Regarding the recent FUD about "Ryzen Timing Checker" (RTC) - Overclock.net - An Overclocking Community
View Poll Results: Has using "Ryzen Timing Checker" caused any issues on your system?
Yes (please elaborate in a separate post) 6 6.38%
No 88 93.62%
Voters: 94. You may not vote on this poll
post #1 of 138 (permalink) Old 12-14-2017, 10:44 AM - Thread Starter
The Stilt's Avatar
Rep: 872 (Unique: 333)
During the past couple days a certain person (or persons) have been spreading blatant lies about the "Ryzen Timing Checker", claiming that it features malware and puts the systems it has been executed on in immediate risk.
Several additional claims regarding various aspects of it have been made by the same person, but listing all of them would be rather futile as some of the claims are outright insane (some of the claims about me e.g. working for "an outfit" can still be found from other topic on this forum).
So what Ryzen Timing Checker actually is and what exactly does it do?
RTC is a tiny application which can be used to read most of the DRAM timings on Zeppelin and Raven based CPUs and APUs. RTC accesses the DRAM timing (UMC) registers through the standard access port located in the PCI config space (SBDF). It uses a separate WinRing0 driver to access the hardware, because Windows (unlike Linux) doesn't provide a built-in access. Upon starting the RTC it executes several predefined PCI read and write operations (to the SMU data ports) and an additional MSR read operation (in order to check the platform compability). Once the program has finished reading the necessary registers, it displays the results and waits until the GUI window is terminated by the user. It doesn't perform any actions once the GUI is visible and never accesses the internet or the memory space.
How Ryzen Timing Checker was coded?
RTC uses AutoIT engine (version 3.3.14.2 to be specific). AutoIT is an automation language, and it's syntaxes are similar to BASIC. AutoIT is extremely versatile and based on my experience it is no lesser than the actual programming languages (C, C++, etc.) in terms of functionality, yet much more easier to produce code on.
AutoIT, like each and every other coding style / language has also been used for malicous purposes in the past. Because of that, some of the lesser AV solutions generally automatically flag all AutoIT executables as malware, regardless if there is anything malicious in them or not. Reputable AV providers such as F-Secure, Kaspersky or Symantec don't do that.
Read more about AutoIT: https://en.wikipedia.org/wiki/AutoIt
Check AutoIT's official website and user forum featuring > 72k members.
If there isn't anything malicious in the code, then why is the RTC binary distribution password protected and the binary itself encrypted?
The most convinient place for me (and the users downloading it) to host any file for the time being is OneDrive. There are several other potential places to host the files at, but none of the other free solutions are ad, popup and potentially malware ( wink.gif ) free. Based on my past experience OneDrive prevents downloading any archive, which contains an executable binary in it (regardless if it's e.g. the newest official Blender build). To prevent this behavior and to make it possible the users to download the app in the first place, the archive was password protected. That's simply a workaround for OneDrive's behavior, since it cannot block and archive containing an exe file if it cannot see it.
The RTC binary is not encrypted in any way. The RTC script is simply obfuscated in order to protect access methods and register information (i.e. which PCI device to access, which offsets and which SMU addresses), which as of now is still confidential. You can check if that's really the case by looking at the Zeppelin PPR available at AMD Techdocs: http://support.amd.com/TechDocs/54945_PPR_Family_17h_Models_00h-0Fh.pdf This document does not disclose (try seaching for a DRAM timing, e.g. tRFC) any of the information I just mentioned, and neither does any of the Github or Linux repos (as far as I know).
As said before, obfuscating the code makes it significantly harder to read (eventhou still possible) but it is by no means a method of encryption as it can still be read.
In order to end all of this crap that has been spread during the past couple days, I decided to release the non-obfuscated "source code" of the exact script used for RTC 1.01 version. The only changes which have been made to the code is related to confidential register info. In the sanitized version of the code the register addresses are set to zero. In order to compare the resulting code between the original release and the one you just compiled yourself, use following workflow:
How to audit the code?
- Download AutoIT: https://www.autoitscript.com/site/autoit/downloads/
- Install it
- Download the Obfuscator version used for RTC (AutoIt3 Source Obfuscator v1.0.30.4, by Jos van der Zande): https://1drv.ms/u/s!Ag6oE4SOsCmDhRTQg6bz8L_qyc8p (PW: Obfuscator)
- Save the script as Audit.au3
- Obfuscate the script source (.au3) using command "Obfuscator Audit.au3"
- Compile the resulting Audit_Obfuscated.au3 with AutoIT x64
- Download the original RTC 1.01 release: https://1drv.ms/u/s!Ag6oE4SOsCmDhQW33FeZaWSlOIds (PW: RyzenDRAM)
- Use 7-Zip to extract the compiled script from both of the exes (.rsrc\0\RCDATA\SCRIPT)
- Compare the sizes and other similarities
The size will differ by few bytes due to the sanitized register values, however you can verify that by changing them yourself as well.
Also try what happens if you make other kind of changes to the code.
RTC 1.01 SCRIPT SOURCE (Click to show)
#RequireAdmin
#NoTrayIcon
#include <EditConstants.au3>
#include <GUIConstantsEx.au3>
#include <WindowsConstants.au3>
If Not FileExists("WinRing0x64.dll") Then
   MsgBox(16, "Error: A missing component", "Part of the driver: WinRing0x64.dll is missing!")
   Exit
ElseIf Not FileExists("WinRing0x64.sys") Then
   MsgBox(16, "Error: A missing component", "Part of the driver: WinRing0x64.sys is missing!")
   Exit
EndIf
If FileExists("Slow.txt") Then
   $SMUDelay = 60
Else
   $SMUDelay = 20
EndIf
$DLL = DllOpen("WinRing0x64.dll")
$InitCheck = DllCall($DLL, "bool", "InitializeOls")
Sleep(100)
$DllCheck = DllCall($DLL, "dword", "GetDllStatus")
Sleep(100)
If $InitCheck[0] = 0 Then
   MsgBox(16, "Cannot initialize the driver!", "The driver failed to initialize!")
   Exit
EndIf
If $DllCheck[0] = 1 Then
   MsgBox(16, "Driver error", "This platform is not supported by the driver!")
   Exit
ElseIf $DllCheck[0] = 2 Then
   MsgBox(16, "Driver error", "The driver could not be loaded!")
   Exit
ElseIf $DllCheck[0] = 3 Then
   MsgBox(16, "Driver error", "The driver seems to be incomplete. Please relocate the files!")
   Exit
ElseIf $DllCheck[0] = 4 Then
   MsgBox(16, "Driver error", "The driver has been unloaded unexpectedly!")
   Exit
ElseIf $DllCheck[0] = 9 Then
   MsgBox(16, "Driver error", "An unspecified error has occured!")
   Exit
EndIf
$CPUID = ""
$CPUFMS = ""
$SMUORG = ""
$BGS = ""
$DramConfiguration = ""
$DramTiming1 = ""
$DramTiming2 = ""
$DramTiming3 = ""
$DramTiming4 = ""
$DramTiming5 = ""
$DramTiming6 = ""
$DramTiming7 = ""
$DramTiming8 = ""
$DramTiming9 = ""
$DramTiming10 = ""
$DramTiming12 = ""
$DramTiming13 = ""
$DramTiming20 = ""
$DramTiming21 = ""
$DramTiming22 = ""
$tRFCTiming0 = ""
$tRFCTiming1 = ""
$tSTAGTiming0 = ""
$tSTAGTiming1 = ""
$DramTiming35 = ""
$tRFCTiming = ""
$tSTAGTiming = ""
$Preamble2T = ""
$GDM = ""
$Cmd2T = ""
$MEMCLK = ""
$MEMCLKTRxx = ""
$tRCDWR = ""
$tRCDRD = ""
$tRAS = ""
$tCL = ""
$tRPPB = ""
$tRP = ""
$tRCPB = ""
$tRC = ""
$tRTP = ""
$tRRDDLR = ""
$tRRDL = ""
$tRRDS = ""
$tFAWDLR = ""
$tFAWSLR = ""
$tFAW = ""
$tWTRL = ""
$tWTRS = ""
$tCWL = ""
$tWR = ""
$tRCPage = ""
$tRDRDBAN = ""
$tRDRDSCL = ""
$tRDRDSCDLR = ""
$tRDRDSC = ""
$tRDRDSD = ""
$tRDRDDD = ""
$tWRWRBAN = ""
$tWRWRSCL = ""
$tWRWRSCDLR = ""
$tWRWRSC = ""
$tWRWRSD = ""
$tWRWRDD = ""
$tWRRDSCDLR = ""
$tRDWR = ""
$tWRRD = ""
$tREF = ""
$tREFCT = ""
$tMODPDA = ""
$tMRDPDA = ""
$tMOD = ""
$tMRD = ""
$tSTAG = ""
$tCKE = ""
$tPHYWRD = ""
$tPHYRDLAT = ""
$tPHYWRLAT = ""
$tRDDATA = ""
$tRFC4 = ""
$tRFC4CT = ""
$tRFC2 = ""
$tRFC2CT = ""
$tRFC = ""
$tRFCCT = ""
$tSTAG4LR = ""
$tSTAG2LR = ""
$tSTAGLR = ""
$tWRMPR = ""
$CPUID = DllCall($DLL, "dword", "CpuidPx", "dword", "0x80000001", "dword*", "", "dword*", "", "dword*", "", "dword*", "", "uint", "0x01")
$CPUFMS = BitAND($CPUID[2], 0xFFFF00)
If Not ($CPUFMS = "0x00800F00" Or $CPUFMS = "0x00810F00") Then
   Msgbox(16, "Error", "The software only supports RV & ZP based Ryzen CPUs")
   DllCall($DLL, "none", "DeinitializeOls")
   Exit
EndIf
$SMUORG = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
DllCall($DLL, "dword", "WritePciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "0x00000000")
Sleep($SMUDelay)
$BGS = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$BGSA = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramConfiguration = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming1 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming2 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming3 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming4 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming5 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming6 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming7 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming8 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming9 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming10 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming12 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming13 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming20 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming21 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming22 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$tRFCTiming0 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$tRFCTiming1 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$tSTAGTiming0 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$tSTAGTiming1 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
Sleep($SMUDelay)
$DramTiming35 = DllCall($DLL, "dword", "ReadPciConfigDword", "byte", "0x00", "byte", "0x00", "dword", "")
Sleep($SMUDelay)
DllCall($DLL, "dword", "WritePciConfigDword", "byte", "0x00", "byte", "0x00", "dword", $SMUORG[0])
Sleep($SMUDelay)
If $tRFCTiming0[0] = $tRFCTiming1[0] Then ; Checks if 2DPC is used or if tRFC has been manually set.
   $tRFCTiming = $tRFCTiming0[0]
   $tSTAGTiming = $tSTAGTiming0[0]
ElseIf $tRFCTiming0[0] = 0x21060138 Then ; Checks if DIMM0 tRFC is set to AGESA defaults, meaning DIMM1 is populated.
   $tRFCTiming = $tRFCTiming1[0]
   $tSTAGTiming = $tSTAGTiming1[0]
Else
EndIf
If $BGS[0] = 2271560481 Then
   $BGS = "Disabled"
Else
   $BGS = "Enabled"
EndIf
If $BGSA[0] = 286328817 Then
   $BGSA = "Enabled"
Else
   $BGSA = "Disabled"
EndIf
$Preamble2T = BitAND($DramConfiguration[0], 0x1000)
$Preamble2T = BitShift($Preamble2T, 12)
If $Preamble2T = 1 Then
   $Preamble2T = "Enabled"
Else
   $Preamble2T = "Disabled"
EndIf
$GDM = BitAND($DramConfiguration[0], 0x800)
$GDM = BitShift($GDM, 11)
If $GDM = 1 Then
   $GDM = "Enabled"
Else
   $GDM = "Disabled"
EndIf
$Cmd2T = BitAND($DramConfiguration[0], 0x400)
$Cmd2T = BitShift($Cmd2T, 10)
If $Cmd2T = 1 Then
   $Cmd2T = "2T"
Else
   $Cmd2T = "1T"
EndIf
$MEMCLK = BitAND($DramConfiguration[0], 0x7F)
$MEMCLKTRxx = ($MEMCLK / 3) * 100
$MEMCLK = Int(($MEMCLK / 3) * 200)
$tRCDWR = BitAND($DramTiming1[0], 0x3F000000)
$tRCDWR = BitShift($tRCDWR, 24)
$tRCDRD = BitAND($DramTiming1[0], 0x3F0000)
$tRCDRD = BitShift($tRCDRD, 16)
$tRAS = BitAND($DramTiming1[0], 0x7F00)
$tRAS = BitShift($tRAS, 8)
$tCL = BitAND($DramTiming1[0], 0x3F)
$tRPPB = BitAND($DramTiming2[0], 0x3F000000)
$tRPPB = BitShift($tRPPB, 24)
$tRP = BitAND($DramTiming2[0], 0x3F0000)
$tRP = BitShift($tRP, 16)
$tRCPB = BitAND($DramTiming2[0], 0xFF00)
$tRCPB = BitShift($tRCPB, 8)
$tRC = BitAND($DramTiming2[0], 0xFF)
$tRTP = BitAND($DramTiming3[0], 0x1F000000)
$tRTP = BitShift($tRTP, 24)
$tRRDDLR = BitAND($DramTiming3[0], 0x1F0000)
$tRRDDLR = BitShift($tRRDDLR, 16)
$tRRDL = BitAND($DramTiming3[0], 0x1F00)
$tRRDL = BitShift($tRRDL, 8)
$tRRDS = BitAND($DramTiming3[0], 0x1F)
$tFAWDLR = BitAND($DramTiming4[0], 0x7E000000)
$tFAWDLR = BitShift($tFAWDLR, 25)
$tFAWSLR = BitAND($DramTiming4[0], 0xFC0000)
$tFAWSLR = BitShift($tFAWSLR, 18)
$tFAW = BitAND($DramTiming4[0], 0x7F)
$tWTRL = BitAND($DramTiming5[0], 0x7F0000)
$tWTRL = BitShift($tWTRL, 16)
$tWTRS = BitAND($DramTiming5[0], 0x1F00)
$tWTRS = BitShift($tWTRS, 8)
$tCWL = BitAND($DramTiming5[0], 0x3F)
$tWR = BitAND($DramTiming6[0], 0x7F)
$tRCPage = BitAND($DramTiming7[0], 0xFFF00000)
$tRCPage = BitShift($tRCPage, 20)
$tRDRDBAN = BitAND($DramTiming8[0], 0xC0000000)
$tRDRDBAN = BitShift($tRDRDBAN, 30)
If $tRDRDBAN = 0 Then
   $tRDRDBAN = "Disabled"
ElseIf $tRDRDBAN = 1 Then
   $tRDRDBAN = "Ban 2"
ElseIf $tRDRDBAN = 2 Then
   $tRDRDBAN = "Ban 2&3"
EndIf
$tRDRDSCL = BitAND($DramTiming8[0], 0xF000000)
$tRDRDSCL = BitShift($tRDRDSCL, 24)
$tRDRDSCDLR = BitAND($DramTiming8[0], 0xF00000)
$tRDRDSCDLR = BitShift($tRDRDSCDLR, 20)
$tRDRDSC = BitAND($DramTiming8[0], 0xF0000)
$tRDRDSC = BitShift($tRDRDSC, 16)
$tRDRDSD = BitAND($DramTiming8[0], 0xF00)
$tRDRDSD = BitShift($tRDRDSD, 8)
$tRDRDDD = BitAND($DramTiming8[0], 0xF)
$tWRWRBAN = BitAND($DramTiming9[0], 0xC0000000)
$tWRWRBAN = BitShift($tWRWRBAN, 30)
If $tWRWRBAN = 0 Then
   $tWRWRBAN = "Disabled"
ElseIf $tWRWRBAN = 1 Then
   $tWRWRBAN = "Ban 2"
ElseIf $tWRWRBAN = 2 Then
   $tWRWRBAN = "Ban 2&3"
EndIf
$tWRWRSCL = BitAND($DramTiming9[0], 0x3F000000)
$tWRWRSCL = BitShift($tWRWRSCL, 24)
$tWRWRSCDLR = BitAND($DramTiming9[0], 0xF00000)
$tWRWRSCDLR = BitShift($tWRWRSCDLR, 20)
$tWRWRSC = BitAND($DramTiming9[0], 0xF0000)
$tWRWRSC = BitShift($tWRWRSC, 16)
$tWRWRSD = BitAND($DramTiming9[0], 0xF00)
$tWRWRSD = BitShift($tWRWRSD, 8)
$tWRWRDD = BitAND($DramTiming9[0], 0xF)
$tWRRDSCDLR = BitAND($DramTiming10[0], 0x1F0000)
$tWRRDSCDLR = BitShift($tWRRDSCDLR, 16)
$tRDWR = BitAND($DramTiming10[0], 0x1F00)
$tRDWR = BitShift($tRDWR, 8)
$tWRRD = BitAND($DramTiming10[0], 0xF)
$tREF = BitAND($DramTiming12[0], 0xFFFF)
$tREFCT = Int(((1000 / $MEMCLKTRxx) * $tREF))
$tMODPDA = BitAND($DramTiming13[0], 0x3F000000)
$tMODPDA = BitShift($tMODPDA, 24)
$tMRDPDA = BitAND($DramTiming13[0], 0x3F0000)
$tMRDPDA = BitShift($tMRDPDA, 16)
$tMOD = BitAND($DramTiming13[0], 0x3F00)
$tMOD = BitShift($tMOD, 8)
$tMRD = BitAND($DramTiming13[0], 0x3F)
$tSTAG = BitAND($DramTiming20[0], 0xFF0000)
$tSTAG = BitShift($tSTAG, 16)
$tCKE = BitAND($DramTiming21[0], 0x1F000000)
$tCKE = BitShift($tCKE, 24)
$tPHYWRD = BitAND($DramTiming22[0], 0x7000000)
$tPHYWRD = BitShift($tPHYWRD, 24)
$tPHYRDLAT = BitAND($DramTiming22[0], 0x3F0000)
$tPHYRDLAT = BitShift($tPHYRDLAT, 16)
$tPHYWRLAT = BitAND($DramTiming22[0], 0x1F00)
$tPHYWRLAT = BitShift($tPHYWRLAT, 8)
$tRDDATA = BitAND($DramTiming22[0], 0x7F)
$tRFC4 = BitAND($tRFCTiming, 0xFFC00000)
$tRFC4 = BitShift($tRFC4, 22)
$tRFC4CT = Round(((1000 / $MEMCLKTRxx) * $tRFC4), 3)
$tRFC2 = BitAND($tRFCTiming, 0x3FF800)
$tRFC2 = BitShift($tRFC4, 11)
$tRFC2CT = Round(((1000 / $MEMCLKTRxx) * $tRFC2), 3)
$tRFC = BitAND($tRFCTiming, 0x7FF)
$tRFCCT = Round(((1000 / $MEMCLKTRxx) * $tRFC), 3)
$tSTAG4LR = BitAND($tSTAGTiming, 0x1FF00000)
$tSTAG4LR = BitShift($tSTAG4LR, 20)
If $tSTAG4LR = 0 Then
   $tSTAG4LR = "Disabled"
EndIf
$tSTAG2LR = BitAND($tSTAGTiming, 0x7FC00)
$tSTAG2LR = BitShift($tSTAG2LR, 10)
If $tSTAG2LR = 0 Then
   $tSTAG2LR = "Disabled"
EndIf
$tSTAGLR = BitAND($tSTAGTiming, 0x1FF)
If $tSTAGLR = 0 Then
   $tSTAGLR = "Disabled"
EndIf
$tWRMPR = BitAND($DramTiming35[0], 0x3F000000)
$tWRMPR = BitShift($tWRMPR, 24)
$RTC = GUICreate("Ryzen Timing Checker", 520, 600, 192, 124)
$MEMCLKBox = GUICtrlCreateInput($MEMCLK, 10, 14, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
GUICtrlSetFont(-1, 8, 400, 0, "Arial")
$MEMCLKLabel = GUICtrlCreateLabel("MEMCLK Ratio", 80, 17, 95, 17)
GUICtrlSetFont(-1, 8, 800, 0, "Arial")
GUICtrlSetState($MEMCLKBox, $GUI_DISABLE)
$Cmd2tBox = GUICtrlCreateInput($GDM, 170, 14, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$Cmd2tLabel = GUICtrlCreateLabel("GearDownMode", 240, 17, 85, 17)
GUICtrlSetState($Cmd2tBox, $GUI_DISABLE)
$GDMBox = GUICtrlCreateInput($Cmd2t, 10, 44, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$GDMLabel = GUICtrlCreateLabel("Cmd2t", 80, 47, 70, 17)
GUICtrlSetState($GDMBox, $GUI_DISABLE)
$BGSBox = GUICtrlCreateInput($BGS, 170, 44, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$BGSLabel = GUICtrlCreateLabel("BankGroupSwap", 240, 47, 85, 17)
GUICtrlSetState($BGSBox, $GUI_DISABLE)
$BGSABox = GUICtrlCreateInput($BGSA, 330, 14, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$BGSALabel = GUICtrlCreateLabel("BankGroupSwapAlt", 400, 17, 100, 17)
GUICtrlSetState($BGSABox, $GUI_DISABLE)
$tCLBox = GUICtrlCreateInput($tCL, 10, 94, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tCLLabel = GUICtrlCreateLabel("tCL", 80, 97, 70, 17)
GUICtrlSetState($tCLBox, $GUI_DISABLE)
$tRCDWRBox = GUICtrlCreateInput($tRCDWR, 10, 124, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRCDWRLabel = GUICtrlCreateLabel("tRCDWR", 80, 127, 70, 17)
GUICtrlSetState($tRCDWRBox, $GUI_DISABLE)
$tRCDRDBox = GUICtrlCreateInput($tRCDRD, 10, 154, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRCDRDLabel = GUICtrlCreateLabel("tRCDRD", 80, 157, 70, 17)
GUICtrlSetState($tRCDRDBox, $GUI_DISABLE)
$tRPBox = GUICtrlCreateInput($tRP, 10, 184, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRPLabel = GUICtrlCreateLabel("tRP", 80, 187, 70, 17)
GUICtrlSetState($tRPBox, $GUI_DISABLE)
$tRASBox = GUICtrlCreateInput($tRAS, 10, 214, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRASLabel = GUICtrlCreateLabel("tRAS", 80, 217, 70, 17)
GUICtrlSetState($tRASBox, $GUI_DISABLE)
$tRCBox = GUICtrlCreateInput($tRC, 10, 244, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRCLabel = GUICtrlCreateLabel("tRC", 80, 247, 70, 17)
GUICtrlSetState($tRCBox, $GUI_DISABLE)
$tRRDSBox = GUICtrlCreateInput($tRRDS, 10, 274, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRRDSLabel = GUICtrlCreateLabel("tRRDS", 80, 277, 70, 17)
GUICtrlSetState($tRRDSBox, $GUI_DISABLE)
$tRRDLBox = GUICtrlCreateInput($tRRDL, 10, 304, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRRDLLabel = GUICtrlCreateLabel("tRRDL", 80, 307, 70, 17)
GUICtrlSetState($tRRDLBox, $GUI_DISABLE)
$tFAWBox = GUICtrlCreateInput($tFAW, 10, 334, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tFAWLabel = GUICtrlCreateLabel("tFAW", 80, 337, 70, 17)
GUICtrlSetState($tFAWBox, $GUI_DISABLE)
$tFAWDLRBox = GUICtrlCreateInput($tFAWDLR, 10, 364, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tFAWDLRLabel = GUICtrlCreateLabel("tFAWDLR", 80, 367, 70, 17)
GUICtrlSetState($tFAWDLRBox, $GUI_DISABLE)
$tFAWSLRBox = GUICtrlCreateInput($tFAWSLR, 10, 394, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tFAWSLRLabel = GUICtrlCreateLabel("tFAWSLR", 80, 397, 70, 17)
GUICtrlSetState($tFAWSLRBox, $GUI_DISABLE)
$tWTRSBox = GUICtrlCreateInput($tWTRS, 10, 424, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWTRSLabel = GUICtrlCreateLabel("tWTRS", 80, 427, 70, 17)
GUICtrlSetState($tWTRSBox, $GUI_DISABLE)
$tWTRLBox = GUICtrlCreateInput($tWTRL, 10, 454, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWTRLLabel = GUICtrlCreateLabel("tWTRL", 80, 457, 70, 17)
GUICtrlSetState($tWTRLBox, $GUI_DISABLE)
$tWRBox = GUICtrlCreateInput($tWR, 10, 484, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRLabel = GUICtrlCreateLabel("tWR", 80, 487, 70, 17)
GUICtrlSetState($tWRBox, $GUI_DISABLE)
$tRCPageBox = GUICtrlCreateInput($tRCPage, 10, 514, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRCPageLabel = GUICtrlCreateLabel("tRCPage", 80, 517, 70, 17)
GUICtrlSetState($tRCPageBox, $GUI_DISABLE)
$tRDRDSCLBox = GUICtrlCreateInput($tRDRDSCL, 10, 544, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDSCLLabel = GUICtrlCreateLabel("tRDRDSCL", 80, 547, 70, 17)
GUICtrlSetState($tRDRDSCLBox, $GUI_DISABLE)
$tWRWRSCLBox = GUICtrlCreateInput($tWRWRSCL, 10, 574, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRSCLLabel = GUICtrlCreateLabel("tWRWRSCL", 80, 577, 70, 17)
GUICtrlSetState($tWRWRSCLBox, $GUI_DISABLE)
$tRFCBox = GUICtrlCreateInput($tRFC, 170, 94, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRFCLabel = GUICtrlCreateLabel("tRFC", 240, 97, 70, 17)
GUICtrlSetState($tRFCBox, $GUI_DISABLE)
$tRFCCTBox = GUICtrlCreateInput($tRFCCT, 170, 124, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRFCCTLabel = GUICtrlCreateLabel("tRFC (ns)", 240, 127, 70, 17)
GUICtrlSetState($tRFCCTBox, $GUI_DISABLE)
$tCWLBox = GUICtrlCreateInput($tCWL, 170, 154, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tCWLLabel = GUICtrlCreateLabel("tCWL", 240, 157, 70, 17)
GUICtrlSetState($tCWLBox, $GUI_DISABLE)
$tRTPBox = GUICtrlCreateInput($tRTP, 170, 184, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRTPLabel = GUICtrlCreateLabel("tRTP", 240, 187, 70, 17)
GUICtrlSetState($tRTPBox, $GUI_DISABLE)
$tRDWRBox = GUICtrlCreateInput($tRDWR, 170, 214, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDWRLabel = GUICtrlCreateLabel("tRDWR", 240, 217, 70, 17)
GUICtrlSetState($tRDWRBox, $GUI_DISABLE)
$tWRRDBox = GUICtrlCreateInput($tWRRD, 170, 244, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRRDLabel = GUICtrlCreateLabel("tWRRD", 240, 247, 70, 17)
GUICtrlSetState($tWRRDBox, $GUI_DISABLE)
$tWRWRSCBox = GUICtrlCreateInput($tWRWRSC, 170, 274, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRSCLabel = GUICtrlCreateLabel("tWRWRSC", 240, 277, 70, 17)
GUICtrlSetState($tWRWRSCBox, $GUI_DISABLE)
$tWRWRSDBox = GUICtrlCreateInput($tWRWRSD, 170, 304, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRSDLabel = GUICtrlCreateLabel("tWRWRSD", 240, 307, 70, 17)
GUICtrlSetState($tWRWRSDBox, $GUI_DISABLE)
$tWRWRDDBox = GUICtrlCreateInput($tWRWRDD, 170, 334, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRDDLabel = GUICtrlCreateLabel("tWRWRDD", 240, 337, 70, 17)
GUICtrlSetState($tWRWRDDBox, $GUI_DISABLE)
$tRDRDSCBox = GUICtrlCreateInput($tRDRDSC, 170, 364, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDSCLabel = GUICtrlCreateLabel("tRDRDSC", 240, 367, 70, 17)
GUICtrlSetState($tRDRDSCBox, $GUI_DISABLE)
$tRDRDSDBox = GUICtrlCreateInput($tRDRDSD, 170, 394, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDSDLabel = GUICtrlCreateLabel("tRDRDSD", 240, 397, 70, 17)
GUICtrlSetState($tRDRDSDBox, $GUI_DISABLE)
$tRDRDDDBox = GUICtrlCreateInput($tRDRDDD, 170, 424, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDDDLabel = GUICtrlCreateLabel("tRDRDDD", 240, 427, 70, 17)
GUICtrlSetState($tRDRDDDBox, $GUI_DISABLE)
$tCKEBox = GUICtrlCreateInput($tCKE, 170, 454, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tCKELabel = GUICtrlCreateLabel("tCKE", 240, 457, 70, 17)
GUICtrlSetState($tCKEBox, $GUI_DISABLE)
$tRPPBBox = GUICtrlCreateInput($tRPPB, 170, 484, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRPPBLabel = GUICtrlCreateLabel("tRPPB", 240, 487, 70, 17)
GUICtrlSetState($tRPPBBox, $GUI_DISABLE)
$tRCPBBox = GUICtrlCreateInput($tRCPB, 170, 514, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRCPBLabel = GUICtrlCreateLabel("tRCPB", 240, 517, 70, 17)
GUICtrlSetState($tRCPBBox, $GUI_DISABLE)
$tRRDDLRBox = GUICtrlCreateInput($tRRDDLR, 170, 544, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRRDDLRLabel = GUICtrlCreateLabel("tRRDDLR", 240, 547, 70, 17)
GUICtrlSetState($tRRDDLRBox, $GUI_DISABLE)
$tRDRDBANBox = GUICtrlCreateInput($tRDRDBAN, 170, 574, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDBANLabel = GUICtrlCreateLabel("tRDRDBAN", 240, 577, 70, 17)
GUICtrlSetState($tRDRDBANBox, $GUI_DISABLE)
$tRDRDSCDLRBox = GUICtrlCreateInput($tRDRDSCDLR, 330, 94, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDRDSCDLRLabel = GUICtrlCreateLabel("tRDRDSCDLR", 400, 97, 70, 17)
GUICtrlSetState($tRDRDSCDLRBox, $GUI_DISABLE)
$tWRWRBANBox = GUICtrlCreateInput($tWRWRBAN, 330, 124, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRBANLabel = GUICtrlCreateLabel("tWRWRBAN", 400, 127, 70, 17)
GUICtrlSetState($tWRWRBANBox, $GUI_DISABLE)
$tWRWRSCDLRBox = GUICtrlCreateInput($tWRWRSCDLR, 330, 154, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRWRSCDLRLabel = GUICtrlCreateLabel("tWRWRSCDLR", 400, 157, 70, 17)
GUICtrlSetState($tWRWRSCDLRBox, $GUI_DISABLE)
$tWRRDSCDLRBox = GUICtrlCreateInput($tWRRDSCDLR, 330, 184, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRRDSCDLRLabel = GUICtrlCreateLabel("tWRRDSCDLR", 400, 187, 70, 17)
GUICtrlSetState($tWRRDSCDLRBox, $GUI_DISABLE)
$tREFBox = GUICtrlCreateInput($tREF, 330, 214, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tREFLabel = GUICtrlCreateLabel("tREF", 400, 217, 70, 17)
GUICtrlSetState($tREFBox, $GUI_DISABLE)
$tREFCTBox = GUICtrlCreateInput($tREFCT, 330, 244, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tREFCTLabel = GUICtrlCreateLabel("tREF (ns)", 400, 247, 70, 17)
GUICtrlSetState($tREFCTBox, $GUI_DISABLE)
$tMODBox = GUICtrlCreateInput($tMOD, 330, 274, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tMODLabel = GUICtrlCreateLabel("tMOD", 400, 277, 70, 17)
GUICtrlSetState($tMODBox, $GUI_DISABLE)
$tMODPDABox = GUICtrlCreateInput($tMODPDA, 330, 304, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tMODPDALabel = GUICtrlCreateLabel("tMODPDA", 400, 307, 70, 17)
GUICtrlSetState($tMODPDABox, $GUI_DISABLE)
$tMRDBox = GUICtrlCreateInput($tMRD, 330, 334, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tMRDLabel = GUICtrlCreateLabel("tMRD", 400, 337, 70, 17)
GUICtrlSetState($tMRDBox, $GUI_DISABLE)
$tMRDPDABox = GUICtrlCreateInput($tMRDPDA, 330, 364, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tMRDPDALabel = GUICtrlCreateLabel("tMRDPDA", 400, 367, 70, 17)
GUICtrlSetState($tMRDPDABox, $GUI_DISABLE)
$tSTAGBox = GUICtrlCreateInput($tSTAG, 330, 394, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tSTAGLabel = GUICtrlCreateLabel("tSTAG", 400, 397, 70, 17)
GUICtrlSetState($tSTAGBox, $GUI_DISABLE)
$tPHYWRDBox = GUICtrlCreateInput($tPHYWRD, 330, 424, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tPHYWRDLabel = GUICtrlCreateLabel("tPHYWRD", 400, 427, 70, 17)
GUICtrlSetState($tPHYWRDBox, $GUI_DISABLE)
$tPHYWRLBox = GUICtrlCreateInput($tPHYWRLAT, 330, 454, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tPHYWRLLabel = GUICtrlCreateLabel("tPHYWRL", 400, 457, 70, 17)
GUICtrlSetState($tPHYWRLBox, $GUI_DISABLE)
$tPHYRDLBox = GUICtrlCreateInput($tPHYRDLAT, 330, 484, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tPHYRDLLabel = GUICtrlCreateLabel("tPHYRDL", 400, 487, 70, 17)
GUICtrlSetState($tPHYRDLBox, $GUI_DISABLE)
$tRDDATABox = GUICtrlCreateInput($tRDDATA, 330, 514, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tRDDATALabel = GUICtrlCreateLabel("tRDDATA", 400, 517, 70, 17)
GUICtrlSetState($tRDDATABox, $GUI_DISABLE)
$tSTAGLRBox = GUICtrlCreateInput($tSTAGLR, 330, 544, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tSTAGLRLabel = GUICtrlCreateLabel("tSTAGLR", 400, 547, 70, 17)
GUICtrlSetState($tSTAGLRBox, $GUI_DISABLE)
$tWRMPRBox = GUICtrlCreateInput($tWRMPR, 330, 574, 60, 18, BitOR($GUI_SS_DEFAULT_INPUT,$ES_CENTER))
$tWRMPRLabel = GUICtrlCreateLabel("tWRMPR", 400, 577, 70, 17)
GUICtrlSetState($tWRMPRBox, $GUI_DISABLE)
GUISetState(@SW_SHOW)
While 1
        $nMsg = GUIGetMsg()
        Switch $nMsg
        Case $GUI_EVENT_CLOSE
                        Exit
        EndSwitch
WEnd
The Stilt is offline
post #2 of 138 (permalink) Old 12-14-2017, 11:53 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1447 (Unique: 730)
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is online now
post #3 of 138 (permalink) Old 12-14-2017, 12:13 PM
Rep: 11 (Unique: 10)
No, no troubles here. used it with my Ryzen build. Never had any troubles, was very handy when OCing memory. Switched to 8700k build so cannot say anything about current situation. I know ASUS has implemented Stilt's memory profiles to their BIOS. And I know in the past many overcloking utilities have been erroneusly picked up by AV-programs so I dont really worry about that on this case.
CptKuolio is offline
post #4 of 138 (permalink) Old 12-14-2017, 12:44 PM
The 6502 Still Rocks
Master Chicken's Avatar
Rep: 31 (Unique: 29)
That guy got sideways just because the AutoIT system contains library calls to support some of it's network related functions. He never checked to see that you weren't using those calls and thereby weren't generating any traffic ... he just assumed that because they were in there that they were being used. I've never really seen someone as susceptible to such noob paranoia before. The guy is quite literally unstable and not qualified to be making the assumptions he's making in that thread. All he had to do was monitor network traffic when the program was run ... but he couldn't pull that off. Then he went on some Uber rootkit rant involving the UEFI, etc. It was nuts. I hope he can get the help he needs. I've not seen someone come in and wreck a thread like that in a long time ... someone likely to be literally wearing a tinfoil hat.
I hope he doesn't run into any of those articles on the Intel ME v10 or v11 issues. That will surely send him into an unrecoverable spiral.
Master Chicken is offline
post #5 of 138 (permalink) Old 12-14-2017, 12:54 PM
Watercooled
lexer's Avatar
Rep: 47 (Unique: 33)
Remember guys always use a tin foil hat to check your Ryzen timings biggrin.gif
Ryzen 9 3900X/2X16GB DDR4-3733@CL16/X570-I AORUS/RTX 2080 GAMING OC/IN-WIN 301/EVGA 850W
Heatkiller REV3.0+DIY AM4 Adapter/1X120+1x240mm/DDC3.25+EK DDC Res
lexer is offline
post #6 of 138 (permalink) Old 12-14-2017, 02:35 PM
cssorkinman's Avatar
Rep: 499 (Unique: 279)
I wasn't too concerned but I'm glad you took the time to explain the situation.
No problems with BDC or RTC on my end.
Unlike Windows 10's latest update...... run time error etc. etc.
Ryzen Shine!
(15 items)
Ryzen 1800X @ 4125mhz 1.432 Volts
MSI X370 Titanium
Fury
Sapphire Nitro + 5700XT
G.SKILL TridentZ Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C14Q-32GTZ
Samsung 850 pro
Optical Drive
Hp 1260 I
PC power and cooling 910 watt silencer
liquid unobtanium Koolance 480mm radiator, 390 block - 3/4 OD tubing
Thermaltake P5
Operating System
Win 7 HP/Winspy 10 64bit
24" hp @ 1900x1200
Keyboard
Logitech G19
Mouse
Logitech MX 518
Mouse
fUnc industries
cssorkinman is offline
post #7 of 138 (permalink) Old 12-14-2017, 02:47 PM
Tetrapyloctomist
Aenra's Avatar
Rep: 45 (Unique: 27)
Thank you Stilt.
It's the saddest thing in PC-related communities, albeit not exclusive to them.. how the very individuals at the bottom of the fish pond end up doing the work of the corporations (be it brainwashing, flaming, distorting or deflecting), for free. For free, and with a passion unmatched by any professional :)
Pride, honour and purity.
Aenra is offline
post #8 of 138 (permalink) Old 12-14-2017, 03:42 PM
Head Smeghead of OCN
Kryton's Avatar
Rep: 182 (Unique: 132)
Kryton is offline
post #9 of 138 (permalink) Old 12-14-2017, 03:59 PM
Linux Lobbyist
keng's Avatar
Rep: 17 (Unique: 14)
Ok great, thanks for that.
Anyhow, I am personally not involved in this investigation and I will not be commenting on it anymore besides suggesting that anyone with access to any sensible systems should avoid downloading or running this program. If you had run it, you should probably notify your CTO or similar administrator.
If you require any specific timings about your RAM, settings, etc, please refer to the AMD tech guides, EPYC developer SDKs and if it something not public (i.e. sensor identities, registers, etc.) please contact AMD directly and you will more than likely have what you need provided you agree to a NDA.
keng is offline
post #10 of 138 (permalink) Old 12-14-2017, 05:10 PM
Anty's Avatar
Rep: 10 (Unique: 10)
And things escalated quickly - deobfuscated code including regs could be found online (didn't try to compile but reveals lots of info) rolleyes.gif
Ryzen 1700 ~ C6H ~ 4x8GB trident Z [email protected] ~ EVGA 1080Ti
Anty is offline
