:59 PM
Rep: 0
Having found a 3960X locally, I am putting together a system. AMD3960X, Liquitech TR4 II 360 AIO cooler(covers full surface area of Die), Aorus 1TB NVMe Gen4 SSD, Ballistix 4X8GB DDR4000 memory on an Asrock Taichi motherboard. Concerned about memory timing. Does it make sense to reduce memory clock to 3600(the 4000 chips were only fast ones in stock in a 4X8GB kit)? Waiting for Fractal Design Meshify Case from Newegg which was sent by slow truck across country even though I paid for 2nd day delivery so I haven't been able to start assembly yet.
Zver1 is offline
post #16 of 17 (permalink) Old 12-06-2019, 11:37 AM
Rep: 0
I have not played around with it much yet but I believe Ryzen Master will allow you to disable cores (Available from AMD overclocking utility) This can be useful if a game or other app can not use all cores. You can disable cores to spread heat dissipation more widely and overclock a little faster on remaining cores. This is also an advantage of the 3960 vs the 3970: fewer cores means power budget per core goes up(higher clock possible and turbo modr sustained longer).
Zver1 is offline
post #17 of 17 (permalink) Old 12-07-2019, 08:47 AM - Thread Starter
elmor's Avatar
Rep: 344 (Unique: 154)
How high is your idle power consumption and where do you measure? You can disable cores in BIOS, but not on-the-fly in the OS.
elmor is offline
