general feedback on 13h monitoring? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 06-10-2020, 09:39 AM - Thread Starter
Rep: 0
windows 10 2004 fresh install
room temperature, about 25c +/- 1
during this 13h;
idle temps about 35-40c
mostly light web browsing / youtube
busy vmware instance running, allocated 4 core
cpu utilization between 5% and 20% (mostly from vmware)
not in this 13h;
cinebench 20, 79c with 7233 score
no game played
anything jumping out that would be red / yellow flag? any questions if some information are missing?
Name:	Annotation 2020-06-10 122906.png
Current
(6 items)
3900x
Aorus x570 Pro Wifi
Sapphire Pulse 5700
G.SKILL Trident Z Neo - F4-3600C16D-32GTZNC
Noctua NH-D15S
Define R6
spirch is offline
post #2 of 7 (permalink) Old 06-14-2020, 04:34 PM
PhillyB's Avatar
Rep: 30 (Unique: 28)
"What are you trying to monitor?" is a good question
Just looking at the image, the cpu voltage does seem excessive as does the chipset temp.
Not sure why your score is low. Your clocks dont seem to match the score. My 3900x averages around 7650 to 7700 with an all core over clock at 4.3 and 1.2875v.
PhillyB is offline
post #3 of 7 (permalink) Old 06-17-2020, 10:15 PM
Rep: 0
Look fine to me.
Is this stock(no PBO or OC)? If it is, then your cinebench score is very very good. Most stock 3900x I've seen top out at score around 71xx.
NonXtreme is offline
post #4 of 7 (permalink) Old 06-18-2020, 05:51 PM - Thread Starter
Rep: 0
100% stock yes, I decided to get new paste and redo it, this is what i found when I removed the heatsink.
previously it was the paste that came with the heatsink, the one that I got (my only choice at that time) mx-4
i cleaned everything and put it back, this time temperature seem a little bit better, I'm getting (sometime) ~7250 R20 score and temperature peak at 76-77 now
it's funny how vmware with 4 cores allocated to it (not idle) create a lot of heat, after 19h of monitoring now i'm sitting close to 58c average
Current
(6 items)
3900x
Aorus x570 Pro Wifi
Sapphire Pulse 5700
Noctua NH-D15S
Define R6
spirch is offline
post #5 of 7 (permalink) Old 06-19-2020, 05:45 PM
PhillyB's Avatar
That sounds about right for vm that is not idle. It has to run an os through a simulated hardware, then converted into instructiond for your base os. The video processing in the vm has to do the same. Tons of translation for the cpu to perform. Its why hypervisors like vsphere and proxmox are vital for vm servers. Less layers to clog up cpu time.
PhillyB is offline
post #6 of 7 (permalink) Old 06-19-2020, 09:16 PM - Thread Starter
Rep: 0
i have hardware pass through / virtualisation turned on
Current
(6 items)
3900x
Aorus x570 Pro Wifi
Sapphire Pulse 5700
Noctua NH-D15S
Define R6
spirch is offline
post #7 of 7 (permalink) Old 06-20-2020, 06:08 AM
PhillyB's Avatar
Virtualization on is required. The local os has to still process the application which is vmware, which processes the vm.
PhillyB is offline
