AsRock Creator trx40 - what cable to use to power the '6 pin 12V Power Connector' for quad gpu support? - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 07-02-2020, 01:42 AM - Thread Starter
Rep: 0
Hi there,
I'm building a quad GPU build and the manual for the AsRock Creator trx40 states, I need to power the '6 pin 12V Power Connector'. What power cable do I use?
I have the Corsair AX1600i PSU and the only cable that fits into a 6pin is a PCIe cable, but I wanted to double-check.
Thank you.
poeticstudio is offline
post #2 of 3 (permalink) Old 07-02-2020, 02:05 AM
The Stilt's Avatar
Rep: 872 (Unique: 333)
6-pin PCIe power cable.
No reason to connect it, unless you are using multiple (4, according to ASRock) GPUs.
The Stilt is offline
post #3 of 3 (permalink) Old 07-02-2020, 04:20 AM - Thread Starter
Rep: 0
Thank you for your fast reply.
Yes, that's exactly what I'm doing: using 4 graphics cards.
