How much of a leg up have Intel's security issues given Ryzen? - Overclock.net - An Overclocking Community
post #1 of 17 (permalink) Old 05-30-2019, 11:17 AM - Thread Starter
Peon's Avatar
Rep: 6 (Unique: 6)
With Meltdown/Spectre last year, Zombieload this year, and who know what else next year and beyond - along with the performance crippling patches needed to address them - I've pretty much decided to go with Ryzen 3000 this time around.
That said, are there any recent benchmarks that compare Intel before and after all these patches with AMD?
Peon is offline
post #2 of 17 (permalink) Old 06-08-2019, 01:18 AM
SwitchFX's Avatar
Rep: 15 (Unique: 12)
Depends on workload, to be frank with you. We don't know how Zen2 is IPC wise. The reality is that given Intel's security issues and the recent leak of them trying to bribe researchers, I highly suspect there will be more security flaws published in the coming year. Intel won't have a brand new architecture Intel 2023 at the latest. I sincerely doubt they'll be able to release Sapphire Rapids in 2021 given their slide leaks courtesy of Huawei.
Intel is due to release some patches in a few weeks. That said, if AMD somehow maintains a healthy IPC increase with each generation than Intel will be facing some important decisions. That said, in AVX512 workloads, and Intel processor is going to be better. AVX workloads tend to be niche so I wouldn't focus too much on them unless your work relies on those instruction sets for efficiency and money savings.
SwitchFX is offline
post #3 of 17 (permalink) Old 06-08-2019, 07:57 AM
Stuck in the past
mtrai's Avatar
Rep: 35 (Unique: 21)
It is not so much a leg up, but rather if they had actually cared about security in the first place. If they had of cared then these issues would not exist but then they also knew performance would have been much much worse all along. You cannot look at these issues in an isolated way to compare both companies. We already knew intel had shady business practices with the bribes they used to pay.
Yeah there are some benchmarks floating around...can't remember where though and the performance hits are brutal. I even saw some comparing bulldozer cpu vs the comparable intel at the time with and without the security patches. Those are even more brutal. AMD and Intel were on par and traded blows depending on workloads. And back then you also have to take into consideration Intel was also paying for companies to use the intel compiler which would also cripple how AMD would show.
Sabertooth 990 FX R 2.0 FX 8120 BL ED. B2 Rev Can over clocked to 5.0( Normally run at 4.4 Ghz )
2 x 8 Gb Corsair Vengence 1600 Ram EVGA Supernova 1050 GS Gold PSU Logitech G502 Proteus Gaming Mouse
Powercolor PCS+ R9 290X x2 CM Storm Trooper Case
SteelSeries Apex Gaming Keyboard SteelSeries Stealth Merc Keyboard (1 broke key)
Several Sata HDs CM Seidron 120 AIO Closed Liquid Cooler
Disabled so not a ton of money.
mtrai is offline
post #4 of 17 (permalink) Old 06-09-2019, 02:02 AM
SwitchFX's Avatar
You make a good point. Actually, to expound on what you said, I wonder how long they knew about these. Was it during development? Probably not. The university bribes hail from a year ago. Imagine if they knew this several years ago. I wonder if a lawsuit ever goes through what would be found during discovery.
My general understanding is that parts of Core arch were lifted from the P6 days. Core has evolved over the last 19 years despite Intel's clever but short lived tick-tock cycle.
SwitchFX is offline
post #5 of 17 (permalink) Old 06-09-2019, 02:22 AM
AMD Overclocker
Alastair's Avatar
Rep: 261 (Unique: 163)
I think sacrificing the security of their processors is the whole reason why intel has had a leg up this entire time. I don't think it is AMD that has the leg up. Its like Intel was an athlete and they just got bust for using PEDs. It didn't suddenly give AMD and advantage. Just brought everything back down to where it should of been this entire time.
If You Can Cool It! You Can Clock It! (AMD's Vishera)
GHOST rev 4
(26 items)
Rura Penthe
(12 items)
AMD Ryzen 7 3800X
Gigabyte Aorus X570 Pro Wifi
MSI VEGA 64 WAVE
Avexir Core 2 3600MHz 18-20-20-44
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
Samsung Spinpoint HD502HI
CoolerMaster V1300 Platinum
XSPC D5 Bay Res
1x CoolerMaster Storm Force 200
XSPC Raystorm CPU Block
EKWB Coolstream PE360
6x CoolerMaster Jetflo's 120mm
XSPC D5 Vario
EKWB Coolstream CE280
6 Corsair ML140's
Barrow Vega 64 full cover waterblock.
NZXT Phantom 820 Black
Operating System
Windows 10 Pro 64-Bit
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
GX Gaming SW-G2.1 3000
Audio
Kingston Hyper X Cloud Core
AMD Athlon 860K
Asus A88X-Pro
MSI R6850 Cyclone Power Edition
G-Skill Ares 2133 CL10 8GB (2x4GB)
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Arctic Cooling Freezer A30
Corsair Carbide SPEC-02
Operating System
Windows 10 Home Edition 64bit
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte RX580 Gaming 4G
Gigabyte RX570 Gaming 4G
XFX RX480 reference edition 8G
Gigabyte RX570 Gaming 4g
G-Skill Ares F3-1600C9D
Samsung 750 Evo 120GB
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #6 of 17 (permalink) Old 06-10-2019, 07:25 AM
curmudgeon
miklkit's Avatar
Rep: 309 (Unique: 180)
Agreed. I can remember conversations about the back doors 20 years ago. It just took this long for the general public to discover them. And yes intel cheated and made Billions. They knew exactly what they were doing and chose that path.
IOKIYAR
Junkyard Dog
(18 items)
Blackie
(17 items)
AMD Ryzen 1700
Biostar X370 GT7
Sapphire Nitro+ Radeon Vega 64
G. Skill Ripjaws ddr4 3200 16 GB 4x4
Samsung 850 EVO 500gb SSD
Western Digital 500gb
Samsung 860 evo 1tb ssd
Optical Drive
Memorex Lightscribe dvd
Seasonic 850 watt
Thermalright Silver Arrow IB-E Extreme
Silverstone Redline RL05
Operating System
Win 10 64bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent vertical mouse
Mouse
yes
Audio
Creative X-FI
Other
Sennheiser headphones HD 599
AMD FX8370 @ 5 ghz
ASUS Sabertooth
Sapphire Fury
G Skill F3-14900CL9Q-16GBXL
Western Digital
Samsung 850 EVO
Optical Drive
Seasonic SS-850KM Active PFC F3
Silverstone Redline RL02b
Operating System
Win X 64 bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent VM4
Mouse
yes
Audio
Creative Soundblaster Z
Audio
Sennheiser 428 headphones
miklkit is offline
post #7 of 17 (permalink) Old 06-10-2019, 07:41 AM
Overclocker
JackCY's Avatar
Rep: 364 (Unique: 261)
Pretty much. And keeping the lid on with $$$ for the few that dared and had the skill to dig deep and discover crap.
If there is some leak of Intel trying to bribe researchers now? It's IMHO more of someone finally talking about it, about something that has been going on for ages, someone doesn't want the money anymore.
The original in recent years popularized issues were known since early 90s, problem was no one had the time or conscience to present a proof on actual hardware as such Intel kept dismissing the known issues as "theoretical" only... hoping that no one would break it in reality and those who did would be kept $$$ quiet. They $$$ influence benchmarks, researchers/hackers digging into their own products, pay researchers/hackers to dig into products of competition even so much so as to make fake reports for sole purpose of brand image damage.
As far as performance goes... for some workloads the software mitigations did have an impact.
Yes Core is nothing more but a modernized Pentium, developed from the mobile more power efficient variant. That's also why the old known issues were finally broken, they were still present and more were added when multi core and multi threading was added.
JackCY is offline
post #8 of 17 (permalink) Old 06-13-2019, 03:41 AM
SwitchFX's Avatar
Yeah this is what surprised me when I dig into the Intel architecture several years back. Core uses many components of P6, and while Core was modernized a handful years after it came out, it still retained many of its flaws. It's karma as far as I'm concerned. I think it says something when Microsoft is using Epyc for Azure and Amazon is looking to use Epyc.
SwitchFX is offline
post #9 of 17 (permalink) Old 06-13-2019, 05:11 AM
Overclocker in training
ThrashZone's Avatar
Rep: 186 (Unique: 111)
Hi,
Doubt any
Only amd performance will give them any boost or real consideration towards gamers....
Otherwise they will stay as the budget build crowds choice
TR is impressive and as long as that keeps going amd will excel
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
post #10 of 17 (permalink) Old 06-14-2019, 06:36 PM
F3ERS 2 ASH3S's Avatar
Rep: 132 (Unique: 89)
Intel will only put a cover on it.. mainly because the full root cause is a lot of the cores initial arch.. see below
correct the security should have been fixed but they where making too much money and that wasn't a focus
see below
For the most part this.. it isn't a leg up unless you are referring to PR
(ps ya missed me? well im back looks like I has no more reps anymores though le sigh lol)
This.. the cores issues are a result in security flaw from the derived arch.. with that being said that it was been improved on and the flaws are now mitigated through other security software patches however on a hardware level the only "patch" that can be provided would be a driver patch reroute etc the handling of threads.. the issue is that Intel isn't going to go full circle on it because that would cause a huge overhead that would degrade performance.. so what you will see is a way to make it look better in publics eyes as they tried to fix it.. same old Intel and thats how business is.. they made far more money doing wrong than was worth spending to do right and if they have to pay for it.. its pennys on the dollar for them.
Warning: Spoiler! (Click to show)
Asus sabertooth rev 2.0 BIOS 1503
Coolermaster Haf Stacker
FX 8350 @5.1 @1.7v :O
XSPC Raystorm RS240 + Swiftec D5 pump and 360 Rad
2x AMD XFX 280x DD @ 1210/1700
Rosewill Capstone 750w PSU
F3ERS 2 ASH3S is offline
