First Build in 10 years, First AMD CPU since the 1990s and First overlclock in forever (advice please :) ) - Page 2 - Overclock.net - An Overclocking Community
post #11 of 14 (permalink) Old 05-17-2020, 12:19 PM
Rep: 11 (Unique: 9)
Manual OC is fine just keep TDC and voltage below the pbo settings(your TDC is higher than stock in OC mode @1.325v). I would guess around 1.25v max in your case. I use [email protected] on my 3600. Also look into CCD overclocking because your 1st CCD can go up to 100mhz+ faster than the 2nd CCD.
2600ryzen is online now
post #12 of 14 (permalink) Old 05-17-2020, 01:38 PM
KarathKasun's Avatar
Rep: 218 (Unique: 136)
Thats a fairly golden 3600 you have there. It takes me the better part of 1.3v (1.325v set, 1.295v under load) to hold 4200 on mine under Prime 95, anything lower and it errors out almost immediately.
EDC is almost 30A higher with that manual OC as well, ~70A peaks become 112A peaks.
HP-UX. I came, I saw, I was sad it would not run on my X86 box.
skull.gif [Official]AMD RX 480/ 470/ 460 Owners Club skull.gif
KarathKasun is offline
post #13 of 14 (permalink) Old 05-17-2020, 01:51 PM
Rep: 963 (Unique: 708)
Your cpu is close to my 3900x i got 4400Mhz stable at right around 1.31 and drops to 1.28 underload.
Midnight Madness
(17 items)
AMD RYZEN 9 3900X
ASUS AMD AM4 ROG Strix X570-E
EVGA GTX 1080 FTW Hydro Copper
G.SKILL TridentZ Series
Samsung EVO 850 500
SeaSonic M12D SS-850 850W
EK-SBAY Dual DDC 3.2 PWM Serial
Alphacool NexXxoS ST30 Full Copper Radiator 360
Hardware Labs Black Ice SR2 Multiport Black Carbon Radiator - 360mm
EKWB EK-Velocity Strike CPU
EK-CoolStream RAD XTC 420
Thermaltake core x71
Operating System
Windows 10 Pro
ASUS VW246H Black 24" 2ms
Keyboard
Rosewill NEON K75 V2 BR
Mouse
CM Storm Sentinel Advance II
Audio
Corsair Void
Bal3Wolf is offline
post #14 of 14 (permalink) Old 07-14-2020, 09:19 AM
Ryzen1979
Rep: 0
Hi Mark,
I recently purchased an AMD setup similar to yours with the R9 3900x coupled with Asus ROG x570-F gaming. I'm using 4.3mhz @ 1.3v with CPU LLC at Level 2 & SOC LLC at Level 3. I'm getting 74 degrees C under full load on CB R20 that's using a Corsiar H115i AIO. From reading so many reviews I'm still unsure on the best voltage to use and if LLC should be used on my setup currently. Still so much to learn. I too have upgraded from an old system, I had a i7 3820 on the X79 Sabertooth which kept me going for years. Curious what bios settings you're using now after having your setup going for a couple of months now?
Kind regards,
Keith
kapf1979 is offline
