Need advice about PC Build for audio production - Overclock.net - An Overclocking Community
post #1 of 65 (permalink) Old 01-02-2020, 05:11 PM - Thread Starter
Rep: 0
Hi, I'm a composer and I usually work with orchestral samples. I want to upgrade my pc and I've been reading during these past days but I'm not sure about some parts or if there are any other better options. I hope it is okay to ask this kind of questions here.
This is the build I've been thinking:
https://es.pcpartpicker.com/list/2K2g3t
There are a few things I've been considering about this build.
About the motherboard, I thought about this one because of the cashback promotion of 50€, but I may get one b450 instead, maybe tomahawk.
The CPU Cooler I don't know if I'll need it, but if the one with 3900x is very noisy I've considered this one.
About the memory, I don't know if going for 3600 cl 16 at 188€ is worth for me rather than getting this pair. It would be better but I don't know if the improvement is worth the 44€ difference.
I don't know a lot about the case, but I've read good things about it, so I suppose it wouldn't give me any problems.
I'm also in doubt about the external storage, I bought it because it was a very good deal and I think it's possible to shuck, but that might be too much storage for me and I can return it and use the money improving other parts, but it might be a good idea having at least one external storage for back-up.
If you have any advice or recommendation, it would be very appreciated.
Yagia is offline
post #2 of 65 (permalink) Old 01-02-2020, 05:15 PM
LTSC Consiglieri
skupples's Avatar
Rep: 651 (Unique: 349)
I look forward to some educated answers. Last time I messed with making music it was just plugging an M-Box into a decent PC
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #3 of 65 (permalink) Old 01-02-2020, 05:34 PM
Tech Enthusiast
oreonutz's Avatar
Rep: 66 (Unique: 45)
So I see nothing wrong at all with this build. The only thing I may change is the case. There is a P400A that will get you better airflow, which in turn will allow you to turn your fans down and get it quieter, while keeping your components cooler. You definitely want another cooler (other than the Stock I mean) if Noise is a concern, the one you picked out is perfect.
Everything else in your PC Part Picker list is perfect. The only thing else I would consider is some silent fans, either some Noctua's, Be Quiet Silent Wings, or Corsair ML120/ML140s. People will argue until they are red in the face about which of these is better, but in my experience any of the ones I mentioned will allow you to get a nice and silent build while remaining damn near perfectly quiet, which of course is a plus for a machine that is in the same room as you while you are making music.
I ran a studio here in town for almost 5 years, and still make custom builds for studio clients in town. These days we are doing custom water cooling builds, but to be honest you can achieve the same level of cooling (almost) with air cooling, and as long as you tune your fans, you will be able to get your build silent. If you have any more specific questions, dont be afraid to ask, but I see nothing at all wrong with your picks, they will work perfectly.
BTW, what will be your DAE Interface?
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #4 of 65 (permalink) Old 01-02-2020, 05:34 PM
Tech Enthusiast
oreonutz's Avatar
LOL! Thats exactly how I started in this Industry in 2003. Got me an MBox, the original, and an AMD Athlon PC, and was off to the races. Oh how times have changed since then...
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #5 of 65 (permalink) Old 01-02-2020, 05:42 PM
Turtle Rig's Avatar
Rep: 6 (Unique: 6)
OOOOOOOOOHHHHHHHHH wait a minute tiger. DO NOT GET AMD if your going to run a DAW. It is known fact Ryzen latency with music production sux ballz. Ive known this forever. AMD cant handle VSTs and VSTi's and work at low latency doing so. You want a DAW Grab 64GB RAM and a Intel 9900k at minimum. I don't know how large your projects are but Im telling you now I have read in many places over the years how AMD sux at DAW. It is still that way with the release of Ryzen 3xxx series. A site talking about this specifically said if your gonna use a DAW get the 10980XE 64GB RAM and a nice audio interface external preferred or internal would work. Also grab a 500GB SSD as your project drive if your freezing synths and what not. Ovoid AMD at all costs my friend. Ive been producing music since 1997 so I know what Im talking about and Im not dissing AMD in any way. Simply put if your running a DAW like I said get Intel. End of story.
INTEL 10980XE @ NO STOCK
GIGABYTE X299X AORUS MASTER
GIGABYTE WF RTX 2080
CORSAIR DOMINATOR PLATINUM RGB @ 64GB 3200 CL16 QUAD CHANNEL B-DIE
CORSAIR MP510 960GB M.2 GEN 3 SAMSUNG 950 PRO M.2 500GB 850 PRO 500GB CRUCIAL M4 500GB LaCie EXTERNAL 2TB PORSCHE DESIGN & 500GB eSATA
CORSAIR AX1600i TITANIUM @ CORSAIR 330r BLACKOUT EDITION CASE
CORSAIR H115i PRO RGB @ NOCTUA NF-14's INTAKE NF-14 EXHAUST NF-P12
AOC 40" CURVED 4k LG 55" C9 OLED G-SYNC 120HZ
Keyboard
LOGITECH 915 LINEAR WIRELESS
Mouse
LOGITECH G PRO WIRELESS LIZZARD GRIP 3M TAPE
Mousepad
STEELSERIES SMALL
Audio
LOGITECH G935 WIRELESS SCARLETT 2i2 AUDIO INTERFACE KRK ROKITS 10" & SENNHEISER HD 650 & 4.5.0 BTNC SL GRAND 88 CAKEWALK BY BANDLAB
Turtle Rig is offline
post #6 of 65 (permalink) Old 01-02-2020, 05:47 PM
Tech Enthusiast
oreonutz's Avatar
LOL. This is more superstition.
For a Straight DAW Rig, where this is your top concern, and you just want it to work out of the box with no tweaking, the intel platform is set up well for this, just because they have been working with companies like AVID Since the early 2000's on perfecting their software on there platform.
That said, I just deployed 4 separate 3900x Bases systems in studios around town since the 3000 Series launch. These are mainly for Pro Tools Rigs, and they vastly outperformed the outgoing Intel 8700k systems they are replacing. The days of messed up latency based issues are long over. There were some teething with certain plugins, but they have all been worked out, just make sure to install the newest versions and you will be fine. That said, ESPECIALLY if you plan on Pirating audio plugins, you will have an easier time on Intel, but it is not quite as diar as some would want you to believe. Either Platform you choose will go nicely.
What are your main DAW Programs you plan on using?
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #7 of 65 (permalink) Old 01-02-2020, 05:48 PM
LTSC Consiglieri
skupples's Avatar
yep, it was quite easy for us to procure, being 2 miles from SweetWater (Indiana)
same era as well. High School band days. bwahaha, we got MAAD, NAND, DARE, and a few others to pay us for playing weekend school events n stuff. good times.
also folks, things like known facts are typically followed up with links, not more paragraphs of ramblings
skupples is offline
post #8 of 65 (permalink) Old 01-02-2020, 05:59 PM
Paradigm Shifter's Avatar
Rep: 252 (Unique: 201)
[citation needed]
Would be interested myself. I tinker around with Sonar, but I'm not even a talented amateur, let alone seasoned pro.
Paradigm Shifter is offline
post #9 of 65 (permalink) Old 01-02-2020, 06:05 PM
Graphics Junkie
UltraMega's Avatar
Rep: 46 (Unique: 41)
The short answer is, you don't need anything special for audio on PC. If you need some specific audio ports you will probably want to get a sound card, but for simply making audio files with some kind of audio program will work fine on just about any PC. Audio tasks are really simple for a PC.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #10 of 65 (permalink) Old 01-02-2020, 06:12 PM
Tech Enthusiast
oreonutz's Avatar
Quote: Originally Posted by Paradigm Shifter View Post
[citation needed]
Yeah this used to be a MUCH bigger deal then it is these days. I ran a pretty decently sized studio here in town for years. My Main Editing Rig used a AMD Phenom 2 6-Core, and I did indeed used to have issues, all of which I got around, and the truth was my Mac Rigs running Intel had just as many issues, they just tended to be different.
I just ran an entire session at one of the Studios I just upgraded to the 3900x Rig, had a 52 Track Session, using Plugins Galore and it just screamed through it. We ended up needing almost all 128GB of Ram in the System, but it handled it quite well. So these days are long behind us. When the 3000 Series first dropped there were rumbling of issues, and My very first 3900x upgrade did have them, but they ended up being Windows Based, once Windows Pushed an Update a few months back it solved all of our issues. So there are people who have problems who would blame them on AMD, and in some cases it might end up being AMDs fault, simply because they haven't put the same amount of resources into fixing code of these DAW programs to work with their architecture as intel as, but I have never came up across one that wasn't solvable with a little time.
Again, if that time is just something you don't have, and you need a new Rig up and running for a session in a day or 2, then Intel right now might be the better option, but if you have a session or 2 to work out the kinks (which to be honest you may need with an Intel Build anyway depending on your other hardware choices) then AMD is a valid option, and short of some new issue that arises that I am not yet aware of, where there is actual proof of a deal breaking issue, I wouldn't let overblown comments scare you.
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
