Ryzen Upgrade from 1090T Help? - Overclock.net - An Overclocking Community
post #1 of 29 (permalink) Old 04-18-2019, 06:50 AM - Thread Starter
tuffstuff's Avatar
Rep: 8 (Unique: 8)
I have fallen out of the loop from a hardware stand point and was looking to upgrade my current pc setup for under 500 bucks if possible. I mostly play POE, Diablo 3, Guild Wars 2, and might eventually play WoW again. Other than that the pc will mostly be bill paying and watching youtube/streaming hulu and internet surfing.
I saw the Ryzen 5 1600 was on sale at microcenter for only 79.99 and was tempted to pick one up if its worth it. If I did go that route what would you recommend as far as memory, video card, and motherboard to go with it? I would like to start with the main components to upgrade. I don't really overclock either just let the system do it or just run with what I have.
Thanks for the help as I am lost as to what is decent nowadays as far as hardware due to not keeping up. I would also need a new windows 10 key.
tuffstuff is offline
post #2 of 29 (permalink) Old 04-18-2019, 07:02 AM
battlenut's Avatar
Rep: 58 (Unique: 52)
Whats your Current hardware?
CPU: AMD Ryzen R9 3900X
Mobo: Asrock X570 Extreme 4
VGA:Sapphire RX 5700 XT Nitro For games Asrock Phantom Gaming Radeon VII for folding
RAM: G-Skill 3600 RipJaws F4-3600C19D-32GVRB X 2
Storage: Samsung M.2 850 EVO 1TB
PSU: Seasonic Prime Ultra 1000 Platinum
Cooling: HeatKiller For CPU & Bykski for GPU
battlenut is offline
post #3 of 29 (permalink) Old 04-18-2019, 07:39 AM - Thread Starter
tuffstuff's Avatar
Rep: 8 (Unique: 8)
Current system is
1090T AMD with DEEPCOOL GAMMAXX 400-CPU Cooler
ASUS M4A88TD-V EVO
2xG.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) 16gb
ASUS Radeon HD 6870 DirectX 11 EAH6870 DC/2DI2S/1GD5 1GB 256-Bit GDDR5 PCI Express 2.1 x16
Western Digital Black WD1002FAEX 1TB 7200 RPM HardDrive
Kingston Hyper X SSD
ASUS Xonar DG 5.1 Channels 24-bit 96KHz PCI Interface Sound Card
MasterCase Pro 5 Mid-Tower Case
OCZ ModXStream Pro Series 700 Watt 80+ Semi-Modular Active PFC Performance Grade ATX PC Power Supply (OCZ700MXSP)
also have a Cooler Master Master Watt 650 Watt Semi-Fanless Silencio Fan, Semi-Modular 80 PLUS Bronze Power Supply brand new in box.
Everything is about 8-10 years old besides the case.
post #4 of 29 (permalink) Old 04-18-2019, 07:52 AM
rdr09's Avatar
Rep: 874 (Unique: 637)
Op, if you don't mind getting Win10 key in the site suggested. There might be one US based. If you are a student, your school might get a discount in Windows OS.
Total: 455$ before Tax.
RAM - !00$
https://www.newegg.com/Product/Produ...82E16820232181
Alternate RAM (160$ B-Die)
https://www.newegg.com/Product/Produ...-217-_-Product
Motherboard - 215$ (R5 2600 is a tad faster)
https://www.microcenter.com/product/...erboard-bundle
GPU - 130$
https://www.newegg.com/Product/Produ...82E16814202283
Win10 – 10$
https://www.cjs-cdkeys.com/products/...SAAEgJJfvD_BwE
I would highly suggest going with the alternate RAM. You can talk to Micro Center see if there is a R5 1600 in a bundle. Then the money saved goes to the alternate RAM.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #5 of 29 (permalink) Old 04-18-2019, 07:59 AM - Thread Starter
tuffstuff's Avatar
Rep: 8 (Unique: 8)
RAM - !00$
GPU - 130$
Win10 – 10$
Unfortunately not a student atm. This all looks good and I forgot to see what they offered for combos. For another 45 to take it to an even 500 is there any other graphics cards that would be better or is it all going to be around the same performance or not needed? I will go with the better ram suggestion.
Thanks again for the suggested build above.
post #6 of 29 (permalink) Old 04-18-2019, 08:03 AM
rdr09's Avatar
Is there something wrong with your current rig? We have the same AM3 motherboard and it oc my PhenomII X 6 to 4GHz. If it can, then just get a GTX 2060 and wait for Ryzen 3000 and X570 boards.
Mine is currently paired with a GTX 1050, which is slower than my HD7950.
I was gonna suggest the RX 570 8GB but i want to stay at 500$ mark.
BTW, the 1090 will bottleneck the 2060 but it will still be a massive upgrade from the 6870. Massive. The RX 570 alone is already a massive upgrade for you. About 4X faster than the 6870.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #7 of 29 (permalink) Old 04-18-2019, 08:06 AM - Thread Starter
tuffstuff's Avatar
Rep: 8 (Unique: 8)
Just been starting to stutter/skip a little when I have been playing diablo 3 and POE. It's not overclocked at the moment because I couldn't get it to be stable but if you wanna help with any suggestions there I will give it a go. Would be cheaper just to upgrade the graphics card and overclock it anyway.
It was more so I saw the Ryzen cpus getting cheap and was wondering if a quick cheap upgrade wouldn't be bad.
post #8 of 29 (permalink) Old 04-18-2019, 08:08 AM
rdr09's Avatar
Its your gpu. Current Ryzen will get cheaper in a few weeks when the new CPUs come out. At 4GHz, it should handle the RX 570 just fine. It will bottleneck but you'll get better gaming experience. I had my Phenom paired with a R9 290 (equal to RX 570) and i had to oc the cpu to 4.2GHz.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #9 of 29 (permalink) Old 04-18-2019, 08:13 AM - Thread Starter
tuffstuff's Avatar
Rep: 8 (Unique: 8)
So look for a RX 570? Then if needed to try to overclock the cpu some?
post #10 of 29 (permalink) Old 04-18-2019, 08:16 AM
rdr09's Avatar
Yes, it will be massive upgrade from the HD 6870. Save some for when NAVI gpus come out then do a proper upgrade. Not sure if your cpu cooler is up to the task but shoot for at least 3.8GHz.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
