Requesting some 3300x OC Help - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 07-03-2020, 05:24 PM - Thread Starter
Rep: 0
Hey guys,
So i'm pretty new to the Ryzen platform in general, only upgraded cause my old bulldozer died on me in december, so got myself a 3300x with an Aorus B450 Elite and some G-skill Ripjaws 3200mhz ram,
Anyhow i was playing with the clocks in Ryzen Master and noticed that playing with the voltages/clock speeds i was able to bring up my cpu to 4.4ghz at 1.25v while running cooler than stock out of the box settings? and not just by a small margin either, i went from ~70c under full load to about 58-59c which surprised me quite a bit,
Anyhow i tried going further and am currently sat at 4.6ghz @ 1.275 volts and it appears to be stable as of writing this, so i'm tempted to keep it like this but wondering if the voltage isn't a bit high for continuous use?
xXEl3mXx is offline
post #2 of 7 (permalink) Old 07-03-2020, 05:32 PM
abso's Avatar
Rep: 9 (Unique: 9)
Unlikely you can go from [email protected] to [email protected]
Below 1.3V should be ok for daily use
abso is offline
post #3 of 7 (permalink) Old 07-03-2020, 05:35 PM - Thread Starter
Rep: 0
Could be that i can sit at 4.4ghz well below 1.25v just didn't bother testing it, i just slapped 1.25v on there and it worked, increased clocks till it was unstable and then bumped to 1.275v and was able to hit the 4.6ghz with that, haven't been able to hit 4.7ghz though even at 1.325v so not even gonna bother with that
xXEl3mXx is offline
post #4 of 7 (permalink) Old 07-03-2020, 06:12 PM - Thread Starter
Rep: 0
Okay i am sooo confused right now, Decided to leave Ryzen Master and OC in the bios, did a +0.230~ Dynamic Vcore and bumped multi to 46 for 4.6ghz and tbh i'm not even sure what's going on as my system is reporting a voltage of 1.1v at 4.6ghz and it's stable? wth
xXEl3mXx is offline
post #5 of 7 (permalink) Old 07-04-2020, 02:17 AM
Rep: 9 (Unique: 8)
VID doesn't include the offset, you need to check what the sv12 vcore sensor says.
2600ryzen is online now
post #6 of 7 (permalink) Old 07-04-2020, 02:25 AM
Edgy & on the edge
Rep: 54 (Unique: 27)
It will reboot instantly once you fire up Prime95 small FFTs.
AMD Bliss
(16 items)
AMD Ryzen 5 3600 - 2019PGT
MSI X470 Gaming Plus Max - 1.0.0.6
ASUS GTX 1060 Strix 6GB
2x8GB G.Skill Trident Z 3600C15 @3800 14-15-12-28-40 1T 1.52V
Samsung 970 Evo Plus 250GB
2x Samsung 860 Evo 500GB
2x Crucial MX500 1TB
Super Flower Leadex II Gold 650W
be quiet! Dark Rock 4
Phanteks P350X
ASUS VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Logitech G502 Proteus Core
Mousepad
Logitech G440 hardmat
Audio
Asus Cerberus
rares495 is offline
post #7 of 7 (permalink) Old 07-23-2020, 11:00 AM
Alexshunter's Avatar
Rep: 0
Could you run a Chinebench R20? I'm curious what voltage you would need to pass it trough at 4.6GHz.Include screenshoot with CPU-Z
Asrock X470 ITX, Ryzen 5 3600X, 2x8GB DDR4 3600 CL16, Geforce 1660ti, Samsung 970 Evo Plus
Alexshunter is offline
