Gigabyte B450 Aorus Pro Wifi RAM settings - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 11-09-2019, 06:18 PM - Thread Starter
wmunn's Avatar
Rep: 4 (Unique: 4)
I have the Gigabyte B450 Aorus Pro wifi, with G.Skill F4-3200C16-8GTZR memory kit, Previously I hadn't had much luck getting the ram to run stable above 3333 mhz.....
Today I tried something a bit different, I picked hynix CJR in ryzen dram calculator, and applied the 3800 mhz safe profile it generated, and IT WORKED!
This is with a Ryzen 7 3700x processor.
I have no idea why the CJR settings work, but they do. Very stable without issues. Boots well and no errors.
AMD Ryzen 7 3700X
Gigabyte GTX 1660 OC
G.Skill Trident Z RGB 3200 8GB x 2
Intel P600 1TB Nvme
Corsair RM750i
Phanteks PH-TC14PE_ 140mm UFB CPU Cooler
Fractal Design Define R5
wmunn is offline
post #2 of 8 (permalink) Old 11-17-2019, 12:07 PM
Rep: 0
Do you have more information on this? I have the same motherboard. Is it stable?
goxplex is offline
post #3 of 8 (permalink) Old 11-17-2019, 12:09 PM
Rep: 0
Is it stable? Are you sure you dont have the F4-3200C16-8GTZRX which is specifically made for ryzen?
goxplex is offline
post #4 of 8 (permalink) Old 11-18-2019, 07:08 PM - Thread Starter
wmunn's Avatar
Rep: 4 (Unique: 4)
Yes, it passes memtest completely at this setting.
If you have this board, and the same ram kit noted above, I would start with ryzen dram calculator, generate safe profile for 3600 and start there. I have since moved onto a 32gb kit rated for 3600 as I wanted the increase in available memory, but the 3200 kit was working fine at 3600 and 3800 speeds.
AMD Ryzen 7 3700X
Intel P600 1TB Nvme
Corsair RM750i
wmunn is offline
post #5 of 8 (permalink) Old 11-18-2019, 07:17 PM - Thread Starter
wmunn's Avatar
Rep: 4 (Unique: 4)
This was the stable 3600 settings
AMD Ryzen 7 3700X
Intel P600 1TB Nvme
Corsair RM750i
wmunn is offline
post #6 of 8 (permalink) Old 11-18-2019, 07:19 PM
Rep: 1 (Unique: 1)
What type of RAM did you pick in the calculator? Those sticks are Hynix AFR. These are the chips: H5AN8G8NAFR-TFC. You can tell if you run Thaiphoon Burner and read the memory modules. It will tell you what type of ram chips are on that board. I'm not totally surprised that CJR worked. They are slightly better than AFR, but those settings may not be totally stable.
Black Widow
(17 items)
AMD RYZEN 9 3900X 12-Core 3.8 GHz (4.6 GHz Max Boost)
Gigabyte X570 Aorus Master
MSI GTX 1070 Ti Gaming
G.Skill Flare-X F4-3200C14D-16GFX
ADATA XPG SX8200 Pro
Crucial CT525MX300SDD1
EVGA SuperNOVA G3 750 W 80+ Gold
Noctua NH-D15
Noctua NF-A14 PWM
Noctua NF-A14 PWM
Noctua NF-F12 PWM
Noctua NA ​FC1 Fan controller
Fractal Design Define C TG
Operating System
MS Windows 10 Home OEM
Nixeus EDG v2 27" IPS
Keyboard
Massdrop CTRL w/ Cherry MX Brown
Mouse
Razer DeathAdder
Rapidian is offline
post #7 of 8 (permalink) Old 11-19-2019, 04:05 AM - Thread Starter
wmunn's Avatar
Rep: 4 (Unique: 4)
see attached thaiphoon burner readings. definitely A die, but runs with C die calculator settings.
AMD Ryzen 7 3700X
Intel P600 1TB Nvme
Corsair RM750i
wmunn is offline
post #8 of 8 (permalink) Old 11-19-2019, 04:09 AM - Thread Starter
wmunn's Avatar
Rep: 4 (Unique: 4)
Here are the stable 3800 settings.....
AMD Ryzen 7 3700X
Intel P600 1TB Nvme
Corsair RM750i
wmunn is offline
