HyperTransport 3.0 what exactly does it help do? - Overclock.net - An Overclocking Community
post #1 of 17 (permalink) Old 04-30-2012, 01:30 AM - Thread Starter
Kalistoval's Avatar
Rep: 41 (Unique: 31)
Ok so i was reading and trying to understand hypertransport and how it works and i a cross this
article here : http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-the-HyperTransport-Bus/19/4
so as i understand it 8 megabits = 1 megabyte
1,800 Mhz = 3,600 MT/S = 7,200 MB/S (Megabits)
2,000 Mhz = 4,000 MT/S = 8,000 MB/S
2,400 Mhz = 4,800 MT/S = 9,600 MB/S
and finally the ratio I accually care about, so if
2,600 Mhz = 5,200 MegaTransfers per Second = 10,400 Megabits per Second
If 8 Megabits = 1 Megabytes then that means that 10,400 Megabits equall 1.3 Megabytes right?
If thats true then wouldnt that mean that 1.3 Megabytes X 2 = 2.6 Megabytes/s aka 2,600 Mhz
or 2,600 Mhz X 2 = 5,200 MegaTransfers
So now if im runing a ssd from the pci-e lane and a gpu, my x64 os is on the ssd and im using my ssd to process both small and large video files via my gpu and also after converting my videos into iso's i burn 4 copys of them on to dvds at the same time via nero 11 so all 4 burners connected via my onboard sata II ports will be reading the same data simultaneously and writing on to the dvds, after the data has been written
on the dvds i move the iso image to my 1Tb hhd connected via sata II port note that these video files are anyware from 2.5 GB to 4.5 GB becouse there high quality movies my question is do i benefit from utilizing a hypertransport of 2,600 Mhz ? thinking.gif please share your 2cents.gif
Kalistoval is offline
post #2 of 17 (permalink) Old 04-30-2012, 12:02 PM
Hey I get one of these!
KyadCK's Avatar
Rep: 301 (Unique: 212)
Math time!
SSD based on sig: ~500MB/s
Fast HDD speed: ~150MB/s
Fast DVD speed: ~50MB/s
Total: ~850MB/s
(GPU not calculated; dependent on SSD)
The only time a HT link should even be close to flooded is moving large things from RAM to the GPU. You're fine. Although it is generally suggested to run the HT link as close to stock as possible on Phenom IIs.
Forge
(18 items)
Forge-LT
(7 items)
AMD Threadripper 1950X
Gigabyte X399 Designare
EVGA 1080ti SC2 Hybrid
32GB G.Skill TridentZ RGB (4x8GB 3200Mhz 14-14-14)
Intel 900P 480GB
Samsung 950 Pro 512GB
Corsair AX1200
EK Predator 240
Corsair Graphite 780T
Operating System
Windows 10 Enterprise x64
2x Acer XR341CK
Keyboard
Corsair Vengeance K70 RGB
Mouse
Corsair Vengeance M65 RGB
Audio
Sennheiser HD700
Audio
Sound Blaster AE-5
Audio
Audio Technica AT4040
Audio
30ART Mic Tube Amp
i7-4720HQ
UX501JW-UB71T
GTX 960m
16GB 1600 9-9-9-27
512GB PCI-e SSD
Operating System
Windows 10 Pro
4k IPS
KyadCK is offline
post #3 of 17 (permalink) Old 04-30-2012, 12:11 PM
OG AMD
Redwoodz's Avatar
Rep: 576 (Unique: 455)
Originally Posted by KyadCK View Post
Math time!
Total: ~850MB/s
From personal trial and error, increased HTT speeds only help once you max out the chipset bandwith. A speed of 2000MHz will give you around 16Gbps internally. You would have to run your RAM at a greater speed than this to see an increase in performance. I use Sandra http://downloads.guru3d.com/downloadget.php?id=2056&file=7&evp=961bab4bcae4ac632dacb807b976bc0b to test.
example #1 HTT at 2160MHz
480
https://valid.x86.fr/cache/banner/4d8m5e-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(4 items)
RCPC#1
(17 items)
Professional
Ryzen 2200G
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Ripjaws PS850G
AMD Phenom II X6 960T
Asus M4A88T-VEVO
Asus Strix R7 370
SuperTalent Perfomance
GSkill Snipers
Monster Daytona
Seagate Barracuda 500GB 7,200 RPM 16Mb cache
Optical Drive
Memorex DVD/RW
Corsair GS500
Corsair H60
In Win H-Frame
Operating System
Windows 8N
IBM 9494 19" LCD
Keyboard
IBM
Mouse
OCZ Behemoth
Mouse
Wolfking
Audio
JBL Creature
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #4 of 17 (permalink) Old 04-30-2012, 12:22 PM
KyadCK's Avatar
480
Forge
(18 items)
Forge-LT
(7 items)
Intel 900P 480GB
Corsair AX1200
EK Predator 240
Operating System
2x Acer XR341CK
Keyboard
Mouse
Audio
Sennheiser HD700
Audio
Sound Blaster AE-5
Audio
Audio
30ART Mic Tube Amp
i7-4720HQ
UX501JW-UB71T
GTX 960m
16GB 1600 9-9-9-27
512GB PCI-e SSD
Operating System
Windows 10 Pro
4k IPS
KyadCK is offline
post #5 of 17 (permalink) Old 04-30-2012, 01:05 PM
OG AMD
Redwoodz's Avatar
480
480
480
RedwoodCustomPC
AM4
(4 items)
RCPC#1
(17 items)
Professional
Ryzen 2200G
ASRock X470 Taichi
Asus M4A88T-VEVO
Asus Strix R7 370
GSkill Snipers
Monster Daytona
Optical Drive
Memorex DVD/RW
Corsair GS500
Corsair H60
In Win H-Frame
Operating System
Windows 8N
IBM 9494 19" LCD
Keyboard
IBM
Mouse
OCZ Behemoth
Mouse
Wolfking
Audio
JBL Creature
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
Optical Drive
Samsung BD
Zalman 9900MAX
Fractal Design R3
Operating System
AOC 22" LED
Keyboard
Logitech
Other
Redwoodz is offline
post #6 of 17 (permalink) Old 04-30-2012, 01:50 PM
KyadCK's Avatar
That's nice, but what increased that speed was your FSB going up (and thus forcing your RAM to be faster). RAM isn't on the HTT.
422
EDIT: Foot, meet mouth.
Anyway, I did say AMD said to keep the HTT as close to stock as possible. A better test however would be to leave everything stock and nudge the HTT multi around a bit.
Forge
(18 items)
Forge-LT
(7 items)
Intel 900P 480GB
Corsair AX1200
EK Predator 240
Operating System
2x Acer XR341CK
Keyboard
Mouse
Audio
Sennheiser HD700
Audio
Sound Blaster AE-5
Audio
Audio
30ART Mic Tube Amp
i7-4720HQ
UX501JW-UB71T
GTX 960m
16GB 1600 9-9-9-27
512GB PCI-e SSD
Operating System
Windows 10 Pro
4k IPS
KyadCK is offline
post #7 of 17 (permalink) Old 04-30-2012, 01:53 PM
GanjaSMK's Avatar
Rep: 626 (Unique: 466)
To note, HTT = bus speed, reference clock, base clock. It is not the HT Link speed. Just for reference.
@OP
I believe the differences in HT versions (1.0, 2.0, 3.0 etc) are variations of the same principle in transporting data over that i/o interface, but each version has theoretical limits and transfer speeds. Calculating them is tricky at best partially because the reported speed isn't how the speed is measured.
So HT 3.0 aims to implement enough bandwidth for ever-increasing bandwidth requirements of GPU and other high end PCI-E devices (SSD, controllers, etc).
@drbaltazar posts
Originally Posted by dave12
I like your posts. Every time I see one I read it multiple times trying to discern meaning, ultimately failing, but enjoying the experience.
GanjaSMK is offline
post #8 of 17 (permalink) Old 04-30-2012, 02:03 PM
KyadCK's Avatar
Hopefully PCI-e will get bumped up to the CPU directly instead of relying on the HT. That'd be nice. Not that HT isn't a seriously wide pipe, but it is one more step that has to be taken between the CPU and GPU.
Forge
(18 items)
Forge-LT
(7 items)
Intel 900P 480GB
Corsair AX1200
EK Predator 240
Operating System
2x Acer XR341CK
Keyboard
Mouse
Audio
Sennheiser HD700
Audio
Sound Blaster AE-5
Audio
Audio
30ART Mic Tube Amp
i7-4720HQ
UX501JW-UB71T
GTX 960m
16GB 1600 9-9-9-27
512GB PCI-e SSD
Operating System
Windows 10 Pro
4k IPS
KyadCK is offline
post #9 of 17 (permalink) Old 04-30-2012, 02:10 PM
GanjaSMK's Avatar
I'm pretty sure too there are a couple other things that were implemented with HT 3.0 that also relies on the chipset, but I don't know specifically what. Been a while since I read anything about the differences. redface.gif
@drbaltazar posts
GanjaSMK is offline
post #10 of 17 (permalink) Old 04-30-2012, 03:10 PM - Thread Starter
Kalistoval's Avatar
598 598
598
so what exactly does this mean?
