3950x WC Build - Shopping cart check - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 05-15-2020, 02:25 AM - Thread Starter
Regel's Avatar
Rep: 41 (Unique: 37)
Hi everyone,
Before I pull the trigger on some of these, would you mind giving me your thoughts?
Main purpose will be video editing and graphic design, some ML workloads occasionally.
PC Components:
  • CPU: Ryzen 9 3950x
  • Mobo: Asus ROG Crosshair VIII Formula
  • RAM: 4x 16GB G.Skill TridentZ RGB F4-3600C17Q-64GTZR
  • PSU: Seasonic Prime PX-1000
  • Graphics Card: I will use my old GTX 970 for now until RTX 30x0 comes out
  • Storage: Seagate FireCuda 520 1TB (as I don't need a separate heatsink with the mobo) + a Samsung EVO 970 M.2 and some other drives from my current build
  • Case: Lian Li O11 Dynamic XL
Watercooling:
I'll look to put in 3x 360mm rads. I was very much inspired by Sc00ter's build here. As I'm in Europe, Alphacool rads are the easiest to come by.
  • Bottom rad: Alphacool NexXxoS Monsta 360mm (86mm thick)
  • Top rad: Alphacool NexXxoS XT45 Full Copper X-Flow 360mm Radiator (45mm thick)
  • Side rad: Alphacool NexXxoS UT60 Full Copper 360mm Radiator - White Special Edition (60mm thick)
  • CPU block: EK Water Blocks EK-Velocity AM4 D-RGB CPU Wasserkühler - Nickel + Acryl
  • Coolant: Mayhems Pastel - UV White
  • Tubing: Tygon R3400 16/10mm
  • Pump/res: Corsair Hydro X XD5 RGB White
  • Fans: ML120 Pro for bottom and side rad, LL120 for top rad
Once I switch to a new GPU I plan to add that in the loop as well.
Thoughts? Anything I'm missing?
Thanks a lot for your help.
Ghost
(18 items)
AMD Ryzen 9 3950x
ASUS Crosshair VIII Formula
ASUS 2080 Ti TURBO
G.Skill Trident Z RGB 64GB
Seagate FireCuda 520 NVMe
EK Quantum Velocity Acryl/Copper
Heatkiller IV 2080Ti block
Alphacool Monsta 360mm
Alphacool UT-60 360mm White Edition
Alphacool XT-45 360mm
Lian Li O11D XL
Dell U4919DW
Keyboard
Filco Majestouch 2
Mouse
Razer Mamba Tournament Edition
Mousepad
Razer Goliathus Extended Chroma
Audio
Sennheiser RS-195
Audio
Focusrite Scarlett 2i2 3rd Gen
Regel is offline
post #2 of 10 (permalink) Old 05-15-2020, 12:13 PM
Rep: 2 (Unique: 2)
I recently did a build in the same case. I used a 360 x 55 mm rad at the top and originally used a 360 x 60 mm rad at the bottom but the bottom rad had a couple of leaks. So, I replaced it with a 360 x 30mm rad. I also installed a 240 x 30 mm rad on the side. I used a Singularity Protium Ultimate 150 D5/Reservoir combo. My MB is a GB X570 Aorus Extreme. With the 55mm thick rad installed in the top position along with the fans there is very little clearance between it the MB which made it some what difficult to install it along with 2 8pin EPS cables plugged into the MB at the top left. With original 60mm thick rad at the bottom clearance was marginal but workable. The 30mm thick rad I ultimately used provide better clearance. Part of the clearance issue is the use of E-ATX MB.
Your 86mm thick bottom rad along with fans will probably cause clearance issues. Would suggest going no thicker than 60mm.
The 45mm thick top rad should be fine. The 60mm thick rad for the side will probably be to thick, suggest no more than 45mm thick for that rad.
The build you reference is using 3 360x38mm rads.
Good luck with the build.
Ryzen 3950X Build
(18 items)
3950X
Gigabyte X570 Aorus Extreme
PowerColor RX 5700XT Liquid Devil
MSI RX 5700 XT Water cooled
GSkill F4-3600C16D-32GTZN X 2
Samsung NVMe EVO 970
Samsung SSD 850 Pro
GB Aorus NVMe Gen4 SSD
Optical Drive
LG BDDVDRW
Seasonic
Optimus Foundation water block/custome loop with 360 rad.
Lian Li 011 Dynamic XL
Operating System
MS Win10 Pro
Samsung LC27HG70QQNXZA
Keyboard
Logitech G815
Mouse
Logitech G502
Other
Liquid Metal Conductonaut used on CPU and GPU
jfrob75 is offline
post #3 of 10 (permalink) Old 05-15-2020, 01:32 PM - Thread Starter
Regel's Avatar
Thanks for the comments!
I was watching this vid for the radiator clearances:
According to this video I should be able to fit both of those rads:
  • The 86mm thick bottom rad with fans will indeed stick past the bottom of the ATX motherboard, but as I only mount one graphics card this should be OK?
  • The 60mm rad on the side if I mount the fans behind in the other compartment
Is your experience different?
Ghost
(18 items)
AMD Ryzen 9 3950x
ASUS 2080 Ti TURBO
Lian Li O11D XL
Dell U4919DW
Keyboard
Filco Majestouch 2
Mouse
Mousepad
Audio
Sennheiser RS-195
Audio
Regel is offline
post #4 of 10 (permalink) Old 05-15-2020, 02:55 PM
Rep: 2 (Unique: 2)
I guess what you want to do will work it just makes it more cramped in my opinion. As far as the side rad thickness it probably won't be an issue but for me it was because my top rad is 55mm thick before the fans which mad it kinda of difficult to get to the side rad ports. I too mounted the side rad fans on the back side.
Ryzen 3950X Build
(18 items)
3950X
Samsung SSD 850 Pro
Optical Drive
LG BDDVDRW
Seasonic
Operating System
MS Win10 Pro
Keyboard
Logitech G815
Mouse
Logitech G502
Other
jfrob75 is offline
post #5 of 10 (permalink) Old 05-15-2020, 03:26 PM
Back at it again.
Avacado's Avatar
Rep: 104 (Unique: 79)
I was watching this vid for the radiator clearances: https://www.youtube.com/watch?v=EO6fVAkWINo&t=370s
You should be fine with one 1st slot mounted GPU. I have 2 and can fit a 60 with fans in the bottom, it's tight, but it works. You should be fine @86mm, though do consider, make sure your plan to water cool and mount a res to your side fans/rad, do not buy one larger than 240mm as you will need the bottom 120mm fan for clearance for the rad.
23652 Time Spy https://www.3dmark.com/3dm/47932151?
[email protected] Stats https://folding.extremeoverclocking....e.php?u=207393
i9 9900k @5.1GHz 1.34v
ASUS Prime Z390-A 1504 BIOS
Evga 2080 Ti Black Gamer +220 Core
Evga 2080 Ti Black Gamer +150 Core
4x8GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w G+
EK CPU/GPU/RES
2x aCool UT60 RADs
Lian Li O11 Dynamic XL (White)
Operating System
Windows 10
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #6 of 10 (permalink) Old 05-17-2020, 09:45 AM - Thread Starter
Regel's Avatar
Thank you, both!
Pulled the trigger yesterday, looking forward to building this machine! I finally went with a 2080Ti as well, so I can build the entire loop at once.
Ghost
(18 items)
AMD Ryzen 9 3950x
ASUS 2080 Ti TURBO
Lian Li O11D XL
Dell U4919DW
Keyboard
Filco Majestouch 2
Mouse
Mousepad
Audio
Sennheiser RS-195
Audio
Regel is offline
post #7 of 10 (permalink) Old 05-17-2020, 06:32 PM
Back at it again.
Avacado's Avatar
Thank you, both!
If you need any help what so ever that I can do to help your build, don't hesitate.
EVGA 1000w G+
EK CPU/GPU/RES
2x aCool UT60 RADs
Operating System
Windows 10
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #8 of 10 (permalink) Old 05-19-2020, 05:39 AM
hisXLNC's Avatar
Rep: 3 (Unique: 3)
out of curiosity, if only 1 gpu, could you fit a 60mm rad and fans in push and pull at the bottom?
hisXLNC is offline
post #9 of 10 (permalink) Old 05-19-2020, 06:02 AM
Back at it again.
Avacado's Avatar
Good question. Assuming your GPU was mounted in the 1st slot in a non-vertical configuration and your res was mounted high enough, yes.
EVGA 1000w G+
EK CPU/GPU/RES
2x aCool UT60 RADs
Operating System
Windows 10
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #10 of 10 (permalink) Old 05-19-2020, 12:58 PM - Thread Starter
Regel's Avatar
I will try to go for push/pull with an 86mm rad. I'll post pictures once the rads come in.
Ghost
(18 items)
AMD Ryzen 9 3950x
ASUS 2080 Ti TURBO
Lian Li O11D XL
Dell U4919DW
Keyboard
Filco Majestouch 2
Mouse
Mousepad
Audio
Sennheiser RS-195
Audio
Regel is offline
