Aorus B450i unstable with 3200MHz RAM (Help!) - Overclock.net - An Overclocking Community
post #1 of 1 (permalink) Old 06-20-2020, 05:40 AM - Thread Starter
Rep: 0
I just picked up an Aorus B450 I Pro Wi-Fi motherboard to pair with my existing Ryzen 2700X and Corsair Vengeance RGB DDR4 RAM in an ITX case. I am trying to get my RAM to run at 3200MHz, its rated speed, but my system becomes unstable (blue screens right after booting into Windows) with XMP Profile enabled. I have installed the latest BIOS update but no idea where to go next.
This issue is really frustrating me. I had the same problem with another Gigabyte B450 board and ended up just swapping it for an ASUS one, which ran the RAM at 3200MHz without any issues whatsoever. I had hoped the latest BIOS update would fix things, since it promises improved memory compatbility, but no luck. After some searching, I see this is a common problem with Gigabyte boards.
One of the solutions I tried was to manually set my RAM voltage. I tried 1.35v initially, then increased to 1.4v, but that made no difference at all. Yet more blue screens right after logging into Windows. I'm not sure if it's safe to go higher than that -- I've read conflicting info about it.
Thanks in advance for any advice.
killianbell is offline
