help me OC my old PC - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 03-13-2015, 12:33 AM - Thread Starter
jj72's Avatar
Rep: 0
Hi,
I would like to OC my old PC with the following hardware:
Asus A8N-VM CSM
3200+ Venice
4x 512MB RAM PC3200
2x Infineon 3-3-3-8
2x Apacer 2.5-4-4-8
nVidia 7900gs
newest BIOS v1007
Here is what I've done so far:
Increased the GPU clock with ASUS GPU tweak from 450MHz to 610MHz (can I get any higher?)
Max'ed the FSB to 240MHz (was 200MHz before)
Slightly lowered the RAM timings to 2.5-3-3-6 2T (is it safe to go lower with CAS or something else?) was inspired by http://www.tomshardware.co.uk/forum/194643-30-drops-speed
He said, that changing to these values made his RAM clock go back from 333MHz to 400MHz
and I read many articles about my motherboard, so I know it is a bad OC board.
I know it is possible to tweak the NB and HT link but I'm not sure how to do it properly.
bootup screen shows that DRAM clocking is 333MHz, but once booted CPU-Z says my RAM is running on 400MHz (DRAM Frequency 200MHz) so who is lying? smile.gif
This thread was also informative http://forum.corsair.com/v3/showthread.php?t=46100 the author said, that he actually lowered the RAM clock to get back to 400MHz (is it for the sake of syncing the clock speed??) but I don't know where to set this option.
Cheers
jj72 is offline
post #2 of 4 (permalink) Old 03-13-2015, 12:37 AM
Overclock Failed...
billbartuska's Avatar
Rep: 1249 (Unique: 969)
Neither. The boot screen says you have DDR 333 memory installed, CPU-Z says it's running at 400 MHz.
https://www.overclock.net/images/smil...lame-small.gif5 GHz Overclock Club https://www.overclock.net/images/smil...lame-small.gifMisinformation is available from a variety of other sources. Misinformation is just like real information but wrong
....and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 4 (permalink) Old 03-13-2015, 12:48 AM - Thread Starter
jj72's Avatar
Rep: 0
Well, all RAMs are PC3200 (confirmed by CPU-Z), meaning it should've been DDR 400. DDR 333 is PC2700, isn't it?
jj72 is offline
post #4 of 4 (permalink) Old 03-13-2015, 01:17 AM
Overclock Failed...
Ah yes, I see that in your original post. Then I don't know what's going on. They should agree.
