Max safe 24/7 temp threadripper 3970x - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 06-10-2020, 02:38 AM - Thread Starter
happyluckbox's Avatar
Rep: 11 (Unique: 9)
Curious what the max safe 24/7 temperature I should aim for with this chip? I have it running 24/7 on air noctua, daytime temps avg 80 with occasional peaks at 88, nighttime temps avg 72 with occasional peaks of 80. Pbo enabled with negative voltage offset of -0.06825, LLC level 5 aka medium
I'd like it to last at least around 5 years 24/7
AMD Threadripper 3990x || 256GB G.Skill TridentZ Neo @ 3600mhz 18-22-22-42 || Asus Zenith 2 Extreme Alpha || 2080TI FE || Samsung 960 Pro 1TB || Samsung 970 EVO 4TB || Evga 1200 P2 || Meshify S2 || Custom Loop
happyluckbox is offline
post #2 of 7 (permalink) Old 06-10-2020, 04:52 PM
oni222's Avatar
Rep: 0
Well not sure if it helps but I currently run the 3990x at stock settings at 37c on idle and up to 48c on load but I have had issues getting all cores to work.
I switched from Win 10 pro to Win 10 enterprise but I have had issues with enterprise working right...
I use a custom loop with three 480 radiators in lush pull configuration.
The GPU’s are on their own loop.
Sent from my iPhone using Tapatalk
oni222 is offline
post #3 of 7 (permalink) Old 06-10-2020, 06:18 PM - Thread Starter
Rep: 11 (Unique: 9)
What issues are you having? I'm using windows 10 education for my 3990x and all cores and 256gb of ram are working. Maybe i can help
post #4 of 7 (permalink) Old 06-10-2020, 07:43 PM
oni222's Avatar
Rep: 0
It is hard to explain but on win 10 pro it worked fine but the whole 128 threads being not used properly always bugged me.
So I used my Enterprise N edition from work and it had some features gutted. For example SMB shares where disabled and was more sluggish than Pro.
So then I tried a pirated iso of Enterprise using my volume key and SMB shares worked but it would become unresponsive half the time so I am now going back to Windows 10 Pro.
oni222 is offline
post #5 of 7 (permalink) Old 06-10-2020, 08:53 PM - Thread Starter
Rep: 11 (Unique: 9)
Interesting, I was under the impression that windows 10 pro should use all 128 threads properly.
post #6 of 7 (permalink) Old 06-11-2020, 05:44 PM
Rep: 6 (Unique: 5)
If it were me I would put thermal throttling to 70c, I don't know what's 24/7 full load safe though. Maybe that's 90c like AMD says?
edit: either thermal throttling or TDC limiting, whatever gives you the most performance at 70c.
2600ryzen is offline
post #7 of 7 (permalink) Old 06-11-2020, 06:02 PM
Rep: 6 (Unique: 5)
Also if it's actually going to be running 24/7 and you don't care about single threaded performance consider a manual OC. It will use much less power/generate less heat and give you 100's of mhz extra performance.
