Has using "Ryzen Timing Checker" caused any issues on your system?
  • Yes (please elaborate in a separate post)
    Votes: 6 6.4%
  • No
    Votes: 88 93.6%
Regarding the recent FUD about "Ryzen Timing Checker" (RTC)
33K views 137 replies 51 participants last post by  gupsterg
#1 ·
During the past couple days a certain person (or persons) have been spreading blatant lies about the "Ryzen Timing Checker", claiming that it features malware and puts the systems it has been executed on in immediate risk.
Several additional claims regarding various aspects of it have been made by the same person, but listing all of them would be rather futile as some of the claims are outright insane (some of the claims about me e.g. working for "an outfit" can still be found from other topic on this forum).
So what Ryzen Timing Checker actually is and what exactly does it do?
RTC is a tiny application which can be used to read most of the DRAM timings on Zeppelin and Raven based CPUs and APUs. RTC accesses the DRAM timing (UMC) registers through the standard access port located in the PCI config space (SBDF). It uses a separate WinRing0 driver to access the hardware, because Windows (unlike Linux) doesn't provide a built-in access. Upon starting the RTC it executes several predefined PCI read and write operations (to the SMU data ports) and an additional MSR read operation (in order to check the platform compability). Once the program has finished reading the necessary registers, it displays the results and waits until the GUI window is terminated by the user. It doesn't perform any actions once the GUI is visible and never accesses the internet or the memory space.
How Ryzen Timing Checker was coded?
RTC uses AutoIT engine (version 3.3.14.2 to be specific). AutoIT is an automation language, and it's syntaxes are similar to BASIC. AutoIT is extremely versatile and based on my experience it is no lesser than the actual programming languages (C, C++, etc.) in terms of functionality, yet much more easier to produce code on.
AutoIT, like each and every other coding style / language has also been used for malicous purposes in the past. Because of that, some of the lesser AV solutions generally automatically flag all AutoIT executables as malware, regardless if there is anything malicious in them or not. Reputable AV providers such as F-Secure, Kaspersky or Symantec don't do that.
Read more about AutoIT: https://en.wikipedia.org/wiki/AutoIt
Check AutoIT's official website and user forum featuring > 72k members.
If there isn't anything malicious in the code, then why is the RTC binary distribution password protected and the binary itself encrypted?
The most convinient place for me (and the users downloading it) to host any file for the time being is OneDrive. There are several other potential places to host the files at, but none of the other free solutions are ad, popup and potentially malware (
) free. Based on my past experience OneDrive prevents downloading any archive, which contains an executable binary in it (regardless if it's e.g. the newest official Blender build). To prevent this behavior and to make it possible the users to download the app in the first place, the archive was password protected. That's simply a workaround for OneDrive's behavior, since it cannot block and archive containing an exe file if it cannot see it.
The RTC binary is not encrypted in any way. The RTC script is simply obfuscated in order to protect access methods and register information (i.e. which PCI device to access, which offsets and which SMU addresses), which as of now is still confidential. You can check if that's really the case by looking at the Zeppelin PPR available at AMD Techdocs: http://support.amd.com/TechDocs/54945_PPR_Family_17h_Models_00h-0Fh.pdf This document does not disclose (try seaching for a DRAM timing, e.g. tRFC) any of the information I just mentioned, and neither does any of the Github or Linux repos (as far as I know).
As said before, obfuscating the code makes it significantly harder to read (eventhou still possible) but it is by no means a method of encryption as it can still be read.
In order to end all of this crap that has been spread during the past couple days, I decided to release the non-obfuscated "source code" of the exact script used for RTC 1.01 version. The only changes which have been made to the code is related to confidential register info. In the sanitized version of the code the register addresses are set to zero. In order to compare the resulting code between the original release and the one you just compiled yourself, use following workflow:
How to audit the code?
- Download AutoIT: https://www.autoitscript.com/site/autoit/downloads/
- Install it
- Download the Obfuscator version used for RTC (AutoIt3 Source Obfuscator v1.0.30.4, by Jos van der Zande): https://1drv.ms/u/s!Ag6oE4SOsCmDhRTQg6bz8L_qyc8p (PW: Obfuscator)
- Save the script as Audit.au3
- Obfuscate the script source (.au3) using command "Obfuscator Audit.au3"
- Compile the resulting Audit_Obfuscated.au3 with AutoIT x64
- Download the original RTC 1.01 release: https://1drv.ms/u/s!Ag6oE4SOsCmDhQW33FeZaWSlOIds (PW: RyzenDRAM)
- Use 7-Zip to extract the compiled script from both of the exes (.rsrc\0\RCDATA\SCRIPT)
- Compare the sizes and other similarities
The size will differ by few bytes due to the sanitized register values, however you can verify that by changing them yourself as well.
Also try what happens if you make other kind of changes to the code.
#RequireAdmin
#NoTrayIcon
#include <EditConstants.au3>
#include <GUIConstantsEx.au3>
#include <WindowsConstants.au3>
If Not FileExists("WinRing0x64.dll") Then
   MsgBox(16, "Error: A missing component", "Part of the driver: WinRing0x64.dll is missing!")
   Exit
ElseIf Not FileExists("WinRing0x64.sys") Then
   MsgBox(16, "Error: A missing component", "Part of the driver: WinRing0x64.sys is missing!")
   Exit
EndIf
If FileExists("Slow.txt") Then
   $SMUDelay = 60
Else
   $SMUDelay = 20
EndIf
$DLL = DllOpen("WinRing0x64.dll")
$InitCheck = DllCall($DLL, "bool", "InitializeOls")
Sleep(100)
$DllCheck = DllCall($DLL, "dword", "GetDllStatus")
Sleep(100)
If $InitCheck[0] = 0 Then
   MsgBox(16, "Cannot initialize the driver!", "The driver failed to initialize!")
   Exit
EndIf
If $DllCheck[0] = 1 Then
   MsgBox(16, "Driver error", "This platform is not supported by the driver!")
   Exit
ElseIf $DllCheck[0] = 2 Then
   MsgBox(16, "Driver error", "The driver could not be loaded!")
   Exit
ElseIf $DllCheck[0] = 3 Then
   MsgBox(16, "Driver error", "The driver seems to be incomplete. Please relocate the files!")
   Exit
ElseIf $DllCheck[0] = 4 Then
   MsgBox(16, "Driver error", "The driver has been unloaded unexpectedly!")
   Exit
ElseIf $DllCheck[0] = 9 Then
   MsgBox(16, "Driver error", "An unspecified error has occured!")
   Exit
EndIf
$CPUID = ""
$CPUFMS = ""
$SMUORG = ""
$BGS = ""
$DramConfiguration = ""
$DramTiming1 = ""
$DramTiming2 = ""
$DramTiming3 = ""
$DramTiming4 = ""
$DramTiming5 = ""
$DramTiming6 = ""
$DramTiming7 = ""
$DramTiming8 = ""
$DramTiming9 = ""
$DramTiming10 = ""
$DramTiming12 = ""
$DramTiming13 = ""
$DramTiming20 = ""
$DramTiming21 = ""
$DramTiming22 = ""
$tRFCTiming0 = ""
$tRFCTiming1 = ""
$tSTAGTiming0 = ""
$tSTAGTiming1 = ""
$DramTiming35 = ""
$tRFCTiming = ""
$tSTAGTiming = ""
$Preamble2T = ""
$GDM = ""
$Cmd2T = ""
$MEMCLK = ""
$MEMCLKTRxx = ""
$tRCDWR = ""
$tRCDRD = ""
$tRAS = ""
$tCL = ""
$tRPPB = ""
$tRP = ""
$tRCPB = ""
$tRC = ""
$tRTP = ""
$tRRDDLR = ""
$tRRDL = ""
$tRRDS = ""
$tFAWDLR = ""
$tFAWSLR = ""
$tFAW = ""
$tWTRL = ""
$tWTRS = ""
$tCWL = ""
$tWR = ""
$tRCPage = ""
$tRDRDBAN = ""
$tRDRDSCL = ""
$tRDRDSCDLR = ""
$tRDRDSC = ""
$tRDRDSD = ""
$tRDRDDD = ""
$tWRWRBAN = ""
$tWRWRSCL = ""
$tWRWRSCDLR = ""
$tWRWRSC = ""
$tWRWRSD = ""
$tWRWRDD = ""
$tWRRDSCDLR = ""
$tRDWR = ""
$tWRRD = ""
$tREF = ""
$tREFCT = ""
$tMODPDA = ""
$tMRDPDA = ""
$tMOD = ""
$tMRD = ""
$tSTAG = ""
$tCKE = ""
$tPHYWRD = ""
$tPHYRDLAT = ""
$tPHYWRLAT = ""
$tRDDATA = ""
$tRFC4 = ""
$tRFC4CT = ""
$tRFC2 = ""
$tRFC2CT = ""
$tRFC = ""
$tRFCCT = ""
$tSTAG4LR = ""
$tSTAG2LR = ""
$tSTAGLR = ""
$tWRMPR = ""
$CPUID = DllCall($DLL, "dword", "CpuidPx", "dword", "0x80000001", "dword*", "", "dword*", "", "dword*", "", "dword*", "", "uint", "0x01")
$CPUFMS = BitAND($CPUID[2], 0xFFFF00)
If Not ($CPUFMS = "0x00800F00" Or $CPUFMS = "0x00810F00") Then
   Msgbox(16, "Error", "The software only supports RV & ZP based Ryzen CPUs")
   DllCall($DLL, "none", "DeinitializeOls")
   Exit
EndIf
$SMUORG = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
DllCall($DLL, "dword", "WritePciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "0x00000000")
Sleep($SMUDelay)
$BGS = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$BGSA = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramConfiguration = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming1 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming2 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming3 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming4 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming5 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming6 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming7 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming8 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming9 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming10 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming12 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming13 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming20 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming21 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming22 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$tRFCTiming0 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$tRFCTiming1 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$tSTAGTiming0 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$tSTAGTiming1 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming35 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
DllCall($DLL, "dword", "WritePciConfigDword", "byte", "0x00", "byte", "0x00", "dword", $SMUORG[0])
Sleep($SMUDelay)
If $tRFCTiming0[0] = $tRFCTiming1[0] Then ; Checks if 2DPC is used or if tRFC has been manually set.
   $tRFCTiming = $tRFCTiming0[0]
   $tSTAGTiming = $tSTAGTiming0[0]
ElseIf $tRFCTiming0[0] = 0x21060138 Then ; Checks if DIMM0 tRFC is set to AGESA defaults, meaning DIMM1 is populated.
   $tRFCTiming = $tRFCTiming1[0]
   $tSTAGTiming = $tSTAGTiming1[0]
Else
EndIf
If $BGS[0] = 2271560481 Then
   $BGS = "Disabled"
Else
   $BGS = "Enabled"
EndIf
If $BGSA[0] = 286328817 Then
   $BGSA = "Enabled"
Else
   $BGSA = "Disabled"
EndIf
$Preamble2T = BitAND($DramConfiguration[0], 0x1000)
$Preamble2T = BitShift($Preamble2T, 12)
If $Preamble2T = 1 Then
   $Preamble2T = "Enabled"
Else
   $Preamble2T = "Disabled"
EndIf
$GDM = BitAND($DramConfiguration[0], 0x800)
$GDM = BitShift($GDM, 11)
If $GDM = 1 Then
   $GDM = "Enabled"
Else
   $GDM = "Disabled"
EndIf
$Cmd2T = BitAND($DramConfiguration[0], 0x400)
$Cmd2T = BitShift($Cmd2T, 10)
If $Cmd2T = 1 Then
   $Cmd2T = "2T"
Else
   $Cmd2T = "1T"
EndIf
$MEMCLK = BitAND($DramConfiguration[0], 0x7F)
$MEMCLKTRxx = ($MEMCLK / 3) * 100
$MEMCLK = Int(($MEMCLK / 3) * 200)
$tRCDWR = BitAND($DramTiming1[0], 0x3F000000)
$tRCDWR = BitShift($tRCDWR, 24)
$tRCDRD = BitAND($DramTiming1[0], 0x3F0000)
$tRCDRD = BitShift($tRCDRD, 16)
$tRAS = BitAND($DramTiming1[0], 0x7F00)
$tRAS = BitShift($tRAS, 8)
$tCL = BitAND($DramTiming1[0], 0x3F)
$tRPPB = BitAND($DramTiming2[0], 0x3F000000)
$tRPPB = BitShift($tRPPB, 24)
$tRP = BitAND($DramTiming2[0], 0x3F0000)
$tRP = BitShift($tRP, 16)
$tRCPB = BitAND($DramTiming2[0], 0xFF00)
$tRCPB = BitShift($tRCPB, 8)
$tRC = BitAND($DramTiming2[0], 0xFF)
$tRTP = BitAND($DramTiming3[0], 0x1F000000)
$tRTP = BitShift($tRTP, 24)
$tRRDDLR = BitAND($DramTiming3[0], 0x1F0000)
$tRRDDLR = BitShift($tRRDDLR, 16)
$tRRDL = BitAND($DramTiming3[0], 0x1F00)
$tRRDL = BitShift($tRRDL, 8)
$tRRDS = BitAND($DramTiming3[0], 0x1F)
$tFAWDLR = BitAND($DramTiming4[0], 0x7E000000)
$tFAWDLR = BitShift($tFAWDLR, 25)
$tFAWSLR = BitAND($DramTiming4[0], 0xFC0000)
$tFAWSLR = BitShift($tFAWSLR, 18)
$tFAW = BitAND($DramTiming4[0], 0x7F)
$tWTRL = BitAND($DramTiming5[0], 0x7F0000)
$tWTRL = BitShift($tWTRL, 16)
$tWTRS = BitAND($DramTiming5[0], 0x1F00)
$tWTRS = BitShift($tWTRS, 8)
$tCWL = BitAND($DramTiming5[0], 0x3F)
$tWR = BitAND($DramTiming6[0], 0x7F)
$tRCPage = BitAND($DramTiming7[0], 0xFFF00000)
$tRCPage = BitShift($tRCPage, 20)
$tRDRDBAN = BitAND($DramTiming8[0], 0xC0000000)
$tRDRDBAN = BitShift($tRDRDBAN, 30)
If $tRDRDBAN = 0 Then
   $tRDRDBAN = "Disabled"
ElseIf $tRDRDBAN = 1 Then
   $tRDRDBAN = "Ban 2"
ElseIf $tRDRDBAN = 2 Then
   $tRDRDBAN = "Ban 2&3"
EndIf
$tRDRDSCL = BitAND($DramTiming8[0], 0xF000000)
$tRDRDSCL = BitShift($tRDRDSCL, 24)
$tRDRDSCDLR = BitAND($DramTiming8[0], 0xF00000)
$tRDRDSCDLR = BitShift($tRDRDSCDLR, 20)
$tRDRDSC = BitAND($DramTiming8[0], 0xF0000)
$tRDRDSC = BitShift($tRDRDSC, 16)
$tRDRDSD = BitAND($DramTiming8[0], 0xF00)
$tRDRDSD = BitShift($tRDRDSD, 8)
$tRDRDDD = BitAND($DramTiming8[0], 0xF)
$tWRWRBAN = BitAND($DramTiming9[0], 0xC0000000)
$tWRWRBAN = BitShift($tWRWRBAN, 30)
If $tWRWRBAN = 0 Then
   $tWRWRBAN = "Disabled"
ElseIf $tWRWRBAN = 1 Then
   $tWRWRBAN = "Ban 2"
ElseIf $tWRWRBAN = 2 Then
   $tWRWRBAN = "Ban 2&3"
EndIf
$tWRWRSCL = BitAND($DramTiming9[0], 0x3F000000)
$tWRWRSCL = BitShift($tWRWRSCL, 24)
$tWRWRSCDLR = BitAND($DramTiming9[0], 0xF00000)
$tWRWRSCDLR = BitShift($tWRWRSCDLR, 20)
$tWRWRSC = BitAND($DramTiming9[0], 0xF0000)
$tWRWRSC = BitShift($tWRWRSC, 16)
$tWRWRSD = BitAND($DramTiming9[0], 0xF00)
$tWRWRSD = BitShift($tWRWRSD, 8)
$tWRWRDD = BitAND($DramTiming9[0], 0xF)
$tWRRDSCDLR = BitAND($DramTiming10[0], 0x1F0000)
$tWRRDSCDLR = BitShift($tWRRDSCDLR, 16)
$tRDWR = BitAND($DramTiming10[0], 0x1F00)
$tRDWR = BitShift($tRDWR, 8)
$tWRRD = BitAND($DramTiming10[0], 0xF)
$tREF = BitAND($DramTiming12[0], 0xFFFF)
$tREFCT = Int(((1000 / $MEMCLKTRxx) * $tREF))
$tMODPDA = BitAND($DramTiming13[0], 0x3F000000)
$tMODPDA = BitShift($tMODPDA, 24)
$tMRDPDA = BitAND($DramTiming13[0], 0x3F0000)
$tMRDPDA = BitShift($tMRDPDA, 16)
$tMOD = BitAND($DramTiming13[0], 0x3F00)
$tMOD = BitShift($tMOD, 8)
$tMRD = BitAND($DramTiming13[0], 0x3F)
$tSTAG = BitAND($DramTiming20[0], 0xFF0000)
$tSTAG = BitShift($tSTAG, 16)
$tCKE = BitAND($DramTiming21[0], 0x1F000000)
$tCKE = BitShift($tCKE, 24)
$tPHYWRD = BitAND($DramTiming22[0], 0x7000000)
$tPHYWRD = BitShift($tPHYWRD, 24)
$tPHYRDLAT = BitAND($DramTiming22[0], 0x3F0000)
$tPHYRDLAT = BitShift($tPHYRDLAT, 16)
$tPHYWRLAT = BitAND($DramTiming22[0], 0x1F00)
$tPHYWRLAT = BitShift($tPHYWRLAT, 8)
$tRDDATA = BitAND($DramTiming22[0], 0x7F)
$tRFC4 = BitAND($tRFCTiming, 0xFFC00000)
$tRFC4 = BitShift($tRFC4, 22)
$tRFC4CT = Round(((1000 / $MEMCLKTRxx) * $tRFC4), 3)
$tRFC2 = BitAND($tRFCTiming, 0x3FF800)
$tRFC2 = BitShift($tRFC4, 11)
$tRFC2CT = Round(((1000 / $MEMCLKTRxx) * $tRFC2), 3)
$tRFC = BitAND($tRFCTiming, 0x7FF)
$tRFCCT = Round(((1000 / $MEMCLKTRxx) * $tRFC), 3)
$tSTAG4LR = BitAND($tSTAGTiming, 0x1FF00000)
$tSTAG4LR = BitShift($tSTAG4LR, 20)
If $tSTAG4LR = 0 Then
   $tSTAG4LR = "Disabled"
EndIf
$tSTAG2LR = BitAND($tSTAGTiming, 0x7FC00)
$tSTAG2LR = BitShift($tSTAG2LR, 10)
If $tSTAG2LR = 0 Then
   $tSTAG2LR = "Disabled"
EndIf
$tSTAGLR = BitAND($tSTAGTiming, 0x1FF)
If $tSTAGLR = 0 Then
   $tSTAGLR = "Disabled"
EndIf
$tWRMPR = BitAND($DramTiming35[0], 0x3F000000)
$tWRMPR = BitShift($tWRMPR, 24)
$RTC = GUICreate("Ryzen Timing Checker", 520, 600, 192, 124)
$MEMCLKBox = GUICtrlCreateInput($MEMCLK, 10, 14, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
GUICtrlSetFont(-1, 8, 400, 0, "Arial")
$MEMCLKLabel = GUICtrlCreateLabel("MEMCLK Ratio", 80, 17, 95, 17)
GUICtrlSetFont(-1, 8, 800, 0, "Arial")
GUICtrlSetState($MEMCLKBox, $GUI_DISABLE)
$Cmd2tBox = GUICtrlCreateInput($GDM, 170, 14, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$Cmd2tLabel = GUICtrlCreateLabel("GearDownMode", 240, 17, 85, 17)
GUICtrlSetState($Cmd2tBox, $GUI_DISABLE)
$GDMBox = GUICtrlCreateInput($Cmd2t, 10, 44, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$GDMLabel = GUICtrlCreateLabel("Cmd2t", 80, 47, 70, 17)
GUICtrlSetState($GDMBox, $GUI_DISABLE)
$BGSBox = GUICtrlCreateInput($BGS, 170, 44, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$BGSLabel = GUICtrlCreateLabel("BankGroupSwap", 240, 47, 85, 17)
GUICtrlSetState($BGSBox, $GUI_DISABLE)
$BGSABox = GUICtrlCreateInput($BGSA, 330, 14, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$BGSALabel = GUICtrlCreateLabel("BankGroupSwapAlt", 400, 17, 100, 17)
GUICtrlSetState($BGSABox, $GUI_DISABLE)
$tCLBox = GUICtrlCreateInput($tCL, 10, 94, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tCLLabel = GUICtrlCreateLabel("tCL", 80, 97, 70, 17)
GUICtrlSetState($tCLBox, $GUI_DISABLE)
$tRCDWRBox = GUICtrlCreateInput($tRCDWR, 10, 124, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRCDWRLabel = GUICtrlCreateLabel("tRCDWR", 80, 127, 70, 17)
GUICtrlSetState($tRCDWRBox, $GUI_DISABLE)
$tRCDRDBox = GUICtrlCreateInput($tRCDRD, 10, 154, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRCDRDLabel = GUICtrlCreateLabel("tRCDRD", 80, 157, 70, 17)
GUICtrlSetState($tRCDRDBox, $GUI_DISABLE)
$tRPBox = GUICtrlCreateInput($tRP, 10, 184, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRPLabel = GUICtrlCreateLabel("tRP", 80, 187, 70, 17)
GUICtrlSetState($tRPBox, $GUI_DISABLE)
$tRASBox = GUICtrlCreateInput($tRAS, 10, 214, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRASLabel = GUICtrlCreateLabel("tRAS", 80, 217, 70, 17)
GUICtrlSetState($tRASBox, $GUI_DISABLE)
$tRCBox = GUICtrlCreateInput($tRC, 10, 244, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRCLabel = GUICtrlCreateLabel("tRC", 80, 247, 70, 17)
GUICtrlSetState($tRCBox, $GUI_DISABLE)
$tRRDSBox = GUICtrlCreateInput($tRRDS, 10, 274, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRRDSLabel = GUICtrlCreateLabel("tRRDS", 80, 277, 70, 17)
GUICtrlSetState($tRRDSBox, $GUI_DISABLE)
$tRRDLBox = GUICtrlCreateInput($tRRDL, 10, 304, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRRDLLabel = GUICtrlCreateLabel("tRRDL", 80, 307, 70, 17)
GUICtrlSetState($tRRDLBox, $GUI_DISABLE)
$tFAWBox = GUICtrlCreateInput($tFAW, 10, 334, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tFAWLabel = GUICtrlCreateLabel("tFAW", 80, 337, 70, 17)
GUICtrlSetState($tFAWBox, $GUI_DISABLE)
$tFAWDLRBox = GUICtrlCreateInput($tFAWDLR, 10, 364, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tFAWDLRLabel = GUICtrlCreateLabel("tFAWDLR", 80, 367, 70, 17)
GUICtrlSetState($tFAWDLRBox, $GUI_DISABLE)
$tFAWSLRBox = GUICtrlCreateInput($tFAWSLR, 10, 394, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tFAWSLRLabel = GUICtrlCreateLabel("tFAWSLR", 80, 397, 70, 17)
GUICtrlSetState($tFAWSLRBox, $GUI_DISABLE)
$tWTRSBox = GUICtrlCreateInput($tWTRS, 10, 424, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWTRSLabel = GUICtrlCreateLabel("tWTRS", 80, 427, 70, 17)
GUICtrlSetState($tWTRSBox, $GUI_DISABLE)
$tWTRLBox = GUICtrlCreateInput($tWTRL, 10, 454, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWTRLLabel = GUICtrlCreateLabel("tWTRL", 80, 457, 70, 17)
GUICtrlSetState($tWTRLBox, $GUI_DISABLE)
$tWRBox = GUICtrlCreateInput($tWR, 10, 484, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRLabel = GUICtrlCreateLabel("tWR", 80, 487, 70, 17)
GUICtrlSetState($tWRBox, $GUI_DISABLE)
$tRCPageBox = GUICtrlCreateInput($tRCPage, 10, 514, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRCPageLabel = GUICtrlCreateLabel("tRCPage", 80, 517, 70, 17)
GUICtrlSetState($tRCPageBox, $GUI_DISABLE)
$tRDRDSCLBox = GUICtrlCreateInput($tRDRDSCL, 10, 544, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDSCLLabel = GUICtrlCreateLabel("tRDRDSCL", 80, 547, 70, 17)
GUICtrlSetState($tRDRDSCLBox, $GUI_DISABLE)
$tWRWRSCLBox = GUICtrlCreateInput($tWRWRSCL, 10, 574, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRSCLLabel = GUICtrlCreateLabel("tWRWRSCL", 80, 577, 70, 17)
GUICtrlSetState($tWRWRSCLBox, $GUI_DISABLE)
$tRFCBox = GUICtrlCreateInput($tRFC, 170, 94, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRFCLabel = GUICtrlCreateLabel("tRFC", 240, 97, 70, 17)
GUICtrlSetState($tRFCBox, $GUI_DISABLE)
$tRFCCTBox = GUICtrlCreateInput($tRFCCT, 170, 124, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRFCCTLabel = GUICtrlCreateLabel("tRFC (ns)", 240, 127, 70, 17)
GUICtrlSetState($tRFCCTBox, $GUI_DISABLE)
$tCWLBox = GUICtrlCreateInput($tCWL, 170, 154, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tCWLLabel = GUICtrlCreateLabel("tCWL", 240, 157, 70, 17)
GUICtrlSetState($tCWLBox, $GUI_DISABLE)
$tRTPBox = GUICtrlCreateInput($tRTP, 170, 184, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRTPLabel = GUICtrlCreateLabel("tRTP", 240, 187, 70, 17)
GUICtrlSetState($tRTPBox, $GUI_DISABLE)
$tRDWRBox = GUICtrlCreateInput($tRDWR, 170, 214, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDWRLabel = GUICtrlCreateLabel("tRDWR", 240, 217, 70, 17)
GUICtrlSetState($tRDWRBox, $GUI_DISABLE)
$tWRRDBox = GUICtrlCreateInput($tWRRD, 170, 244, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRRDLabel = GUICtrlCreateLabel("tWRRD", 240, 247, 70, 17)
GUICtrlSetState($tWRRDBox, $GUI_DISABLE)
$tWRWRSCBox = GUICtrlCreateInput($tWRWRSC, 170, 274, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRSCLabel = GUICtrlCreateLabel("tWRWRSC", 240, 277, 70, 17)
GUICtrlSetState($tWRWRSCBox, $GUI_DISABLE)
$tWRWRSDBox = GUICtrlCreateInput($tWRWRSD, 170, 304, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRSDLabel = GUICtrlCreateLabel("tWRWRSD", 240, 307, 70, 17)
GUICtrlSetState($tWRWRSDBox, $GUI_DISABLE)
$tWRWRDDBox = GUICtrlCreateInput($tWRWRDD, 170, 334, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRDDLabel = GUICtrlCreateLabel("tWRWRDD", 240, 337, 70, 17)
GUICtrlSetState($tWRWRDDBox, $GUI_DISABLE)
$tRDRDSCBox = GUICtrlCreateInput($tRDRDSC, 170, 364, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDSCLabel = GUICtrlCreateLabel("tRDRDSC", 240, 367, 70, 17)
GUICtrlSetState($tRDRDSCBox, $GUI_DISABLE)
$tRDRDSDBox = GUICtrlCreateInput($tRDRDSD, 170, 394, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDSDLabel = GUICtrlCreateLabel("tRDRDSD", 240, 397, 70, 17)
GUICtrlSetState($tRDRDSDBox, $GUI_DISABLE)
$tRDRDDDBox = GUICtrlCreateInput($tRDRDDD, 170, 424, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDDDLabel = GUICtrlCreateLabel("tRDRDDD", 240, 427, 70, 17)
GUICtrlSetState($tRDRDDDBox, $GUI_DISABLE)
$tCKEBox = GUICtrlCreateInput($tCKE, 170, 454, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tCKELabel = GUICtrlCreateLabel("tCKE", 240, 457, 70, 17)
GUICtrlSetState($tCKEBox, $GUI_DISABLE)
$tRPPBBox = GUICtrlCreateInput($tRPPB, 170, 484, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRPPBLabel = GUICtrlCreateLabel("tRPPB", 240, 487, 70, 17)
GUICtrlSetState($tRPPBBox, $GUI_DISABLE)
$tRCPBBox = GUICtrlCreateInput($tRCPB, 170, 514, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRCPBLabel = GUICtrlCreateLabel("tRCPB", 240, 517, 70, 17)
GUICtrlSetState($tRCPBBox, $GUI_DISABLE)
$tRRDDLRBox = GUICtrlCreateInput($tRRDDLR, 170, 544, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRRDDLRLabel = GUICtrlCreateLabel("tRRDDLR", 240, 547, 70, 17)
GUICtrlSetState($tRRDDLRBox, $GUI_DISABLE)
$tRDRDBANBox = GUICtrlCreateInput($tRDRDBAN, 170, 574, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDBANLabel = GUICtrlCreateLabel("tRDRDBAN", 240, 577, 70, 17)
GUICtrlSetState($tRDRDBANBox, $GUI_DISABLE)
$tRDRDSCDLRBox = GUICtrlCreateInput($tRDRDSCDLR, 330, 94, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDSCDLRLabel = GUICtrlCreateLabel("tRDRDSCDLR", 400, 97, 70, 17)
GUICtrlSetState($tRDRDSCDLRBox, $GUI_DISABLE)
$tWRWRBANBox = GUICtrlCreateInput($tWRWRBAN, 330, 124, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRBANLabel = GUICtrlCreateLabel("tWRWRBAN", 400, 127, 70, 17)
GUICtrlSetState($tWRWRBANBox, $GUI_DISABLE)
$tWRWRSCDLRBox = GUICtrlCreateInput($tWRWRSCDLR, 330, 154, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRSCDLRLabel = GUICtrlCreateLabel("tWRWRSCDLR", 400, 157, 70, 17)
GUICtrlSetState($tWRWRSCDLRBox, $GUI_DISABLE)
$tWRRDSCDLRBox = GUICtrlCreateInput($tWRRDSCDLR, 330, 184, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRRDSCDLRLabel = GUICtrlCreateLabel("tWRRDSCDLR", 400, 187, 70, 17)
GUICtrlSetState($tWRRDSCDLRBox, $GUI_DISABLE)
$tREFBox = GUICtrlCreateInput($tREF, 330, 214, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tREFLabel = GUICtrlCreateLabel("tREF", 400, 217, 70, 17)
GUICtrlSetState($tREFBox, $GUI_DISABLE)
$tREFCTBox = GUICtrlCreateInput($tREFCT, 330, 244, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tREFCTLabel = GUICtrlCreateLabel("tREF (ns)", 400, 247, 70, 17)
GUICtrlSetState($tREFCTBox, $GUI_DISABLE)
$tMODBox = GUICtrlCreateInput($tMOD, 330, 274, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tMODLabel = GUICtrlCreateLabel("tMOD", 400, 277, 70, 17)
GUICtrlSetState($tMODBox, $GUI_DISABLE)
$tMODPDABox = GUICtrlCreateInput($tMODPDA, 330, 304, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tMODPDALabel = GUICtrlCreateLabel("tMODPDA", 400, 307, 70, 17)
GUICtrlSetState($tMODPDABox, $GUI_DISABLE)
$tMRDBox = GUICtrlCreateInput($tMRD, 330, 334, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tMRDLabel = GUICtrlCreateLabel("tMRD", 400, 337, 70, 17)
GUICtrlSetState($tMRDBox, $GUI_DISABLE)
$tMRDPDABox = GUICtrlCreateInput($tMRDPDA, 330, 364, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tMRDPDALabel = GUICtrlCreateLabel("tMRDPDA", 400, 367, 70, 17)
GUICtrlSetState($tMRDPDABox, $GUI_DISABLE)
$tSTAGBox = GUICtrlCreateInput($tSTAG, 330, 394, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tSTAGLabel = GUICtrlCreateLabel("tSTAG", 400, 397, 70, 17)
GUICtrlSetState($tSTAGBox, $GUI_DISABLE)
$tPHYWRDBox = GUICtrlCreateInput($tPHYWRD, 330, 424, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tPHYWRDLabel = GUICtrlCreateLabel("tPHYWRD", 400, 427, 70, 17)
GUICtrlSetState($tPHYWRDBox, $GUI_DISABLE)
$tPHYWRLBox = GUICtrlCreateInput($tPHYWRLAT, 330, 454, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tPHYWRLLabel = GUICtrlCreateLabel("tPHYWRL", 400, 457, 70, 17)
GUICtrlSetState($tPHYWRLBox, $GUI_DISABLE)
$tPHYRDLBox = GUICtrlCreateInput($tPHYRDLAT, 330, 484, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tPHYRDLLabel = GUICtrlCreateLabel("tPHYRDL", 400, 487, 70, 17)
GUICtrlSetState($tPHYRDLBox, $GUI_DISABLE)
$tRDDATABox = GUICtrlCreateInput($tRDDATA, 330, 514, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDDATALabel = GUICtrlCreateLabel("tRDDATA", 400, 517, 70, 17)
GUICtrlSetState($tRDDATABox, $GUI_DISABLE)
$tSTAGLRBox = GUICtrlCreateInput($tSTAGLR, 330, 544, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tSTAGLRLabel = GUICtrlCreateLabel("tSTAGLR", 400, 547, 70, 17)
GUICtrlSetState($tSTAGLRBox, $GUI_DISABLE)
$tWRMPRBox = GUICtrlCreateInput($tWRMPR, 330, 574, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRMPRLabel = GUICtrlCreateLabel("tWRMPR", 400, 577, 70, 17)
GUICtrlSetState($tWRMPRBox, $GUI_DISABLE)
GUISetState(@SW_SHOW)
While 1
        $nMsg = GUIGetMsg()
        Switch $nMsg
        Case $GUI_EVENT_CLOSE
                        Exit
        EndSwitch
WEnd
#104 ·
@The Stilt_stilt I think I know ...well your are saying it...I have to shut down my my asus aura and lighting something in services before running RTC 1.04 or Paid thaiphoon burner it it just does not read things right. To get correct readings at least with RGB ram you MUST shut all these services all.
This does not occur with my non RGB ram.
#105 ·
Yeah, I expected problems from implementing SMBUS support but unfortunately it is the only way to determine the actual DIMM configuration on this platform.
Normally this information would be available from the hardware registers, but thats not the case with Ryzen.
Most of the things on this platform require a crap load of workarounds, as the original implementations are usually a total hack job to begin with.
It seems unbelievable to me that something as non trivial as the RGB cancer is allowed to pollute an internal system bus.
I have basically no other option but to drop the feature in the next version, as the hardware isn't up to the job to make it work without any potential issues.
#109 ·
Use kaspersky at your own risk.
My puter WAS hacked by the russians and used in the DDOS attack on the French elections in 2016. The French government informed me of this and later confirmed that the DDOS attack originated at a known black ops center in moscow.
My puter was also used in repeated DDOS attacks against VoteVets.org. I am a member of VoteVets.org so this was especially galling. You all know VoteVets.org. They are the veterans group that was banned by trumpskiy.
Donald Trump Just Blocked a Massive Veterans' Group on Twitter
#110 ·
For me Ryzen Checker doesn't work properly after I updated to 1.0.0.3 AGESA even when I reverted back .
#112 ·
Non issue on C6H UEFI 6201 C7H UEFI 0804. Only on most recent ZE UEFI I have most of top section being not read correctly, revert to older UEFI (1003) non issue for RTC reading of values.
#114 ·
Dunno. I have W7 on C7H and W10 on ZE, neither has an issue opening the app.
#116 ·
I had this bug as well, I think a motherboard swap triggered it but not completely sure. The only way around I found is reinstalling Windows, which is quite radical but there is nothing alike and this soft is quite handy (I prefer a clean installation when I change motherboard anyway)
#117 ·
Appreciated, Thanks for the tip, yeah i know a windows reinstall might work, but i haven't had much time lately to do so, the program worked before, it's the same board, it just doesn't work now and i was hoping someone would have a fix, I'll have to find some time in the future for a reinstall.
#118 · (Edited)
Problems.. to read system settings with 1.0.3 and 1.0.4
Hello all;
My problem is that readings are not completed (ProcODT, ...)
what is happening?
See screen:
THANKS IN ADVANCE.
#119 ·
Hello all;
what is happening?
See screen:
THANKS IN ADVANCE.
Same,, it worked fine before, now it doesn't.. I don't know what affect this changes !
#120 ·
Had following text added to the TPU download page, around a week ago:
Starting from AGESA version "Combo-AM4 0.0.7.2" the displayed values for APOB parsed values (ProcODT, AddrCmd/CsOdt/Cke -setup, Rtts and DriveStrengths) are broken.
At least for now, the issue cannot be fixed due to the total lack of documentation and support.
From now on, please consider "Ryzen Timing Checker" as discontinued and therefore unsupported.
#121 ·
Thank you Stilt. I'll still use it even if it is no longer supported . At my own risk:)
#123 ·
Ugh. Windows Security started flagging it again. I got Win32/Fuery.B!cl
Is it possible that it some how got tampered with on the hosting side? Or is this just another false positive again. Using RTC 1.05.
#127 ·
Welp MS is starting to flag it again.
#128 ·
Unfortunately there is nothing I can do about it, besides suggesting to disable the MS crap altogether and getting some proper AV.
Personally I use Kaspersky, but many people don't like it because its a Russian company. A valid point, but for me personally it makes no difference if the
information is received either by GRU or CIA :D
#135 ·
Your welcome,
yup it is a shame....
#136 ·
@The Stilt
TR1/2 has had no luv my AMD in Ryzen Master to show as much information as Zen2 does and as it seems it's unlikely any AGESA updates will occur on X399, any chance of an update to RTC?
#137 ·
@The Stilt
I don't think so :(
There are no static locations to read this info from and even if you somehow manage to locate the information through some unorthodox workaround, there is no guarantee that the location or even the format is the same between the different motherboards, bios versions and sometimes even settings.
#138 ·
Ok I understand and thanks for reply :) . Most of RTC works well, only ProODT to CKEDrvStr values haven't shown correctly for while, ahh well, will rant on r/AMD and tag Robert Hallock to improve Ryzen Master! LOL
