need help with load line - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 02-13-2020, 09:41 PM - Thread Starter
kaitlin4599's Avatar
Rep: 2 (Unique: 2)
so i have a B450 tomahawk and a 2700 non X cpu i wanna overclock the cpu but im bot sure which level of load line to use
but heres where im confused im not sure what loadline calibration level to use theres 7 of them in the list 8 if you count the auto setting
HP Z400 workstation with a GTX 750Ti
kaitlin4599 is offline
post #2 of 3 (permalink) Old 02-14-2020, 05:55 AM
VPII's Avatar
Rep: 16 (Unique: 11)
Good day my friend. Interestingly when I had a C7H mobo I used the max LLC for my cpu vcore. I actually measured the true voltage with a multimeter to check the true vdroop and found that it was very small. I also found that the voltage shown by CPUz is absolutely correct, better than any other monitoring programs. I tested it all even with lower LLC and the drop in vcore exponentially climb the lower LLC is set. I did also do a test with LLC left on Auto and to my surprise I had basically no vdroop with LLC set to auto. Right now I am doing the same with my MSI Meg X570 Ace mobo and no issues.
AMD Ryzen 9 3950X
MSI Meg X570 Ace Bios V170
4 x 8GB G-Skill DDR4 3200 CL14 @ DDR4 3733 CL16
Palit Geforce RTX 2080 Ti
VPII is offline
post #3 of 3 (permalink) Old 02-14-2020, 06:28 AM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
I use second to highest and if need be highest. No need to waste your time with the other ones.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
