2600+ XP no Mobile here, need some help - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 10-13-2004, 03:19 PM - Thread Starter
j3rb3@r's Avatar
Rep: 0
Ok as you can read by the specs below what my system is compiled of.
I just ran CPU-Z and i found out that my 2600 is a Throughbred: here are the specs:
Voltage :1.696
Stepping: 1
Model: 8
Family: 6 Ext Family: 7
Core Speed: 2071 MHz
Multiplier: x12.5 (Unlocked BTW)
FSB: 166 MHz
Bus Speed: 333 MHz
L1 Cache: 64+64Kbytes
L2 Cache: 256 Kbytes
Ok now for the BIOS settings:
CPU Fre Multiplier : 12.5
CPU External Frequency: 166/33
Mem Frequency: Auto/333
CPU Vcore: Auto/ Manual
CPU Vcore:1.65
And my RAM is 2.0-3-3-7 for the settings...
I am going to get http://www.case-mod.com/store/produc...roducts_id=801 for my HS replacement with 2x Zalmac Tornadoes fans (92mm)
My ram is PC2700 and i know that i am going to need at least PC3200 to be able to get high speeds. I really need some help here. Thank you guys in advance!~!
EDIT!!!!!:: Should i change the Multiplier and the FSB or both or the V or what...
post #2 of 18 (permalink) Old 10-13-2004, 03:21 PM
forget that giant hsf get a thermalright sp-97 with a vantec tornado and as5 yeah and the the pc-3200 will help you out to
ThE_GeNeRaL is offline
post #3 of 18 (permalink) Old 10-13-2004, 03:26 PM - Thread Starter
j3rb3@r's Avatar
Rep: 0
You sure that will be better then that huge one? And how should i OC this thing. I just raised the FSB by 1 MHz and noticed a HUGE difference.
HELP!!! lol
post #4 of 18 (permalink) Old 10-13-2004, 03:33 PM - Thread Starter
j3rb3@r's Avatar
Rep: 0
Ok , i just OC'ed my CPU to 2.1 GHz by increasing the FSB to 168MHz, and OMG i want MORE!!! I am going to buy a nice HS...but i really want to know what is the best because its going on the credit card tonight!!!
Also RAM is going on as well. Im thinking either corsair or Kingston pc3200, or should i go higher then that?? Thx
post #5 of 18 (permalink) Old 10-13-2004, 03:47 PM
Zeus's Avatar
Rep: 222 (Unique: 155)
I've got a T'Bred 2600+ like yours. and just so you know, I had mine running @ 2.5GHz without any problems (its currently running @ stock speed due the mobo its in)
The RAM I used when oc'ing my 2600 was Corsair TwinX XMS3200Pro Cas2 (2 x 512Mb) with timing of 2.5-3-3-8
Before you start oc'ing I would recommend to read the oc guide (https://www.overclock.net/overclock.p...king-guide.htm) as this will give you a step by step process on how to oc (i used it when I first started to oc).
Colin McRae: - "If in doubt, flat out"
Zeus is offline
post #6 of 18 (permalink) Old 10-13-2004, 04:09 PM
Retired Staff
Evil XP2400's Avatar
Rep: 475 (Unique: 269)
If you're set on that heatsink have a look at the thermaltake tower112... It's the same but all copper instead of aluminum which will help get better temps...
Another goods ones to look at is the thermalright SP97, SLK947.
Evil XP2400 is offline
post #7 of 18 (permalink) Old 10-13-2004, 04:10 PM
kryptonman's Avatar
Rep: 1 (Unique: 1)
Ok, Your board being an A7V8 means its a VIA Chipset, Which also means that there is no PCI lock. If you noticed when you upped the FSB by 1 mhz it read 167/34, the 34 is your PCI bus speed. PCI Bus speeds much over 35 mhz can corrupt a harddrive, not to mention a sound card , vidcard, and anything else on the pci bus, SO, tread lightly. It only goes back to 33mhz at 200, then starts back up above it. Your best bang for the buck, would be to back your multi down, and go to 200. to be on the safe side, take the multi down to a point where you at at or below the 1916mhz your cpu is at stock, then start playing from there.(200x9.5)
kryptonman is offline
post #8 of 18 (permalink) Old 10-13-2004, 04:14 PM
Retired Staff
Rep: 1130 (Unique: 519)
What's the one that Cooler Master has? It's like the Silent tower thing but has serrated edges on the fins to increase the surface area and performs pretty well from what I hear. You probably want to reconsider the fan choices as well...that's gonna be one loud mofo
YiffyGriffy is offline
post #9 of 18 (permalink) Old 10-14-2004, 12:02 AM
Ravage81's Avatar
Rep: 4 (Unique: 4)
I've been looking into a new HS and Fan combo myself. After doing alot of reading reviews and forums I would recommend getting the thermalright SP-97 with a 110 cfm or more fan. It is from what I have read by far one of the best heatpipe heatsinks out there. But they are really hard to find as they are being phased out for its replacement the SI-97 I believe (not available yet). I found them at www.vibecomputers.com on sale for 49.95 CAD!!! A great price, but sale is only on until Oct. 14.
I'll have mine in a few days and I'll give an update as to the difference it makes from my current Vantec Aeroflow.
Ravage81 is offline
post #10 of 18 (permalink) Old 10-14-2004, 12:39 AM
Rep: 26 (Unique: 19)
if you can't find a sp-97 the slk-900a is a good clip on heat sink. Not as spectacular as the sp-9 but in sheer numbers it is not far behind. If you can't find the sp look at the 900a from thermalright. Overclockers.com has tested a bunch of heatsinks and the 900a ruled until the sp-97 came along.
Fold for the cure....Fold for overclock.net Team #37726. Pour youself a drink FOLD!doh.gif
Weasel70 is offline
