Asrock Creator TRX40 not taking power? - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 01-22-2020, 06:48 PM - Thread Starter
Rep: 0
Hey everyone!
First off here is my build:
My specs:
MOBO: Asrock Creator TRX40
CPU: TR 3960x
CPU Cooling: Kraken x62
CASE: Phanteks Primo
RAM: HyperX Fury 64GB
GPU: RTX 2070
PSU: EVGA 1600W T2
SSD: Samsung EVO 512gb
So I connected everything, and I'm getting nothing. Even the Dr. Debugger with the Red LED lights doesn't come up!
I then took everything apart, and connected my two 8pin CPU power chords and my 24pin power chord, and I still get zero lights.
I figured my motherboard was dead, so I had it returned and got another sent to me. Sure enough, I am having the same issue, which leads me to believe this is a user-error.
Can anyone with a Asrock Creator TRX40 confirm a way to test if the motherboard is faulty? Shouldn't it light up with just a PSU connected to it?
Anyway help would be much appreciated, again this is my second motherboard so I don't believe that I could of received 2 dead motherboards, I'm clearly doing something wrong....
viable is offline
post #2 of 6 (permalink) Old 01-23-2020, 07:04 AM
boldenc's Avatar
Rep: 7 (Unique: 7)
maybe there is a short? I would suspect the PSU or compatibility issue, did you try different PSU?
Also I would test it outside the case just to make sure there is no short.
Overclocked
TUF Ultimate Force
(17 items)
Ryzen 9 [email protected]
X570 Plus TUF - Wifi
ASUS Strix 1070 Ti
GSkill 32GB [email protected]
PM980 1TB
970 Pro 512GB
Intel 660p 2TB
Seagate 8TB DC Edition
960 Pro 512GB
Seasonic Prime Titanium 850w
Enermax LIQMAX III 360mm
ASUS TUF GT501
Operating System
Windows 10 1909
LG 34UM88
Keyboard
Kingston HyperX Alloy Elite
Mouse
Razer DeathAdder Elite
Audio
Creative SB ZxR
boldenc is offline
post #3 of 6 (permalink) Old 01-23-2020, 07:05 AM
Senior OCN Member
shilka's Avatar
Rep: 2801 (Unique: 1654)
Have you tried using only a single 8 pin?
I once had a board with two 8 pins and for some reason it just refused to boot with both 8 pins plugged in
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #4 of 6 (permalink) Old 01-23-2020, 07:14 AM
Bench, Dead, Squat
Bad5ector's Avatar
Rep: 20 (Unique: 15)
The power switch is turned on on the back of the PSU???
Deff seems like short or power related though.
ShadowMoses
(21 items)
i7 7700K
ASUS ROG Maximus IX Formula LGA1151
EVGA GeForce GTX 1080 Ti Founders Edition
Corsair Vengenace Lpx 32GB DDR4 3200MHZ
Seagate ST1000DX001 SSHD 1TB 3.5in SATA3 64MB Cache Internal Solid State Hybrid Drive
Kingston HyperX Predator 240GB
EVGA SuperNOVA 1000 G1 80 Plus Gold Certified 1000W Fully Modular
RAD - EK-CoolStream XE 360
CPU Block - EK-Supremacy EVO - Nickel
GPU Block - EK-FC Titan X Pascal - Nickel
Pump / Res - EK-XRES 140 Revo D5 PWM (incl. sleeved pump)
Fans - 3 x EK-Vardar F4-120ER (2200rpm)
Coolant - EK-Ekoolant Pastel BLUE (concentrate 250mL)
Tubing - EK-DuraClear 11,1/15,9mm
Thermaltake Core P3 SE Snow Edition
Operating System
Microsoft Windows 10 Pro 64Bit
BenQ XL2720Z 27in LED 144HZ 1ms GTG FPS Gaming Monitor
42" LG TV
Keyboard
Corsair Gaming K65 Lux RGB Compact Mechanical Keyboard
Mouse
Corsair Gaming M65 Pro RGB Optical Gaming Mouse
Mouse
Corsair Gaming MM300
Bad5ector is offline
post #5 of 6 (permalink) Old 01-23-2020, 07:37 PM - Thread Starter
Rep: 0
Hey everyone, thanks so much for taking the time to help me!
Long story short, i got it to boot. I do think my first board i got from asrock was dead on arrival, because when I hooked
everything up, i got nothing.
But now, with this, everything works. The thing is, when I hooked the PSU up to it, i got nothing out of it.
But once I hooked everything else up (ram, cpu, cpu cooler, gpu, fans, psu, etc) i got it to boot...
Again thanks again for taking the time guys <3
viable is offline
post #6 of 6 (permalink) Old 01-23-2020, 07:50 PM
Paradigm Shifter's Avatar
Rep: 252 (Unique: 201)
Just out of curiosity, what boards have you used that do anything without a CPU in situ?
Paradigm Shifter is offline
