Need advice about PC Build for audio production - Page 2 - Overclock.net - An Overclocking Community
post #11 of 65 (permalink) Old 01-02-2020, 06:20 PM
Gamer
dlewbell's Avatar
Rep: 57 (Unique: 50)
One thing to consider is what audio interface you plan to use. My wife plays cello & does recording as a hobby. We bought the Universal Audio Arrow, which requires a thunderbolt port. I already had an i5-6600K that I was donating to the cause, so those 2 factors combined with availability at the time chose the motherboard for us. My wife still only does the most basic editing, so I don't know how demanding more serious editing work can get, but she's able to run the system fanless without issue, which works out well for noise concerns. Here's the full build if you'd like to see for reference: https://pcpartpicker.com/list/qm8Nq4
TV Gaming PC
Alienware 17R5
(5 items)
i7-8700K
MSI Z370 Gaming Pro Carbon
EVGA GeForce GTX 1070 FTW
GSkill Ripjaws V 16GB (2x8GB) DDR4-3200
Samsung 950 Pro 512GB M.2 2280
Seagate Barracuda 2TB 3.5" 7200RPM
Optical Drive
LG WH14NS40 Blu-Ray Writer
EVGA SuperNOVA 750 G2
Phanteks PH-TC14PE_BL
Enthoo Luxe
Operating System
Windows 10 Pro
Visio E601i-A3
Keyboard
Logitech K400
i7-8750H
GeForce GTX 1070
Samsung 860 EVO 1TB
Operating System
Windows 10
1920x1080 G-Sync
dlewbell is offline
post #12 of 65 (permalink) Old 01-02-2020, 06:20 PM
AllenG's Avatar
Rep: 28 (Unique: 24)
LOL. Commander Data (Turtle Rig) at it again. Good read below.
https://www.overclock.net/forum/297-...roduction.html
Oreonutz knows what he's talking about and doing, he will be of the most help.
i7 990x @ 4.69GHz
Asus Rampage III Extreme
EVGA GTX780 FTW ACX 2.0 3GB
12 GB Samsung DDR3L @ 2100Mhz
Samsung 840 Pro 256gb Raid0 On LSI 9207
Samsung 840 Pro 512gb
PSN across 10Gb Fiber
Optical Drive
Sony Optiarc DVDRW
Corsair 850HX
DTek Fuzion V2 CPU Block w/ Quad Insert
Laing D5 pump {2MT}
2 x Black Ice Pro 240 Radiators {2MT}
EK Full Cover RIIIE Nickel/Acetal Block
Lian Li PC-A10B
Operating System
Windows 8.1 Enterprise X64
Monoprice 27in WQHD IPS
Keyboard
Das Keyboard Model S
Audio
Creative X-Fi Fatal1ty Platinum
Other
LSI 9207-8i SAS6G Raid Controller
Other
Intel XF SR 10Gb Fiber Adapter
Pentium G3258 @ 4.5GHZ
MSI PC Mate Z97
EVGA GTX 970 SC ACX2.0 4GB
8GB Mushkin Blackline DDR3 2133
256 GB Plextor M6 SSD
WD Black 640GB Raid0
Optical Drive
Sony Optiarc DVDRW
Seasonic S12II 620W
Corsair H50
Old Antec
Operating System
Windows 10 Enterprise x64
Changhong 42in 1080p TV
Keyboard
HP Wireless Keyboard & Thumb tracker
Mouse
Audio
Creative Sound Blaster X-Fi Fatality
Intel Xeon x5687 @ 3.6GHZ
Supermicro X8DT6-F
EVGA GT630 2GB
EVGA GT630 1GB
24GB Hynix DDR3 1333 2R-X4 ECC
Samsung 850 Evo 500GB
Seasonic S12II 620W
Intel LGA1366 HDX Cooler for Extreme Edition CPU
CM Stacker
Operating System
Windows 7 Pro x64
Qnix QX2410R DP
AllenG is offline
post #13 of 65 (permalink) Old 01-02-2020, 06:24 PM
Tech Enthusiast
oreonutz's Avatar
Rep: 66 (Unique: 45)
Quote: Originally Posted by UltraMega View Post
The short answer is, you don't need anything special for audio on PC. If you need some specific audio ports you will probably want to get a sound card, but for simply making audio files with some kind of audio program will work fine on just about any PC. Audio tasks are really simple for a PC.
Yup. I second that. If you know your Editing Program has special input output needs, then just make sure the platform you are choosing has enough PCIE Lanes to accomidate. In some cases the Intel or AMD HEDT Platform may be a better option for plugging in multiple PCIE Cards, but other than that, any Current Platform you build will run the tasks quite nicely. Anyone else that says differently should post proof of issues. I currently am running a 3950x Build in my Home Lab, where I do all of my mixing on pro tools these days (which admittidly is NO WHERE NEAR the amount of mixing as I used to do, but I literally just finished up a mix on my New Rig on December 30th, and it handled it perfectly, before then was a session on a 3900x I custom built for a local studio, and that went well, and before that were small projects I did on my 3900x Rig here at my house, and that also went well (Outside of Protools crashing Constantly, but I solved that by reinstalling Protools, ended up being an issue with a specific build of the software in the end, so again just use new versions that have released since the release of Ryzen 3000, and if you choose AMD you will be fine. The only place I would caution you is if you are using a specific Software or Plugin that has known issues with Ryzen 3000 that have yet to be solved. As of right now I am not aware of one, but still just search the plugins you rely on and Ryzen 3000 in google just to be sure.)
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #14 of 65 (permalink) Old 01-02-2020, 06:26 PM
Tech Enthusiast
oreonutz's Avatar
Definitely a helpful post here, this is 100 percent something to look out for, You can get Thunderbolt on AMD, but only on certain ASRock boards, so just check compatibility for the interface you plan on using. I am curious as to what interface you are planning to use...
Appreciate you man!
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #15 of 65 (permalink) Old 01-02-2020, 06:28 PM
LTSC Consiglieri
skupples's Avatar
Rep: 656 (Unique: 350)
didn't you hear? audio work stations weren't even possible until intel released their latest big boy enthusiast chip!
suffice to say, if you're gonna spend that kinda money, it doesn't need to be on the tower, but what plugs into the tower -.-
OP - unless the money doesn't matter, take nothing said here on face value aside from the fact you don't need $1,000 CPUs to do the job.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is online now
post #16 of 65 (permalink) Old 01-02-2020, 06:30 PM
Graphics Junkie
UltraMega's Avatar
Rep: 47 (Unique: 42)
Sound cards usually only use the 1X PCI slot. Any PC is going to have more than enough PCI lanes for a sounds card. No need worry about this at all.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #17 of 65 (permalink) Old 01-02-2020, 06:32 PM
AllenG's Avatar
sometimes to get the amount of channels you need, you have to stack interfaces... comes down to how many slots are available. with the new-age pci-e splits, you can stack more cards on an hedt platform using breakouts. Most normal users are going to be using usb devices anyways, running into problems when they want it to run on the same root hub as their logitech gaming controller. LOL
This is why real equipment exists for real production though.
i7 990x @ 4.69GHz
Optical Drive
Sony Optiarc DVDRW
Corsair 850HX
Laing D5 pump {2MT}
Lian Li PC-A10B
Operating System
Keyboard
Audio
Other
Other
MSI PC Mate Z97
Optical Drive
Sony Optiarc DVDRW
Seasonic S12II 620W
Corsair H50
Old Antec
Operating System
Keyboard
Mouse
Audio
Supermicro X8DT6-F
EVGA GT630 2GB
EVGA GT630 1GB
Seasonic S12II 620W
CM Stacker
Operating System
Windows 7 Pro x64
Qnix QX2410R DP
AllenG is offline
post #18 of 65 (permalink) Old 01-02-2020, 06:35 PM
Graphics Junkie
UltraMega's Avatar
This is clearly well above the scope of the OP. If anything you are just confusing the issue.
OP, dont worry about PCI lanes, it's not an issue.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
Audio
Sound Blaster z
post #19 of 65 (permalink) Old 01-02-2020, 06:37 PM
Tech Enthusiast
oreonutz's Avatar
Yeah, thats for Sound Cards. I am talking about DAE Interface cards. Depending on the Card that can go up to x16. It depends on the Card and the Interface, thats why I said just to check. For most Uses though, the Mainstream platforms will work nicely.
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #20 of 65 (permalink) Old 01-02-2020, 06:40 PM
AllenG's Avatar
UltraMega, OP still hasn't said what interface(s) they have chosen. May be relevant, may not. Just as your saying to not worry about it.
i7 990x @ 4.69GHz
Optical Drive
Sony Optiarc DVDRW
Corsair 850HX
Laing D5 pump {2MT}
Lian Li PC-A10B
Operating System
Keyboard
Audio
Other
Other
MSI PC Mate Z97
Optical Drive
Sony Optiarc DVDRW
Seasonic S12II 620W
Corsair H50
Old Antec
Operating System
Keyboard
Mouse
Audio
Supermicro X8DT6-F
EVGA GT630 2GB
EVGA GT630 1GB
Seasonic S12II 620W
CM Stacker
Operating System
Windows 7 Pro x64
Qnix QX2410R DP
AllenG is offline
