PC reboot automatically when i'm trying to install the driver for STX II into X370 PRO !!! [ HELP ME PLEASE ] - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 06-24-2017, 10:20 AM - Thread Starter
senna89's Avatar
Rep: 24 (Unique: 22)
Hi guy
I change my PC with an Asus X370 Pro + Ryzen 1700x.
PC run great, but i cant use my Asus Essence STX II, i pluged it and into devices manager i can see it, but when i try to install the drivers or try to update the driver the PC reboot automatically without reason.
What is this ?
- I tryed to remove and reinstall the card into the PCI-ex
- I checked if the power cable was correctly plugged
- I tryed to format the Windows and try to install Essence driver first at all but same problem ..... i run the setup of driver and .... boom !
If i go into devices manager and try to install driver manually, same thing.
HELP PLEASE !
senna89 is offline
post #2 of 8 (permalink) Old 06-24-2017, 10:40 PM
Da Boss
NexusRed's Avatar
Rep: 155 (Unique: 131)
Fresh install or...?
NexusRed is offline
post #3 of 8 (permalink) Old 06-24-2017, 11:48 PM - Thread Starter
senna89's Avatar
What means fresh install ?
i formatted hard drive and reinstall manually all.
senna89 is offline
post #4 of 8 (permalink) Old 06-28-2017, 07:55 AM - Thread Starter
senna89's Avatar
anyone ?
senna89 is offline
post #5 of 8 (permalink) Old 06-29-2017, 12:21 AM - Thread Starter
senna89's Avatar
Hi
Im tryed another slot PCI.
I plug the card in the last PCI 8x and once started Windows the card was recognized with the correct name and seems run ( with the penultimate PCI-ex 1x instead the card was recognized with a generic name like "multimedia asus audio controller" or similar and install any drivers )
But i dont know what driver is it and there's only that, so ..... no Xonar Control Center to set the card.
I try to launch the setup of the official driver downloaded by the site and do the same thing, PC restart immediately and now dont boot, i must switch off the pc via power button.
What is this ?
senna89 is offline
post #6 of 8 (permalink) Old 11-06-2017, 06:47 PM
AmxdPt's Avatar
Rep: 3 (Unique: 2)
Originally Posted by senna89 View Post
Hi
What is this ?
Welcome to the World of the Essence STX II in ryzen.
I have been trying to talk to asus here:
https://rog.asus.com/forum/showthread.php?94266-URGENT-SUPPORT-REQUIRED-PC-reboot-when-installing-driver-of-ESSENCE-STX-II
With no success on the same issue...
Apparently they decided to give up on me!
AmxdPt is offline
post #7 of 8 (permalink) Old 11-12-2017, 03:33 PM
iNeri's Avatar
Rep: 7 (Unique: 7)
If i remember well, Enable EpR or ErP (i dont remember) on bios in power options solves the issues with detection of sound cards. You could try that.
Ryzen [email protected] bclk+ Kraken X61 push/pull|Asrock X370 Taichi|EVGA SC2 1080ti [email protected] & [email protected] Mhz 0.98 mV + Kraken X61|GSkill FlareX 8GBx2 3740MHz CL 16-15-14-14-28-42-282-1t&1.39 mV|EVGA SuperNova 850W|Thermaltake View 31 RGB|NVME CorsairMP500 240 GB+Seagate 3TB 7200rpm 200 MBps|HP Omen 27" [email protected]
iNeri is offline
post #8 of 8 (permalink) Old 02-25-2019, 11:59 AM
j4uj4f's Avatar
Rep: 0
How to fix Asus Xonar STX II set up driver for windows 10 without reboot Computer
Quote: Originally Posted by senna89 View Post
Hi guy
What is this ?
HELP PLEASE !
After search on some forums I have found out 2 ways that can fix it, But I test the second way only and it work for my PC
A/_ 1st way
1 - GO to asus support site
2 - Download the last driver for windows 8.1:
- For example STX_8_1_8_1822_Win8_1.rar
3 - extract files and go to "WIN81" folder
4 - looking for "CmSetx.dll" file, and edit with notepad
5 - The configuration file, has 4 lines:
[SETUP]
ATYPE=30
INI_PATH=SoftwareDriver\InI
SupportOS=win81
You need modify like this:
[SETUP]
ATYPE=30
SupportOS=donotcare
6 - save changes and run with administrator privileges "Setup.exe" of root driver package folder.
( Not test yet )
B/_ 2nd way
Go to Device Manager
Disable ASMedia USB 3.1
Run setup driver as Admin
Wait still it setup successful
It will ask you to restart PC
Choose " No"
Enable ASMedia USB 3.1
Now you can restart your PC
Note : This way is work for me
j4uj4f is offline
