Overclocking Brick Wall... Need help. - Page 2 - Overclock.net - An Overclocking Community
post #11 of 25 (permalink) Old 07-26-2016, 08:25 AM
curmudgeon
miklkit's Avatar
Rep: 306 (Unique: 177)
It seems I no longer remember everything to turn of but a partial list is: CnQ, C1E, EPU, SVM, and anything having to do with power savings. You have your manual and the bios will provide explanations when you hilite something. Methinks there are maybe 6 things to turn off.
The reason for turning them off is to get stable, consistent readings on values when overclocking. When you are done some of them, like CnQ, can be turned on again.
Now, how is your ram running? Is it running at 1866 mhz? Unstable ram will just confuse things later so let's make sure it is correct first.
Yes it is a dance between voltage, clocks, and temperatures. You do not want to go over 60C and cooler is better.
Every cpu is different so no one can say with certainty what yours will need. This is a different cpu and motherboard but it should give you an idea of what to expect at 4 ghz. This is with IBT AVX from the link running and the info shown in HWINF64.
IOKIYAR
Junkyard Dog
(18 items)
Blackie
(17 items)
AMD Ryzen 1700
Biostar X370 GT7
Sapphire Nitro+ Radeon Vega 64
G. Skill Ripjaws ddr4 3200 16 GB 4x4
Samsung 850 EVO 500gb SSD
Western Digital 500gb
Samsung 860 evo 1tb ssd
Optical Drive
Memorex Lightscribe dvd
Seasonic 850 watt
Thermalright Silver Arrow IB-E Extreme
Silverstone Redline RL05
Operating System
Win 10 64bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent vertical mouse
Mouse
yes
Audio
Creative X-FI
Other
Sennheiser headphones HD 599
AMD FX8370 @ 5 ghz
ASUS Sabertooth
Sapphire Fury
G Skill F3-14900CL9Q-16GBXL
Western Digital
Samsung 850 EVO
Optical Drive
Seasonic SS-850KM Active PFC F3
Silverstone Redline RL02b
Operating System
Win X 64 bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent VM4
Mouse
yes
Audio
Creative Soundblaster Z
Audio
Sennheiser 428 headphones
miklkit is offline
post #12 of 25 (permalink) Old 07-26-2016, 12:37 PM - Thread Starter
evilthx's Avatar
Rep: 1 (Unique: 1)
My memory is 1866 DDR3 by Crucial. I am going to fiddle around with a few more settings and post some pics if successful. Thanks for the help.
evilthx is offline
post #13 of 25 (permalink) Old 07-26-2016, 01:07 PM - Thread Starter
evilthx's Avatar
Rep: 1 (Unique: 1)
This is the second of the two back to back IBT I ran with this overclock (3.6Ghz)
evilthx is offline
post #14 of 25 (permalink) Old 07-26-2016, 01:36 PM - Thread Starter
evilthx's Avatar
Rep: 1 (Unique: 1)
Ok third run, this time at Very High. Would not go over 47*c. I will now try for 4.0Ghz.
evilthx is offline
post #15 of 25 (permalink) Old 07-26-2016, 05:49 PM
Riding on the edge
The Sandman's Avatar
Rep: 352 (Unique: 248)
You do realize you are testing with the non AVX version of IBT correct?
That is why you see such low Gflops.
Test your FX with IBT AVX version found here https://www.overclock.net/attachments/13202 but keep a very close eye on your temps.
Better to start with the big boy test before you get too far along. Non AVX version doesn't push the FX enough.
When everything is in tune it should look more like this Warning: Spoiler! (Click to show)
Ryzen Build
(20 items)
Bruce
(14 items)
R7 2700x
Crosshair VI Hero
Diamond 7970
GSkill FlareX F4-3200C14D-16GFX
Samsung 960 EVO NVMe
Samsung 840 SSD
Corsair GT SSD
WD 2TB Black
WD 4TB Red
EVGA 850 G2
XSPC GPU Razor WB
XSPC RX 360
XSPC RS 360
D5 Vario
Gentle Typhoon AP-15 1850 rpm
EK-FB Asus C6H Monoblock
XSPC EX140
Xigmatek Elysium
Operating System
Win 10 Pro
Asus VE248H x2
FX 6350
Asus CHV-Z
PNY GT 710
G.Skill Trident X 16GTX 1866MHz 8-9-9-24-33-1T
Samsung 840 Pro
WD20EFRX 64M Red x4 raid 10
WD5001AALS Blk
Optical Drive
Asus DRW-24B1ST
Corsair HX500
Hyper 212 Evo R2
Corsair 330R Titainium
Operating System
Windows Server 2008 R2 Standard
Asus
Keyboard
Logitech MK300
The Sandman is offline
post #16 of 25 (permalink) Old 07-26-2016, 08:47 PM
cssorkinman's Avatar
Rep: 463 (Unique: 263)
It's confusing , but the package temp on hwinfo is the actual cpu core temp, cpu temp in hwinfo is the socket temp.
At 32C max core temp, you have a ton of thermal headroom on the core.
As for the socket temp, do what you can to get some airflow on that area, place a fan on the back side of the motherboard over the socket area if you can.
cssorkinman is offline
post #17 of 25 (permalink) Old 07-26-2016, 09:10 PM - Thread Starter
evilthx's Avatar
Rep: 1 (Unique: 1)
Yeah that's confusing... how can my core temp be lower than my ambient room temp? The temp that got up to 47* is the temp that controls my fans in the Ai suite.
evilthx is offline
post #18 of 25 (permalink) Old 07-26-2016, 09:19 PM
In reality, it can't.
There is an algorithm that AMD uses to figure core temps on FX , it isn't accurate until core temps reach 30C + , generally.
post #19 of 25 (permalink) Old 03-07-2019, 03:53 PM - Thread Starter
evilthx's Avatar
Rep: 1 (Unique: 1)
Wow, I forgot all about being a member here! Well let us revive this old thread...
With the exception of a few new items, my build is still the same. I have upgraded to the ASUS ROG Strix RX480 graphics card since I started this thread, just two days ago swapped out the 8320E for an 8350 Black Edition and I use Steelseries Keyboard and Mouse. I am also using an LG 29" UltraWide monitor 21:9 @2560x1080. I am still using the Corsair H115i AIO but this CPU is WAY hotter... I fear the pump may have stopped or slowed WAY down. So with that said, I have a question or two on the FX-8350. The CPU is not overclocked and I ran Prime95 for almost 10min. Does this look safe/normal to all of you?
1. What is the max safe package temp of this CPU?
2. Anyone know what Thermal Max Temp of this CPU?
evilthx is offline
post #20 of 25 (permalink) Old 03-07-2019, 04:09 PM
Looks like a botched cooling block install to me, shouldnt be near that hot at that speed and voltage with that cooler.
Could possibly be a heatspreader that isn't flat.
