AMD Threadripper 3000: 30% faster at 30% lower power - Page 3 - Overclock.net - An Overclocking Community
post #21 of 30 (permalink) Old 03-05-2020, 01:45 AM
coccosoids's Avatar
Rep: 3 (Unique: 2)
@elmor : hey, good info here, also in the 10980xe review you did. Specifically because you tested both platforms and you got a feel for them, X299 and TRX40, I want to ask you this question: if you were to advise someone on which platform to build his workstation (this is for 3d animation, rendering, compositing) what would platform would you advise him to pick -X299 or TRX40?
rigTest
(8 items)
intel 10940x
Gigabyte X299X Aorus Master Rev1
nVidia GTX 1070
Predator 16x4GB 3000Mhz CL15
Samsung 970 Evo Plus
Corsair HX850i 850W
Custom EK Loop, 360 slim rad
Operating System
Win 10 Pro
coccosoids is offline
post #22 of 30 (permalink) Old 03-08-2020, 03:13 AM - Thread Starter
elmor's Avatar
Rep: 354 (Unique: 158)
I don't really use these platforms for productivity, I just like to test the new hardware and see how they perform in terms of overclocking/power/thermals. If I were to give some general advice, it would come down to:
- Does your workload benefit from AVX512 support?
Go for 10980XE.
- Do you benefit from PCIE 4.0 support or additional PCI-E lanes?
Go for Threadripper.
- How does your workload scale with the additional threads?
If it scales well enough, go for whichever Threadripper CPU you can afford. If you benefit from single threaded performance, go with 10980XE.
- Do you plan to overclock?
The 10980XE benefits more from overclocking and X299 is an easier platform to tune. Keep in mind both are hard to cool when pushed to the edge (500W+ CPU only power consumption). Cinebench R20 Mult-Threaded score increase when overclocked: 3970X = +19%, 10980XE = +45%.
- How important is platform reliability?
Intel has a better track record when it comes to general platform stability and BIOS support. X299 is also a very mature platform at this point. AMD at launch is usually a mess with patches and fixes. It's gotten better but they're still behind in this regard.
- Do you want ECC memory support?
If you need ECC memory support then Threadripper supports it, while you'd need to go the Xeon route with Intel.
- What's your budget?
If the above criteria are not deciders for you, in general I'd say below 1000 USD budget for the CPU, I'd go with 10980XE. Above that your only choice is really the Threadripper. It's worth considering X299 motherboards are available at much lower prices than TRX40.
elmor is offline
post #23 of 30 (permalink) Old 03-21-2020, 02:49 AM - Thread Starter
elmor's Avatar
https://www.crowd-render.com/post/sh...ing-in-blender
elmor is offline
post #24 of 30 (permalink) Old 05-14-2020, 01:47 PM
Peacemaker
RichardNixon's Avatar
Rep: 0
Thrilled to find a TR discussion thread. I'm surprised there isn't more momentum behind it. Awesome job, OP.
I'm finally building my first new system in 6+ years and my first transition to AMD. I'm doing a lot of virtualization heavy development work from home but also gaming during compilation and standups. Eagerly waiting for my 3970x to arrive.
Coming from the 2015 Intel scene I'm ready to overclock the **** out of everything and I'm slowly learning that AMD really isn't into the CPU overclocking too much. Is there an updated guide I can run through to catch me up on the important settings when dealing with Ryzen and specifically the TR line? I'm going to be running a custom loop and I like to aim for the highest OC I can run on a daily basis - no record setting here but a long-term stable OC to pull every cent I can out of this stupidly bad financial choice. I've found all the relevant info on the membench tool and general ddr4 settings so I'm looking for info on OCing the chip itself and anything that wouldn't be already tweaked from my ******* around with the memory settings.
2020 Anustart
(8 items)
Threadripper 3970x
Asus ROG Zenith II Extreme
Galax 2080ti HOF
G.skill Trident Z Neo
Corsair MP600 pcie4
Corsair AX1600i
EKWB Custom Loop - Monoblock + GPU
Thermaltake Core P5
6700k
MSI Gaming Z170A XPower Gaming Titanium
ASUS 980 Ti
G.Skill Tridentz
EK + Monsoon Custom Loop
Thermaltake P5
Operating System
Win10
Acer Predator X34
RichardNixon is offline
post #25 of 30 (permalink) Old 05-20-2020, 09:34 AM
knightriot's Avatar
Rep: 6 (Unique: 5)
got my new 3970x rig, finding a TR discussion thread too
Knight RIG
(12 items)
Threadripper 3970X
TRX40 aorus xtreme
RTX 2080TI
Corsair
SamSung EVO
SamSung PM951
SamSung 970 EVO Plus
Seasonic Gold+
XSPC RAYSTORM NEO
HeatKiller IV RTX 2080Ti
CaseLabs S8
LG 3495KWU
knightriot is offline
post #26 of 30 (permalink) Old 05-23-2020, 06:05 AM
Martin778's Avatar
Rep: 17 (Unique: 17)
So little love for the Treadripper 3000 series though, almost nonexistent when compared to 3900/3950X. I know lots of folks buy X299 HEDT as 'toys' but Threadripper still has a long way to go before it also becomes a rich kid's toy too
I found manual OC to be a waste of time on my rig, just enabled PBO and let it do it's thing, with 3733 MHz RAM and 1:1 IF I'm just a tiny bit off hitting 14k in R20 but the ambient temp is getting too high to reach maximum boosts.
Threadripper 3960X @ broken PBO EDC=40 | Aorus TRX40 Xtreme | Enermax Liqtech II 360 TR4 + EK Clear flush + 3x Noctua A12x25 | 4x8GB G.Skill TridentZ Neo 3800C14 @ 3733 CL14-15-15-30 CR1 | EVGA Kingpin 2080Ti @ 2115MHz / 8250MHz + Noctua A12-25 | 4x1TB 970 PRO raid0 | Corsair MP600 2TB | Seasonic Prime Platinum 1300W | In Win D-Frame 2.0 Gold | ASUS PG349Q
Martin778 is offline
post #27 of 30 (permalink) Old 05-23-2020, 06:12 AM
Overclocker in training
ThrashZone's Avatar
Rep: 179 (Unique: 107)
Hi,
Price jump didn't make much sense for just 3960x 24 core from 3950x 16 core so I passed
I was all ready but let down when I saw the price double but core count didn't double.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
10900k batch # X016E724
z490 ASUS Maximus XII Apex
EVGA 1080ti FTW3
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
ThrashZone is offline
post #28 of 30 (permalink) Old 05-23-2020, 06:15 AM
Martin778's Avatar
That's true, overall the price jump to TRX40 is quite extreme and other costs (think RAM) would be double. TRX40 boards aren't that much more expensive but it's all in the CPU...
X299 on the other hand is now cheaper than LGA1200 it seems but I was never fond of the CPU's for this socket.
post #29 of 30 (permalink) Old 05-23-2020, 06:23 AM
ThrashZone's Avatar
Hi,
I have no idea where 1200 socket is going besides the frying pan lol but i was all ready for tr4
Maybe next time on 4k amd and what ever big dogs come with it tr5 ? I'm in no hurry really just waiting for 30 series nvidia to show up
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
EVGA 1080ti FTW3
EVGA 1000P2
Corsair 450D
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
post #30 of 30 (permalink) Old 05-23-2020, 07:08 AM
Martin778's Avatar
Also hyped for the 3080Ti....can already tell you how it's going to look like for me:
1. 3080Ti comes out, the launch day models are mostly pretty crappy, me wants 3080Ti anyways so I buy something crappy like the Windforce
2. A model with better cooling comes out, like the Lighting-Z, which I buy.
3. Couple of months later the Kingpin or other bonkers model comes out, I sell the L-Z and buy that one.
4. Repeat for 4080Ti series
Z490 and AMD B550 boards are taking a very weird route, even the lower end Z490's are approaching €200+ and some B550's look better specc'ed than X570...
