System Crashed Now 3TB HHD not showing up - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 02-21-2015, 04:16 AM - Thread Starter
Linux Lobbyist
sb43's Avatar
Rep: 9 (Unique: 9)
I got everything back up and running, after having to re-install Win8, but now my 3 TB HHD isn't showing up in disk management or anywhere. I feel it running. Any help?
AMD RYZEN 7 1800X 8-Core 3.6 GHz (4.0 GHz Turbo) , G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z1701000 Watt EVGA PSU, 1 PNY Geforce GTX 1080 XLR8 GDDR5 8 GB video card, Noctua D-15 Cooler, Corsair Air540 case, Samsung 840 Pro 256 GB SSD, (2) 1TB Western Digital M2 modules, Samsung 850 Evo 500 GB SSD, 2TB Western Digital HHD, Samsung monitor, and "LOTS OF FANS" with a 5 channel (60 watts per channel) fan controller.
sb43 is offline
post #2 of 20 (permalink) Old 02-21-2015, 05:43 AM
FastMHz's Avatar
Rep: 163 (Unique: 122)
Boot into your BIOS and make sure it's visible there in the storage section. If not, check/replace SATA cables.
I love electricity. The smell and crackle of high voltage.....
The funny thing about clouds is that everyone can view them and they eventually disappear.
FastMHz is offline
post #3 of 20 (permalink) Old 02-21-2015, 05:49 AM
Ore Wa Gundam
EvoBeardy's Avatar
Rep: 187 (Unique: 158)
^^ Seconded.
Try alternative SATA leads and ports, if it doesn't show up in the BIOS, plug it in outside of the HDD rack/case (just enough away to hear effectively) and listen to it onstartup, see if you can hear it spin up or for any clicking/clunking of the drive.
Unicorn SD
Astraea
(8 items)
l Intel® Core™ i7-5820K l
l MSI X99A SLI Krait Edition l
l MSI GTX 980Ti Gaming 6G l
l Corsair Dominator® Platinum (4x4GB) DDR4 3Ghz l
| Samsung PM951 M.2 PCI-e NVMe 512GB |
l Samsung 840 Evo 500GB l
l Toshiba X300 4TB 128MB Cache l
l Toshiba MD04ACA400 4TB l
l Toshiba DT01ACA300 3TB (x3) l
l Samsung F3 1TB l
Optical Drive
l Pioneer BDR-209EBK l
l EVGA SuperNOVA G2 850w l
l NZXT Kraken X61 (2x Noctua NF-A14-2000-IP67) l
l Phobya MaxGuide 6 Controller l
l CM Storm Stryker™ l
Operating System
l Windows 7 x64 Customised. l
l LG M2380D 1080p l
l Acer Predator XB240H 144Hz G-Sync l
Keyboard
l Logitech G19s l
Mouse
l Logitech G502 l
Mouse
l Razer Vespula l
Audio
l Steelseries Siberia V2 MSI Gaming Edition l
Audio
l Logitech Z506 5.1 l
Audio
l Creative Fatal1ty HS-800 V2 l
G3258 @4Ghz
MSI Z97I Gaming AC
MSI GTX 460
Crucial Ballistix Sport 1600MHz 8GB
Samsung 840 Evo 128GB
Toshiba DT01ACA100 1TB
Optical Drive
Optiarc 7170S
Cooler Master Silent Pro M2 520w Modular
Corsair H60
Cooler Master Elite 130
Operating System
Windows 7 x64
Keyboard
Logitech K400 Wireless Touch
Mouse
Logitech M187
i5 460m
MSI Intel HM55
Onboard Intel HD
Kingston PC3-8500F
Kingston PC3-8500F
Toshiba MQ01ABD100H [Hybrid]
Optical Drive
Optiarc AD-7580S
Operating System
Windows 7 X64 nVidia Ed.
EvoBeardy is offline
post #4 of 20 (permalink) Old 02-21-2015, 05:52 AM
DTR Enthusiast
bigkahuna360's Avatar
Rep: 141 (Unique: 121)
Had this issue a lot. Just switch SATA ports and boot Linux with the "Try" option. That'll fix it not showing up.
Funny quotes (Click to show)
Don't use software to overclock the CPU. It's not as reliable or as effective. Take off the skirt and go into the BIOS like a man.
Clubs (Click to show)
bigkahuna360 is offline
post #5 of 20 (permalink) Old 02-21-2015, 06:05 AM - Thread Starter
Linux Lobbyist
sb43's Avatar
Rep: 9 (Unique: 9)
I switched it to another SATA port, and it showed up, but then "Explorer stopped responding. I restarted andthen it wasn't there again. I hear and feel it running, it's only a couple months old.........
UPDATE 10 minutes later I just cleared the CMOS, and now it's back.
Update 20 minutes: I see all of my folders, but when I open them, it says' it's empty
sb43 is offline
post #6 of 20 (permalink) Old 02-21-2015, 06:19 AM
xenomorph113's Avatar
Rep: 14 (Unique: 13)
sounds to me like the partition may be corrupted or worse, it may be a failing drive, have you run a check-disk on it yet? or any diagnostics like seatools? do you hear clicking/clunking? is the drive unusually hot (+50 Celsius)?
xenomorph113 is offline
post #7 of 20 (permalink) Old 02-21-2015, 06:26 AM - Thread Starter
Linux Lobbyist
sb43's Avatar
Rep: 9 (Unique: 9)
but when I open the folders, it says it's empty
sb43 is offline
post #8 of 20 (permalink) Old 02-21-2015, 06:29 AM
FastMHz's Avatar
What was the cause of the system crash that required a reload?
FastMHz is offline
post #9 of 20 (permalink) Old 02-21-2015, 06:29 AM
could be file system corruption on that disk, have you run a "chkdsk /f"
open command prompt (start button then CMD)
type in chkdsk /f driveletter: [for instance D: for a secondary drive]
it should attempt to repair the file system
post #10 of 20 (permalink) Old 02-21-2015, 06:31 AM - Thread Starter
Linux Lobbyist
sb43's Avatar
Rep: 9 (Unique: 9)
Thanks I'll try that
sb43 is offline
