Problems with new build, HELP!!!! - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 02-07-2019, 12:18 PM - Thread Starter
Rep: 0
I am trying to upgrade with the following hardware
ASUS ROG X470 crosshair vii non wifi
32 GB Gskill F4-3200C16Q-32GTZRX
Ryzen 2700x CPU
ASUS Vega64 STRIX video card
Initially encountered problem with not being able to boot into the BIOS. Eventually I was able and made some changes, don't recall all that I made, but when I saved them the system would not boot back into the bios. After much agony I finally tried with 2 video cards installed and it will now boot into the bios. I am unable to boot into win10 reliably. Sometimes it gets as far as log in screen other times it shuts down before that point.
I have updated the bios 1201 which is the latest as far as can tell.
Any ideas an why I need 2 videos cards installed in order for it boot into the bios and why I can not boot into windows reliably?
jrob55 is offline
post #2 of 8 (permalink) Old 02-07-2019, 01:07 PM
Filthy Casual
bajer29's Avatar
Rep: 106 (Unique: 91)
A handful of questions that will help us troubleshoot your issue:
What have you tried?
Have you reset the CMOS with the clear CMOS button?
Did you remove the CMOS battery?
Did you reseat RAM?
Did you reseat CPU?
Have you looked into which PCIe slot the BIOS/ mobo wants to boot from?
Which slot are you trying to use as your primary video card slot?
Can you confirm that slot is the one BIOS is trying to use as primary?
What PSU are you using?
How old is the PSU?
Xeno Storm V 1.2
(18 items)
i7 4790K (delidded)
GIGABYTE|GA-Z87X-D3H
EVGA 1080TI FTW3
4x4GB GSKILL @ 2133MHz
WD 1002FAEX
KINGSTON V300 120GB
SanDisk Ultra Plus 128GB
Samsung 850 EVO 500GB
WD Green WD5000AADS
Corsair AX850
Cryorig R1 Ultimate
Phanteks Enthoo Pro M SE
Operating System
Windows 10 Enterprise
Acer XB270HU Predator
Keyboard
E-Element Z-88 RGB
Mouse
Corsair M65
Audio
Logitech X230 2.1
Other
E-SDS USB 3.0 2-Port Front Panel USB Hub
bajer29 is offline
post #3 of 8 (permalink) Old 02-07-2019, 01:12 PM
Rep: 0
Ryzen 2700x CPU
I'll be the jerk that asks the obvious stuff. Did you re-seat the CPU and make certain you used the correct RAM slots (assuming it's a 2x16GB kit)?
Can you describe how it fails in more detail please?
And I can't remember why, but I believe someone in the Crosshair VII forum helped someone else troubleshoot Vega64 problems. You may want to pop in over there.
AMD Ryzen 2700X  |  Fractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  | G.SKILL TridentZ 3636MHz @ 14-15-14-28 2x8GB  | EVGA 1070 Ti SC GAMING ACX 3.0 Black  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3  | Thermaltake Core P3 Case |
nick name is online now
post #4 of 8 (permalink) Old 02-07-2019, 01:51 PM - Thread Starter
Rep: 0
Have you reset the CMOS with the clear CMOS button? YES
Did you remove the CMOS battery? YES
Did you reseat RAM? YES
Did you reseat CPU? YES
Have you looked into which PCIe slot the BIOS/ mobo wants to boot from? I tried both PCIe slots with same results
Which slot are you trying to use as your primary video card slot? Slot closest to the CPU
Can you confirm that slot is the one BIOS is trying to use as primary? As far as can tell slot 1 is primary
What PSU are you using? Thermaltake Toughpower XLT Platinum 1275watts
How old is the PSU?
About 5 years
Thanks for your interest in helping. Just got off the phone ASUS tech support and was elevated to higher level tech to address my problems and ultimately, after discussing with an engineer, they want me have the board replaced. They are just as dumb founded as I am. But if you have any other ideas let me know.
jrob55 is offline
post #5 of 8 (permalink) Old 02-07-2019, 02:17 PM
Senior OCN Member
shilka's Avatar
Rep: 2696 (Unique: 1603)
Your PSU does not have all that great voltage regulation nor is ripple suppression especially on the 3,3v rail all that good either
Seravee
(31 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
EVGA GTX 1080 FTW2
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Seagate Ironwolf Pro 8 TB
Seagate Ironwolf 12 TB
Seagate Ironwolf Pro 10 TB
Seagate Ironwolf Pro 12 TB
Optical Drive
LG CH12NS30
EVGA SuperNova G2 750 watt
x5 Noctua NF-A14 FLX
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 49UH750V 4K LED TV
Keyboard
Corsair Gaming Strafe RGB
Mouse
Roccat Kone EMP
Mouse
Roccat Sense Metor
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod E series PSU cable set
Other
CableMod LED Strips
shilka is offline
post #6 of 8 (permalink) Old 02-07-2019, 03:18 PM - Thread Starter
Rep: 0
That may be but it has worked just fine in my current system that I am trying to upgrade. As far as the ripple and regulation is concerned I can not find any data on those parameters and I seriously doubt they would be causing the kinda issues I have been experiencing.
Thanks for you feedback.
jrob55 is offline
post #7 of 8 (permalink) Old 02-13-2019, 10:12 PM
Rep: 845 (Unique: 618)
Maybe the primary card has a problem. Once in Windows, is crossfire enabled? Is there a secondary BIOS for the Vega? Switch No.2?
rdr09 is offline
post #8 of 8 (permalink) Old 02-13-2019, 10:42 PM
white owl's Avatar
Rep: 124 (Unique: 95)
They're not, Shilka is the resident PSU expert and lets everyone know where the PSU stands even if it's not relevant. Most people don't consider the PSU one of the most important aspects of their rig but it can hamper overclocking if it's just not good or flat out destroy your components if it's OCP/OTP don't function correctly. Some can do rated power but only if they stay cool enough.
With your PSU the voltage fed to the rest of the PC is always changing which is bad but if you don't care, neither do I.
On topic:
Booting your rig for the first time is pretty standard, set the mobo on the box it came in, insert the CPU and ram, install the cooler, and in your case the VGA then plug it all in. If all is well you'll end up in the BIOS. If not remove all ram but the one closest to the CPU and try again, then try the next stick. If that still doesn't work remove the GPU and see if the board hangs in a similar fashion, try a different GPU if available. If you have POST codes you should be able to pinpoint the issue pretty easily.
CPUs are rarely DOA so if none of that gets you anywhere it's likely a bad board.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
