Two(2) 12V power connections on some X570 boards? - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 07-11-2019, 04:27 PM - Thread Starter
15 Year Club
Cait Sith Cat's Avatar
Rep: 90 (Unique: 81)
Hi. It has been a while since I've looked at builds... I don't know if this is new.
I notice some of the X570 mobos (most, actually) have a 24 pin power, an 8 pin power - both expected. But on many, there is ALSO a 4-pin power slot.
Do those both need connected? Or is it one or the other? Will my 3 year old AX650 power supply have the necessary cabling to supply power to the mobo?
15 years of overclocking!
Cait Sith Cat is offline
post #2 of 8 (permalink) Old 07-11-2019, 04:33 PM
The last VRM burner
Rep: 19 (Unique: 12)
Plug in one 8-pin, pretend the other plug does not exist. It's that relevant.
PC for all
(18 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
2x KHX2400C11D3/8GX 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
Pending
Raijintek Tisis lapped+ Arctic Cooling MX4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
SteelSeries Rival 310
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #3 of 8 (permalink) Old 07-12-2019, 07:42 AM
curmudgeon
miklkit's Avatar
Rep: 305 (Unique: 176)
It depends on the cpu and how far you plan on pushing it. For instance, with FX the Sabertooth had one plug and the CHVZ had 2 plugs. Some people running a full water loop and pushing for max OCs on the Sabertooth used so much voltage that they melted that 8 pin plug. Meanwhile I had no problems while running air cooling.
So, what are you planning on doing with your new rig?
IOKIYAR
Junkyard Dog
(18 items)
Blackie
(17 items)
AMD Ryzen 1700
Biostar X370 GT7
Sapphire Nitro+ Radeon Vega 64
G. Skill Ripjaws ddr4 3200 16 GB 4x4
Samsung 850 EVO 500gb SSD
Western Digital 500gb
Samsung 860 evo 1tb ssd
Optical Drive
Memorex Lightscribe dvd
Seasonic 850 watt
Thermalright Silver Arrow IB-E Extreme
Silverstone Redline RL05
Operating System
Win 10 64bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent vertical mouse
Mouse
yes
Audio
Creative X-FI
Other
Sennheiser headphones HD 599
AMD FX8370 @ 5 ghz
ASUS Sabertooth
Sapphire Fury
G Skill F3-14900CL9Q-16GBXL
Western Digital
Samsung 850 EVO
Optical Drive
Seasonic SS-850KM Active PFC F3
Silverstone Redline RL02b
Operating System
Win X 64 bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent VM4
Mouse
yes
Audio
Creative Soundblaster Z
Audio
Sennheiser 428 headphones
miklkit is offline
post #4 of 8 (permalink) Old 07-12-2019, 08:28 AM
Overclocking Enthusiast
ozlay's Avatar
Rep: 273 (Unique: 219)
A single 8pin should be able to provide 600+ watts. However a lot of PSUs can't provide that over a single cable. So they add more then one. However most people will not need more then a single 8pin. Unless you are going to do some ln2 runs.
In Loving Memory Of Kassandra
Kaby
Rikka
(11 items)
Intel I5-7600k
Asrock Z270M Extreme 4
Titan X
Titan X
Galax HOF
850 pro
960 Pro
970 Evo
Seasonic Prime Snow
enthoo evolv matx tempered glass
Operating System
windows 10 pro
ozlay is offline
post #5 of 8 (permalink) Old 07-12-2019, 08:41 AM
StAndrew's Avatar
Rep: 1 (Unique: 1)
Some boards used to include an extra 4 pin for PCI-E power requirements, generally for multi 3/4 way GPU's. Hasn't been needed lately due to the trend away from multi GPU. Might have to do with the additional power requirements for PCI-E 4.0...?
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #6 of 8 (permalink) Old 07-12-2019, 09:37 AM
Nvidia Enthusiast
philhalo66's Avatar
Rep: 266 (Unique: 208)
if its for the CPU ignore it, its only there to make you feel better. the mosfets will fail long before you need more than 1 8 pin. check out buildzoid he goes deep into why its stupid.
gaming rig
(17 items)
Intel Core i9 9900K
GIGABYTE Z390 AORUS PRO
EVGA GTX 1080 FTW2 2126MHz/11GHz
G.SKILL Ripjaws V DDR4 3600MHz 16GB
HGST 2TB
Seagate 2.5 Inch 2TB
Kingston UV400 480GB SSD
Optical Drive
LG Blu Ray drive
Corsair RM850i 850W
Corsair H115i /W Modded backplate
Corsair C70 Gunmetal
Operating System
windows 10 Pro 1607
HP 24W
AOC i2269vw
Keyboard
G.SKILL RIPJAWS KM780 MX
Mouse
Razer Deathadder Elite
Audio
Creative X-FI Titanium
philhalo66 is offline
post #7 of 8 (permalink) Old 07-12-2019, 10:19 AM
GPU Enthusiast
rv8000's Avatar
Rep: 191 (Unique: 143)
^ Ditto
Basically all the the ryzen 3000 series models up to 12 core (most likely the 16 core part) won't pull enough amperage to saturate the single 8pin EPS on air/h2o with OC's. Even on LN2 you'd need to be pulling well over 200a which for daily use and air/water oc's is just not going to happen.
99% of boards will function with just the single 8pin EPS connected.
Steins Gate
(16 items)
i7 8700k
EVGA Z390 Dark
Radeon 7
2x8GB DDR4 3600 c17 @ 4300 c19 2T
960 Evo
850 Evo
EVGA 750w G2
Thermalright True Spirit 140 Direct
Fractal Design S2
Acer ed323qur
Keyboard
CM MK Pro S
Mouse
G703
Mousepad
Logitech Powerplay
Audio
Polk tsi 100
Audio
HD518
Audio
Topping MX3
rv8000 is offline
post #8 of 8 (permalink) Old 07-12-2019, 10:53 AM
⤷ αC
AlphaC's Avatar
Rep: 874 (Unique: 577)
It's marketing, you'll cook the R9 3900X before you exceed 300W unless on subambient.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is online now
