(Solved) Titan RTX running at pcie 16x (2.0) why not 3.0? help me figure this out - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 04-02-2019, 07:19 AM - Thread Starter
Terrible Overclocker
spadizzle's Avatar
Rep: 0
MSI Meg Creation x399 motherboard running @1smus 132 beta bios. (I have tried 120, 131 also) I have unplugged. reseated, reformatted to no avail.
I have set the values in the Bios for the first slot to run at 16x 3.0. reboot and go back into bios and its reporting from the hardware monitor that its seeing it at that speed. BUT I get into Win10(latest updates) and gpu-z states that it is at 16x 2.0 max and idle speed. (see screenshot)
Video card is a single Nvidia Titan RTX.
Anyone else run into this issue? I have searched/googled high and low and this doesn't seem to be an issue for the last few years.
I eagerly await any feedback!
TY,
Scott
spadizzle is offline
post #2 of 10 (permalink) Old 04-02-2019, 08:01 AM
animeowns's Avatar
Rep: 8 (Unique: 7)
do you think the beta bios could be the problem ?
animeowns is offline
post #3 of 10 (permalink) Old 04-02-2019, 08:14 AM - Thread Starter
spadizzle's Avatar
Rep: 0
I have tried the official 120 release from MSI, same results. I just finished reflashing the card with the stock bios and no change either.
Edit: Just tried setting card to Gen1 to see if that would take effect. GPU-Z still states Gen2. So it does seem like a pc bios issue. So weird.
post #4 of 10 (permalink) Old 04-02-2019, 08:43 AM
skupples's Avatar
Rep: 551 (Unique: 312)
have you confirmed its staying in 2.0 when its actually being used?
pci-e downclocks itself.
skupples is offline
post #5 of 10 (permalink) Old 04-02-2019, 08:55 AM - Thread Starter
spadizzle's Avatar
Rep: 0
loop test, same results.
post #6 of 10 (permalink) Old 04-02-2019, 09:36 AM - Thread Starter
spadizzle's Avatar
Rep: 0
Not enough memory?
Ok, good news, got it going at 16x 3.0 now. I switched back to my DR memory 64gig total. Bad news, the Single rank I was able to push faster. Never heard of PCIe needing more memory, or do we think I had an issue with my 32gig mem set?
G.Skill F4-3200C14-8GTZRX (Single Rank) 32 gig Was able to run stable at 3200mhz With 1.38v
G.Skill F4-3200C14-16GTZR (Dual Rank) 64 gig Will only post at 2933 mhz :/ With 1.4v
post #7 of 10 (permalink) Old 04-02-2019, 09:39 AM
white owl's Avatar
Rep: 136 (Unique: 103)
It's an odd issue but RAM uses CPU lanes like anything else so they're not totally unrelated...still that's pretty crazy. Contact MSI and see what they have to say about it.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #8 of 10 (permalink) Old 04-02-2019, 10:03 AM - Thread Starter
spadizzle's Avatar
Rep: 0
Will do!
post #9 of 10 (permalink) Old 04-10-2019, 09:05 PM
ssateneth's Avatar
Rep: 43 (Unique: 38)
Can you downlclock your RAM, the single rank stuff, to stock speeds and see what happens?
RAM speed is tied to a bunch of other things for Ryzen (SoC, infinity fabric, which links to a lot of other things, such as PCI-E). If your SoC is unstable at higher speeds and can't latch at PCI-E 3.0 speeds (8 GT/sec), it may back down to PCI-E 2.0 (5 GT/sec). PCI-E devices will negotiate to the highest possible speed that both host and device can support, and if any issue arrises from either hardware incapability, or issues with signaling, it will negotiate to lower gen speeds and/or less PCI-E lanes (using a riser with bad shielding or long cable can cause lower pci-e gen speed)
Off topic, but from the new announce of infinity fabric speeds for ryzen 2, memory support will be better. ryzen 1 infinity fabric is 10.7GT/sec, or memory frequency x 8. mem freq is stated to default to 1333MHz (DDR 2666) for ryzen 1, so 1333MHz * 8 = 10667MT/sec, or 10.7GT/sec. Ryzen 2's IF will be 16 x mem freq, or 25.6GT/sec. Putting in some substitution math, that's default memory speed of 1600MHz, or 3200MHz DDR right out of the box with no problems.
Intel Core i9-9900k (Silicon Lottery 5.1GHz @ 5.3GHz 1.36 VCore)
ASUS ROG MAXIMUS XI APEX
G.SKILL F4-4000C19D-32GTZSW (2x16GiB 4000MHz 19-19-19-39 2T, tuned to 4133MHz 14-17-17-31 2T)
EVGA NVIDIA GeForce GTX 1080 Ti FTW3
Seasonic PRIME 1300W 80+ Platinum
ssateneth is offline
post #10 of 10 (permalink) Old 04-13-2019, 10:39 AM
wun
Rep: 0
MSI RTX 2080 Gaming X Trio same problem. Solution: UEFI "CPU BCLK Settings" - live it deafault: "Smart BCLK Switch - Disabled" and "CPU Base Clock (MHz) - Auto". Works for me.
wun is offline
