Gigabyte B450 Aorus M Strange Issue; - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 05-29-2019, 05:20 PM - Thread Starter
httuner's Avatar
Rep: 60 (Unique: 53)
I just built another computer and now fine tuning the overclocks, voltages, ect.
I'm working on air flow in this tiny Corsair 88r case, Hooked up 2 fans for intake up front directly into the power supply with the molex cable. Hooked up System Fan 1 to the rear fan for exhaust.
Everything runs fine, Ryzen 5 1600 3.85GHz at 1.2-1.25 volts easily, 24hour Prime stable with the stock cooler, never saw past 74C.
I thought I could improve those temps a little bit by installing another exhaust fan since while gaming the GPU does heat up the inside of the case quite a bit, I go to plug in another fan to fan header SYSTEM FAN 2.
This is where I run into problems; I shutdown the computer and it lags, monitor turns off but computer remains running, Hard shutoff and go to reboot; try to get into BIOS and it goes there but Keyboard inputs and mouse inputs are incredibly laggy, doesn't want to respond.
Feels like something isn't working, I bump the voltage up on the CPU thinking it could be that, turns out its not, Return all settings to Default in BIOS and nothing still the same, PC boots up and runs okay no problems, go to shut it down and same thing, monitor turns off but computer remains running, have to hard shutoff everytime pushing the power button. Go back into BIOS and keyboard inputs are non-responsive.
Here's the funny part; I go to disconnect the second exhaust fan from SYSTEM FAN 2 header and I'm back in action, no issues, everything is normal, overclock sticks, shutting the computer off is normal, going into BIOS is normal.
Anyone ever ran into this issue? I'm guessing it has to do something with having power drawn from SYS FAN 2 header with a fan in it.
Now here's another strange thing about it; When I plug in a 3 wire FAN into SYS FAN 2 header; its normal no issues, but when I plug in a 4 wire FAN into SYS FAN 2; I get this issue.
I can live with it since the problem only exist when a 4 wire fan is plugged into it but with a 3 wire fan its completely fine. Just looking for someone to chime in if they know what this problem may be.
httuner is offline
post #2 of 2 (permalink) Old 06-25-2020, 06:38 PM
fcchin's Avatar
Rep: 2 (Unique: 1)
Hello httuner, fan calibration, did you run it after plug in 4 pins PWM type fan? all the fan headers are dual mode but must run calibration once to let the motherboard determine the fan type hence applying between DC mode vs. PWM mode accordingly.
Your post been well over a year, may be you've solved it, just curious if you did.
3800x Taichi_X370 Sapphire5700 CX750M [email protected] PoseidonAbsoluteZero3 in Barrow PWM-17w DDC pump> CPU>420x140x28 TT_core_V71
ram 4x8GB HOF4CXLBS3600K17LD162C
Ryzen 3800X
ASRock X370 Taichi
Sapphire 5700 Pulse
Galax Hall of Fame HOF4CXLBS3600K17LD162C
Optane 900p
Corsair CX750
Liquid cool single loop GPU > 420x140x86 > CPU > 420x140x28
Alphacool NexXxoS XP³ Light - Brass Black Chrome
TT Core V71
Acer XG270HU
Mouse
Roccat Tyon
Audio
DIY raw-loudspeaker, DIY box, 3-ways full active 48dB/oct
Other
Thrustmaster TWCS
Ryzen 3 2200G
ASRock A320M-HDV R4.0
G.Skill F4-3000C16S-8GISB
HiKvision E2000
AMD Wraith
GTR S608 silver
Operating System
Windows 10 Pro
Ryzen 1700X
Gigabyte B450 AORUS M
Corsair CMK32GX4M2B3000C15
Adata SX8200 pro
Gigabyte P650B
AIGO/爱国者A16 plus 台式主机电脑机箱
TCL显示器34英寸准4K曲面144Hz电竞游戏21:9带鱼屏PS4液晶2k电脑32屏幕27 T34M6CW
fcchin is offline
