In Need of upgrade? - Page 2 - Overclock.net - An Overclocking Community
In Need of upgrade?
post #11 of 31 (permalink) Old 06-09-2019, 10:01 PM - Thread Starter
DesiredName's Avatar
Rep: 0
Quote: Originally Posted by AlphaC View Post
Yep , it's on your QVL as well.
If you're lucky it might be Samsung B-die rather than Hynix MFR/AFR memory ICs.
that page lists memory supposedly tested on your board with Raven Ridge (your Ryzen 3 APU is Raven Ridge)
Speed = memory listed speed
Supported speed = speed they got it to work at
im sorry I have no idea what this means
and this memory
https://www.amazon.com/Corsair-Venge.../dp/B0143UM4TC
is intel based will it work on AMD products?
DesiredName is offline
post #12 of 31 (permalink) Old 06-09-2019, 10:11 PM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
Yes it should work , even lists Compatible with Intel 100 Series,Intel 200 Series,Intel 300 Series,Intel X299,AMD 300 Series, AMD 400 Series and is on your QVL list. The memory ICs used are something that is difficult to tell if there's heatspreaders (the metal covering) on the memory. However, Samsung B-die modules have been shown to be able to have higher clocks with Ryzen generally although that's changing and some Hynix CJR can clock higher than 3200 as well.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #13 of 31 (permalink) Old 06-09-2019, 10:19 PM - Thread Starter
Rep: 0
Thank u AlphaC imma have to order this ram this week and get back to you guys.
If I don't have a much better performance imma have to wait a few months and get a amd ryzen 5 2600x,
I really like the ryzen 5 2600x has good reviews and seems pretty powerful for the price tag and hopefully the price goes down since the new cpus are coming out...
post #14 of 31 (permalink) Old 06-09-2019, 11:23 PM
Graphics Junkie
UltraMega's Avatar
Rep: 59 (Unique: 53)
Upgrading your ram is pointless. Your ram is not the best, but its more than fine. Going from 2400mhz ram to 2666mhz ram would be a complete waste.
Your GPU isn't great, but it should be good enough for 1080p gaming @60hz. That said, your GPU is a little under the recommended specs for the game. You should be playing with the graphics turned down.
You should upgrade your CPU before anything else. This would be a good CPU to get. It would triple the number of threads on your CPU and its pretty cheap: https://www.newegg.com/amd-ryzen-5-1...82E16819113435
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #15 of 31 (permalink) Old 06-09-2019, 11:42 PM
High Clocker
bmgjet's Avatar
Rep: 192 (Unique: 166)
Games early access still and doesnt run the best on my rig either. 30-80fps (1080ti @ 2.1ghz, 7900X @ 5ghz, 3666mhz 64GB quad channel)
Just get 1 more stick of what you already have so you have the recommended ammount of ram for the game and running in dual channel, Then call it a day since the game will get better with time and optimzations.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #16 of 31 (permalink) Old 06-10-2019, 03:37 AM - Thread Starter
Rep: 0
that's kinda what I figured lol but that ram is only like 35$ lol and if I get 2 (pls don't murder me with this ??) does that automictically make it dual channel?
and you don't think I should upgrade my cpu at all this is not bad at all what that guy posted I could get that and the ram for like barely 150 that's not that bad??
https://www.newegg.com/amd-ryzen-5-1...b903ca0a240610
or should I wait a few more months and wait till the better cpus are on sale since amd is coming out with there new chips?
post #17 of 31 (permalink) Old 06-10-2019, 03:42 AM - Thread Starter
Rep: 0
I would go from 2400mhz to 3200mhz with these
https://www.amazon.com/dp/B0143UM4TC...lockconvert-20
post #18 of 31 (permalink) Old 06-10-2019, 03:16 PM
⤷ αC
AlphaC's Avatar
He's running single channel at 2400MHz
► Recommended GPU Projects: [email protected] , Milk[email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #19 of 31 (permalink) Old 06-10-2019, 04:36 PM
Graphics Junkie
UltraMega's Avatar
I missed that, however single channel vs dual channel isn't huge. It's not like going from dual to quad channel. Sunning a single stick of ram only makes about a 10% difference at most. Its not going to make or break anyone's gaming experience, though it is certainly not ideal.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
Audio
Sound Blaster z
post #20 of 31 (permalink) Old 06-10-2019, 04:55 PM - Thread Starter
Rep: 0
You did send me that link for the CPU but upon reading the reviews they say if you run 2400mhz it would be pointless they were saying you need at least 2666 or more so I would still have to upgrade my ram if I get that CPU
I would rather spend the extra 50-60 bucks for the ryzen 5 2600x to be safe unless u think the other CPU would be just as fine...
