DDR2 frequency setting problem on MA790x-ud3p rev1 - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 10-09-2019, 07:22 AM - Thread Starter
kielbasa's Avatar
Rep: 0
Hi everyone,
I'm a bit confused after installing 16GB (4x4GB Hynix pc6400 ddr2 800mhz) to my motherboard https://www.gigabyte.com/Motherboard...UD3P-rev-1x#ov
It wouldn't boot at first. It did after taking out 2 pieces of Ram, and then system started normally. (8GB)
Then, I installed all four pieces , but I lowered frequency to 667mhz. System booted normally but started to be unstable, rendering stopped and bluescreen appeared.
The last thing I did, I lowered freq to 533mhz (not changing anything else), and all went properly using all 16gigs.
All other settings are set to 'auto in bios.
Does it mean that this specific ram won't run using 800mhz on this motherboard ?
If it's possible to change it back to 800mhz, could someone guide me through the process how to make it work?
Thanks
kielbasa is offline
post #2 of 2 (permalink) Old 10-09-2019, 11:32 AM - Thread Starter
kielbasa's Avatar
Rep: 0
RAM exact symbol is - 4gb 2R x 4 PC2 -6400U-666-12 / HYMP125U64CP8-U6
And actually crucial question - am I loosing much while running it under 533mhz not 800mhz? I'm mainly interested in multithreading. (3ds max)
kielbasa is offline
