CPU upgrade questions - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 07-10-2019, 12:01 PM - Thread Starter
Rep: 0
New to this forum and have a fairly basic knowledge in regards to PC parts and building. I have a Ryzen 5 1600X with a GeForce 1050Ti 4Gb of DDR5 ram. I built my PC myself, and I'm looking to upgrade these parts specifically and i'm going to upgrade both to the newer high end models that have or are coming out eventually but I was wondering which one specifically is better to upgrade. I know that a lot of games are CPU intensive nowadays, but I didn't know if upgrading my CPU would cause major bottlenecking to the point of it not being worth it and just need to upgrade both at the same time which isnt a problem financially. I just don't know if there are other specifics or details that I'm missing in terms of my other PC parts that may be affected that I need to look into. Like is upgrading these parts going to cause heat issues even if not overclocked with.
In regards to the specific upgrades for the aforementioned parts I was looking to go for maybe a Ryzen 7 of sorts and GPU wise I wanted to go for a 1080Ti or AMD equivalent. Also, worth noting, I discussed this briefly with some other people who directed me to this site who mentioned something about 3rd party GPUs or something that seemed a lot cheaper, but they didn't really explain it to me besides the price gap being upwards of 500USD. If someone could touch on that subject a bit that would be very helpful as well.
Overall, i know there is a lot of information missing needed for you to be able to help me and that's due in part to me not knowing what information you need about my specs which I would be happy to provide if it's helpful. It's just a bit confusing in the aspect that when you're starting from scratch, these things are a lot more clear in that you can piece everything together like a puzzle. Whereas now I am essentially taking puzzle pieces out and putting in others that I don't have the knowledge to know if they fit.
Gerump is offline
post #2 of 4 (permalink) Old 07-10-2019, 12:24 PM
Newb to Overclock.net
mouacyk's Avatar
Rep: 173 (Unique: 128)
Welcome. It would be helpful to get some additional basic specs:
1. PSU model
2. Motherboard model
3. RAM installed (even SSD if you have one)
4. target experience like resolution and refresh rate (60Hz?)
5. budget
A 1080Ti is still completely relevant, providing the best value for non-RTX performance if you can find second-hand (look in the market place forums).
CPU: Q6600 X5470 2100T 1680V2 9900K
GPU: 8800GT 9800GTX+ 750Ti 1080Ti
RAM: 2x8GBTZ
Gentoo64 in Water
(14 items)
LGA775 X5470
(6 items)
9900K 5GHz 1.224v
EVGA Z370 Micro
MSI 1080TI GXEK 2100.5/12627
16GB Trident Z 4000C16
970 EVO 500GB
Seasonic X850 Gold
480mm Radiator Custom
Silverstone FT03
Operating System
Windows 7 Ultimate 64-bit
Operating System
Gentoo Linux 64 Multi-Lib
Acer Predator XB271UH 165Hz
Keyboard
Logitech G710+
Mouse
Logitech G502
Audio
Sound Blaster Z
X5470 4GHz (stock v)
GA-EP45-UD3P
EVGA 9800 GTX+ 512MB
8GB 4x2GB GSkill 1066MHz DDR2
XSPC Rasa, D5 + Res, 240mm Rad
Lian-Li PC7-HX
mouacyk is offline
post #3 of 4 (permalink) Old 07-10-2019, 12:25 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1429 (Unique: 725)
No one can recommend what you should upgrade without knowing what you do with your PC and what your budget is.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
The Pook is online now
post #4 of 4 (permalink) Old 07-10-2019, 12:26 PM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Just as information the memory on your GPU is GDDR5 not DDR5 which does not exist yet
We will be happy to help you out so if you can tell us about all the parts you have which includes stuff like the PSU (that matters a lot) and the monitor
After that if you can tell us what you are using the PC for and what you would like to use the PC for and how much you can/want to spend we can help you out
Wecome to OCN by the way
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
