2Q?s [x570 Taichi]: The 2ndary GPU Slot is Connected to CPU not Chipset, Right? --- Will 4-pin 12v EPS help w/OC Stability? - Overclock.net - An Overclocking Community
post #1 of 1 (permalink) Old 02-21-2020, 05:28 PM - Thread Starter
Rep: 0
Hey there my OC brethren; my title pretty much says it - I've just got a couple quick questions that someone with more experience can probably answer:
1) My Chipset is getting really hot; moving my GPU down a slot will probably help a lot, but I don't want to do that if my GPU throughput is going to be unsurreptitiously murdered. I don't see why it WOULD be connected through the chipset, but can't find any definitive information about my specific board, or x570s in general regarding their respective PCI-E trace topologies.
Edit: Or maybe I should consider getting a gpu riser?
2) I'm rocking an OC pretty hard on my 3900x; 4.4Ghz All-Core OC; which is ALMOST totally stable. I'm wondering if buying and connecting the extra 4-pin 12V motherboard connector will help at all. Most of the common information I heard regarding the subject of the 4-pin says something like, "If you aren't extremely overclocking it, you can leave out the 4-pin." or "If you aren't LN2 you don't really need the 4-pin." I don't really want to waste buying and shipping a product if 4-pin OC results are questionable at best. So, if anyone has any relevant real-world knowledge on the subject, or can maybe point me to a youtube video or maybe a tech write-up source on the subject I would be very appreciative for some guidance.
Thanks guys; keep on foldin'
DO OR B-DIE -- 3800C14-16GTZN
3900X
AsRock x570 Taichi
MSI 1080 Ti Gaming X
Trident Z Neo F43800C14D-16GTZN Samsung B-Die
Seagate FireCuda 520 PCI-e 4.0 NVME
Samsung 860 Pro SATA
NZXT HALE90 Fully Modular
NZXT Kraken 72X 380mm Radiator
Corsair RGB Fans x3
Corsair Crystal 570x Mirrrored Black Finish
Operating System
Windows 10 Pro
Monoprice Zero-G 35" Curved Ultra-Wide
Keyboard
Logitech G15
Mouse
Logitech Trackball
Greatli is offline
