AMD Threadripper 3000: 30% faster at 30% lower power - Overclock.net - An Overclocking Community
post #1 of 30 (permalink) Old 11-25-2019, 06:42 AM - Thread Starter
elmor's Avatar
Rep: 354 (Unique: 158)
AMD Zen 2 in every segment
After releasing Zen 2 for mainstream desktop as Ryzen 3000 and for server as EPYC 7002, AMD is following up with a 7 nm update to the Threadripper platform. While desktop users are mostly concerned with performance over power, improvements to energy efficiency usually allows for higher overall performance. The release of second generation Threadripper processors in 2018 increased the peak core count from 16 to 32 resulting in escalated power consumption. This article takes a look at how Zen 2’s improved energy efficiency translates to raw performance for high-end desktops.
Platform changes
  • Unified memory architecture using a 12 nm I/O-die coupled with up to eight 7 nm Zen 2 chiplets
  • Increased fabric bandwidth and doubled L3 cache
  • Support for higher memory speeds and asynchronous memory/fabric clock domains
  • 3960X (24 core) and 3970X (32 cores) at launch, with up to 64 cores coming later
  • CPU PCI-E links upgraded to Gen 4
  • CPU PCI-E lanes from 60 (2×16, 2×8, 3×4) to 56 (2×16, 2×8, 2×4)
  • New TRX40 chipset (same as X570)
  • CPU-chipset link upgraded from x4 Gen 3 to x8 Gen 4 (bandwidth from 3.94 GB/s to 15.75 GB/s)
  • Four USB 3.2 Gen 2 (previously eight USB 3.1 Gen 1)
While the new AM4 and SP3 processors drop into existing boards with a firmware update (sacrificing PCI-E 4.0 capability), backwards compatibility is broken between TR4 and the new TRX4 socket. The physical socket is the same LGA4094 model used for both EPYC and previous Threadripper parts. The CPU-chipset link is increased from four to eight lanes through a re-purposed PCI-E x4 port, which connects to the TRX40 chipset.
Test Setup
  • AMD Threadripper “3970X” ES (32 cores, 4.4 GHz Boost, 280W TDP) / 2990WX (32 cores, 4.2 GHz Boost, 250W TDP)
  • ASUS ROG Zenith II Extreme (BIOS 0042) / Zenith Extreme (BIOS 2001)
  • G.SKILL F4-4000C18Q-32GTZKW (4x8GB)
  • Custom water cooling (Rajintek CWB-TR4 RBW + Bykski B-RD360-TK60)
  • Windows 10 1903, AMD Chipset Driver 1.9.27.1033, Ryzen High Performance power plan
The Threadripper 3000 processor used in this test is an engineering sample with slightly different specifications compared to a retail 3970X. Notably the boost and base clocks are 100 MHz lower, which means stock performance is lower than a final part.
Method
Any benchmark results are the average of three runs. In the single threaded tests, the thread affinity for the benchmark was manually set to the highest ranked core. HWInfo 6.14 was used to record the monitoring information during the run. The average frequency was measured using the “Effective Clock” item. The average power was measured directly from the VRM controller and reports the CPU Core power or SOC power only. Load-Line Calibration was set to Level 5 for the overclocked results.
Results and Analysis
Memory Performance
The new memory architecture coupled with increased fabric speed shows major improvements in memory bandwidth at the same settings. At 3200 MT/s the read bandwidth is 13.4 GB/s higher. Since all cores now have to access memory through the I/O-die, there is a best case latency penalty. At these settings, latency is increased from 66.4 ns to 84.2 ns.
As with regular desktop Ryzen 3000 processors, higher memory speeds are possible with fabric and memory independently clocked. In this case, the system was capable of 4400 MT/s while locking fabric speed to 1800 MHz.
Stock Performance
Comparing the multi-threaded stock performance reveals just how much more efficient Zen 2 is compared to the last generation. At the same power consumption the new processor is 39% faster while maintaining 14% higher clock speeds and reports 14 °C lower temperatures. This is in one benchmark, but arguably other applications may benefit more due to the simplified memory architecture being less dependent on software optimization.
Moving over to the single-threaded test shows a performance increase of 22% at 7% higher frequency. The reported temperatures are similar across the single- and multi-threaded tests. Probably the reported temperature is considering peaks from several sensors and a single core is allowed to use more power when others are idle.
Overclocked Performance
Both processors were overclocked to a point where they could consistently pass the benchmark, which resulted in 4.2 GHz on the 2990WX and 4.4 GHz on the 3970X. In this all-out configuration, the 3970X ES is 31% faster while consuming 30% less power. The reported temperature is also significantly lower.
In heavier tests, the frequencies had to be dropped. The 2990WX could pass for at least 10 minutes in Prime 95 at 3.9 GHz. The 3970X ES passed at 4.3 GHz without AVX and 4.2 GHz when enabled. When allowing AVX instructions the 2990WX power consumption drops, because it takes two clock cycles to executes 256-bit AVX instructions. The 3970X ES can execute them in a single cycle, resulting in higher power consumption even with reduced frequency and voltage.
SOC Power Consumption
At default SOC voltage for 3200 MT/s memory speed (1.05 V in both cases) there are substantial power reductions from the chiplet design. Idle power consumption drops by 56% and in MemTest64 it’s 49% lower.
Original article: https://www.elmorlabs.com/index.php/...0-lower-power/
Feel free to ask if you have questions or want to see any specific test.
elmor is online now
post #2 of 30 (permalink) Old 11-25-2019, 06:56 AM
X5O!P%@AP[4\PZX54(P^)7CC)
rush2049's Avatar
Rep: 46 (Unique: 32)
Wow, thanks for all the time put in on this.
I really appreciate the memory bandwidth and latency tests. As well as the SOC notes.
--Intentionally Left Blank--
Glas
(10 items)
Threadripper 3970x
Asus Zenith Extreme II
Nvidia RTX 2080 ti
G.SKILL TridentZ Series DDR4 3600 Model F4-3600C15D
Corsair AX1600i
Custom Watercooling
Thermaltake Level 20 XT
Operating System
Microsoft Windows 10 Pro
Acer XR382CQK bmijqphuzx
Loctek D7H - Heavy Duty Gas Spring Single LCD Arm Stand Monitor Desk Mount
rush2049 is offline
post #3 of 30 (permalink) Old 11-28-2019, 06:44 AM
FlanK3r's Avatar
Rep: 163 (Unique: 112)
thank you for article. It is yours sample? Will be gonna back with some LN2 results?
I was thinking to buy this monster, but my flat is higher priority Maybe next generation and depends on my situation in late next year. But I am impressed how awesome eprformance and effectivity those CPUs have. Comeback of AMD with old glory! BTw, so current TRX40 boards can handle also new ROMEs CPUs?
Ryzen Threadripper TBD ,-), Ryzen Threadripper 1950X, Ryzen 7 2700X, Ryzen 5 2400G, Ryzen 7 1800X, Ryzen 7 1700X, Ryzen 5 1500X, Ryzen 5 1600X, FX-8320E, FX-8370, FX-8370E, 2x FX-9590, 4x AMD FX-8350, 2x FX-8320, 2xFX-8300, 4xAMD FX-8150, AMD FX-8120 95W, AMD FX-8120 125W, AMD Phenom II x6 1100T BE, AMD Phenom II x6 1090T BE 4.3 GHz stable, AMD Phenom II x 980 BE, Phenom II x4 975 BE,Phenom II x4 970 BE, 2x Phenom II x4 965 BE C3, Phenom II x4 965 BE C2, Athlon 860K, Athlon 845, A10-7870K, 2xA10-7850K, 2x A10-7700K, A10-6800K, A10-6800B, A8-6600K, A10-5800K, A8-5600K, A10-3870K, A8-3850, Athlon 5150 Kabini,Intel core i9-7900X, Intel core i7-6950X, Intel core i7-5960X, core i7-3930K, i7-980X,3x Intel core i7-8700K, i7-7700K,i3-7350K, 2x i7-6700K, i5-6600K, i7-4770K, i7-3770K, i7-2600K
AMD AIR cooling challenge Cinebench R10
FlanK3r is offline
post #4 of 30 (permalink) Old 11-28-2019, 06:51 AM
What goes here?
speed_demon's Avatar
Rep: 142 (Unique: 101)
Looking mighty good!
Thank you for the in depth look at these new chips. You may not hear it often but I and others in the community do appreciate what you are doing for us.
I am debating picking up a 3960X in the near future with a TRX40 mobo & 32gb DDR4, then waiting until DDR5 & 4000 series is released to buy up more cheap ram & a cheap 3990X. Would make for a fairly affordable & high powered home server after I upgrade down the line and my old hardware is relegated to the server closet for Plex & home surveillance. Certainly much cheaper than a comparable Dell R740 would cost. I bet it'd have lower power bills too..
Ryzen 3900X
MSI X470 Gaming Plus
MSI R9 390 8GB
16GB DDR4-3000
120GB HP M700 SSD
Samsung Spintpoint M9T 2TB
Seagate Barracuda 500GB
Corsair HX1200 (2017)
Thermalright True Spirit 140
Fractal Define S
Operating System
Windows 10 LTSC
Keyboard
Alienware W/Cherry MX Switches
Mouse
Logitech G5
speed_demon is offline
post #5 of 30 (permalink) Old 11-28-2019, 06:54 AM
Hardware Princess
Hydroplane's Avatar
Rep: 38 (Unique: 30)
Good test results lord moffle
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #6 of 30 (permalink) Old 11-28-2019, 06:58 AM
Forsaken1's Avatar
Rep: 12 (Unique: 12)
Thanks for review.
Forsaken1 is offline
post #7 of 30 (permalink) Old 11-28-2019, 09:00 PM - Thread Starter
elmor's Avatar
Thanks, I enjoy doing these tests too. Takes a bit too much time away from other things I should be doing instead though. The numbers here should mostly interest those looking to go from TR4 to TRX4. Will certainly be interesting to see 64C on a "consumer" platform in the future.
I don't plan on doing LN2 results this time around, there are others doing a great job on Hwbot already.
elmor is online now
post #8 of 30 (permalink) Old 11-29-2019, 04:47 AM
Hale59's Avatar
Rep: 25 (Unique: 14)
Quick Reference Guide
Name:	EKimtFOUYAE0wX6.png large.png
Hale59 is offline
post #9 of 30 (permalink) Old 11-29-2019, 07:24 AM
VPII's Avatar
Rep: 16 (Unique: 11)
My friend, I know you want to LN2 it is in your blood, so get on to it and show us some results.
VPII is offline
post #10 of 30 (permalink) Old 11-29-2019, 07:27 AM - Thread Starter
elmor's Avatar
Maybe with 64C
elmor is online now
