Regarding the recent FUD about "Ryzen Timing Checker" (RTC) - Page 2 - Overclock.net - An Overclocking Community
View Poll Results: Has using "Ryzen Timing Checker" caused any issues on your system?
Yes (please elaborate in a separate post) 6 6.38%
No 88 93.62%
Voters: 94. You may not vote on this poll
post #11 of 138 (permalink) Old 12-15-2017, 12:49 AM
Meddling user
gupsterg's Avatar
Rep: 786 (Unique: 360)
Absolutely horrified that certain members have no faith in revered member's apps.
I for one believe there would be an irreplaceable void within our online communities if it was not for the shares and help given by The Stilt. So Thank you for all you do thumb.gif .
Originally Posted by keng View Post
please contact AMD directly and you will more than likely have what you need provided you agree to a NDA.
Good luck, as even with NDA and registered as dev you may struggle.
I look forward to apps, bioses, etc from yourself in the future, so we don't have trojan, malware, etc wink.gif .
gupsterg is offline
post #12 of 138 (permalink) Old 12-15-2017, 08:10 AM
Shaav's Avatar
Rep: 1 (Unique: 1)
"Cannot initializte the driver!"
"The driver failed to initialize!"
Do you have any idea how I can fix this issue? I just donwloaded the program, extracted the zip file and started the program with admin permissions.
Shaav is offline
post #13 of 138 (permalink) Old 12-15-2017, 08:14 AM - Thread Starter
The Stilt's Avatar
Rep: 872 (Unique: 333)
The app is most likely blocked by Windows Defender, due being flagged as malware.
You need to add an exclusion for RTC.exe manually, if you want to use it.
The Stilt is offline
post #14 of 138 (permalink) Old 12-15-2017, 08:17 AM
Shaav's Avatar
Rep: 1 (Unique: 1)
I think I just did it, but it didn't help to solve the problem:
Shaav is offline
post #16 of 138 (permalink) Old 12-15-2017, 12:03 PM
Kayant's Avatar
Rep: 1 (Unique: 1)
Try adding the exe itself rather than folder
Kayant is offline
post #17 of 138 (permalink) Old 12-15-2017, 12:52 PM
Shaav's Avatar
Rep: 1 (Unique: 1)
I downloaded the program once more, added each file to that list, ran the program with admin rights but still receive the same error report. frown.gif
Shaav is offline
post #18 of 138 (permalink) Old 12-15-2017, 01:10 PM
In VB's Basement
ENTERPRISE's Avatar
Thanks for the explanation (Not that I personally needed it). Hopefully this will go someway to putting some peoples minds at rest. Personally I love member created applications. Homegrown/grassroots applications can be fantastic, mostly because they get the job done and they are free for the most part. What I love is if you meet a member who is making a useful App, you can communicate with them directly regarding ideas or support which for me makes all the difference !
Need help with your account or something forum related ? Please use our Contact Us form
ENTERPRISE is offline
post #19 of 138 (permalink) Old 12-15-2017, 01:19 PM - Thread Starter
The Stilt's Avatar
C++ port in progress.
Will test the code tomorrow and then start making a GUI for it. That's the hardest part for me, since I have no experience what so ever on GUI applications stun.gif
Getting rid of AutoIT should address the recent issues with the app being blocked by Windows Defender as well.
post #20 of 138 (permalink) Old 12-15-2017, 02:20 PM
Anty's Avatar
Rep: 10 (Unique: 10)
You may consider using Qt for it.
Ryzen 1700 ~ C6H ~ 4x8GB trident Z [email protected] ~ EVGA 1080Ti
Anty is offline
