CPUZ and HWINFO report wrong voltages when using offset? - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 02-03-2020, 10:24 PM - Thread Starter
CoreyL4's Avatar
Rep: 2 (Unique: 2)
Does CPU-Z and HWINFO64 display the correct vcore when offset mode is enabled in bios?
I have offset mode, but they constantly give the same values without the vcore fluctuating like a normal offset.
Ryzen Master shows the vcore fluctuating so I was wondering if this is a known issue with the other softwares?
Rig 1: i7-5775c @4.1, MSI 1080ti Gaming X @2037/6102, MSI Z97 Gaming 5, Corsair Vengeance Pro 2400, Corsair AX860, Corsair H110i
Rig 2: i7-4790k @4.8, MSI 980ti Gaming X @1440/7800, ASUS Z97-A/USB 3.1, Corsair Vengeance Pro 1886, EVGA GS 850W, Corsair H105
CoreyL4 is offline
post #2 of 9 (permalink) Old 02-04-2020, 07:27 AM
AMD OVERLOCKER
rastaviper's Avatar
Rep: 2 (Unique: 2)
No such problem here with HWinfo64.
It's changing all the time as it should be.
I don;t use CPUZ for real time monitoring.
  • Ryzen 3600x @4490mhz v1.45, 2nd position at HWBOT
  • Gigabyte Aorus Elite x570
  • G-SkillLL F4-3200C15D-16GTZ Trident Z Series CL15 Bdies @3733 15-14-14-1T 1.39v
Offical Ryzen 5 3600x Owner!
rastaviper is offline
post #3 of 9 (permalink) Old 02-04-2020, 07:50 AM - Thread Starter
CoreyL4's Avatar
Rep: 2 (Unique: 2)
Yeah my voltage doesnt change in hwinfo when I have offset voltage enabled.
CoreyL4 is offline
post #4 of 9 (permalink) Old 02-04-2020, 08:01 AM
MishelLngelo's Avatar
Rep: 47 (Unique: 34)
It changers all the time on my MB. It only changes voltage in idle mode and when Power saving plan minimum CPU is 5% or less.
Asus Prime x470 Pro BIOS 5406 1004b
R7 3700x. CM Nepton 140XL
2 x Kingston HyperX KHX3600C17D4/8GX
Samsung 960 Evo 250GB
Asus strix 570 OC 4gb
MishelLngelo is offline
post #5 of 9 (permalink) Old 02-04-2020, 08:08 AM - Thread Starter
CoreyL4's Avatar
Rep: 2 (Unique: 2)
I have my offset to hit 1.32v, and during loads and idle it still shows 1.32v
CoreyL4 is offline
post #6 of 9 (permalink) Old 02-04-2020, 09:15 AM
AMD OVERLOCKER
rastaviper's Avatar
Rep: 2 (Unique: 2)
Which mobo do u have?
Are u sure offset is properly set in BIOS?
Sent from my ONEPLUS A6003 using Tapatalk
post #7 of 9 (permalink) Old 02-04-2020, 11:34 AM - Thread Starter
CoreyL4's Avatar
Rep: 2 (Unique: 2)
b450 tomahawk max,
and yeah i have it offset + with .2350
not sure what else needs to be set. i have cool n quiet, and c states enabled also.
CoreyL4 is offline
post #8 of 9 (permalink) Old 02-04-2020, 12:25 PM - Thread Starter
CoreyL4's Avatar
Rep: 2 (Unique: 2)
no matter what settings i disable or enable, the vcore will not decrease as it should when reported in hwinfo or cpuz
CoreyL4 is offline
post #9 of 9 (permalink) Old 02-04-2020, 11:52 PM
Rep: 1 (Unique: 1)
On some cheaper motherboards offset actually means fixed voltage. Looks like that.
sleepwithechoes is offline
