Problem with 2700 OC - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 04-21-2019, 12:54 AM - Thread Starter
Rep: 0
So I just built this system my previous build was a ryzen gen 1 with a 1600 and asus mobo.
Moved upto gen 2 and I am getting a weird issue where my processor is hitting 5.0ghz? unless hwmonitor is really messing up it does worry me.
Current build:
AMD Ryzen 7 2700 OC 4.2GHz ~ corsair H115i PRO rgb liquid cooler
Team Vulcan Gaming DDR4 3200 16gb
Geforce RTX 2080 rog strix
MSI B450 Gaming PRO Carbon AC
Temps range from 43C to 54C
max it hit was 5061 MHz earlier today it hit 4.8GHz
Precision boost is off in the bios. I cannot change core level performance as it is greyed out. I have gone through with a fine tooth comb but I feel I may need some help from the community on this issue as I have not had this problem before with the 1600 OC or the old asus mobo. I do miss the asus bios at this point. I will add since I built both of these at the same time this weekend since I was building my wife a computer, that in the asus bios for the 1600 I was able to disable the core performance boost...
psopro2 is offline
post #2 of 8 (permalink) Old 04-21-2019, 01:43 AM
rdr09's Avatar
Rep: 890 (Unique: 643)
Op, use HWINFO64.
https://www.hwinfo.com/download/
BTW, that is an amazing motherboard, value wise, to be able to oc the cpu to 4.2. Haven't tried oc'ing mine higher than 4.1GHz on an Asus Prime X470. I think my next motherboard would be a MSI X570 or 550. Carbon.
By Built-in Benchmark Queen:
My 2.5 years old delidded 7980xe @ 4600mhz all core with 49ns memorylatency (4000c16 twekaed) is faster than 3950x max overclocked on water in every scenario. Pretty good for a ancient cpu
In gaming it has no chance vs my new 10900k @ 5400mhz and 4600c16 tweaked memory. ~35ns memorylatency.
2nd AMD Build
(10 items)
2700
470
5700
3266/14
1000
700
Operating System
10/64
40/1080
Keyboard
M100
rdr09 is offline
post #3 of 8 (permalink) Old 04-21-2019, 02:28 AM
The last VRM burner
Rep: 45 (Unique: 27)
HWMonitor was and is a garbage, use HWiNFO. When you install it make sure that your RAM is running 3200 (1600MHz) C16 in it.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #4 of 8 (permalink) Old 04-21-2019, 12:56 PM - Thread Starter
Rep: 0
awesome thanks guys. used hwinfo instead and im seeing a steady OC being held. ddr4 is c16 and running properly as well thank you
psopro2 is offline
post #5 of 8 (permalink) Old 04-24-2019, 12:33 PM
Rep: 57 (Unique: 56)
Quote: Originally Posted by rdr09 View Post
Op, use HWINFO64.
Hmm then I may need to stop complaining about my chip. I got the board though. Already booted with 4.4ghz.. Not stable at all but, I may be able to with the improved cooling setup i have now.
DoctorNick is offline
post #6 of 8 (permalink) Old 05-12-2019, 08:22 AM - Thread Starter
Rep: 0
Hey guys I know its been a minute but I wanted to give an update.
I ended up settling in at 4.1ghz at 1.36V ~ the increase in voltage to go higher wasn't worth the extra heat. with summer temps outside and no AC ive got idle down to 29 from the original 43 and max on stress in the heat of day is only 65, but typically is around 40ish on load.
swapped my Vulcan ram to the wifes pc and moved my old vengeance over
3000mhz CL15 OC to 3333 1.35v stable timings at 16 haven't tried tightening them up as there stable atm. did increase speed quite noticeably.
hey nick was that with a 2700 or 2700x?
psopro2 is offline
post #7 of 8 (permalink) Old 05-12-2019, 09:57 AM
BeetleatWar1977's Avatar
Rep: 4 (Unique: 4)
I get the same problem with HWMonitor - if the SoC-Voltage is set to low............ slightly bump up, all good.
BeetleatWar1977 is offline
post #8 of 8 (permalink) Old 05-14-2019, 03:57 AM
2700x but with 1.5v or something like that.
