Best memory kit for X570 - Page 2 - Overclock.net - An Overclocking Community
post #11 of 18 (permalink) Old 08-18-2019, 08:47 PM
os2wiz's Avatar
Rep: 65 (Unique: 42)
Quote: Originally Posted by RedBlueHue4 View Post
I prefer 2×16gb kits if some day you want 64gb also memory controller of CPU not being stressed as much atleast from what I've heard.
Those should be B-die, there is also a 3600 cl14 " " " kit of the neo that are exclusively B-die chips. They are high priced and don't find them to be worth it considering the kit you picked out is more than likely also b-die and with some tuning can reach the same timings
As far as stressing memory controller, your recommendations are no longer valid with Ryzen 3000 cpus and X570 motherbooards. I currently have a dual rank G. Skill Trident Z 32GB kit. The best I can do is 3600mhz stable with CL14-15-16-16 .Actually a 4 stick single rank kit if high end B-die can do better. The G.Skill TridentZ Neo 32GB kits are primarily 4 dimm single rank. Especially their more expensive one at 3800mhz . Frankly the extra money required for the highest end 32Gb Neo kit is not worth $200 extra in cost for a mere 1% or slightly higher system performance you get from it.
Technology is NOT a liberator . Whom technology serves is a class question.
Technology wielded by the capitalist class benefits only the exploiters.
Technology wielded by the working class will serve ALL Humanity.
Ryzen 9 3900X 4.275GHZ Sabrent 2TB pcieE 4.0 NVMe drive, Samsung 970 EVO NVMe 1TB
AMD Radeon VII gpu, MSI X570 MEG ACE motherboard, AlphaCool Eisbaer 280 Extreme
32GB G.skill TridentZ NEO DDR4 3600mhz CL16-16-16-36 1.35V
os2wiz is offline
post #12 of 18 (permalink) Old 08-18-2019, 09:08 PM
Retired Staff
JedixJarf's Avatar
Rep: 305 (Unique: 244)
If your fclk will even do 1900 mhz.
JedixJarf is offline
post #13 of 18 (permalink) Old 08-19-2019, 06:20 AM
crastakippers's Avatar
Rep: 3 (Unique: 2)
Sorry you've had this post up for 12 hours and no one has responded to try and help you out. Seems this website has alot of folks who don't care to help someone curious and new to PC like myself but instead boast about their things and rant about rumors or irrelevant things.
This forum has always been super helpful. However its not as busy as it used to be (at least that is how it feels to me). Also not all of us have direct experience with the new 3000 series chips. So in short, sometimes you may have to wait a little while longer for a reply.
And if you don't get a reply don't take it personal. I am sure it happens to everyone once in a while. (;-)
cheers.
crastakippers is offline
post #14 of 18 (permalink) Old 08-19-2019, 11:54 AM
os2wiz's Avatar
Good point. I forgot to say my kit is the fastest dual rank 32GB kit available from G.Skill it is officially rated at DDR4 4000 CL19-19-19-39 1.4 volts. You can not find any dual rank kit above 4000mhz. I am not sure for what reason. But it is apparent from all reviews that 4 dimms on Ryzen 3000 (presumably single rank) can outperform 2 dual rank dimms as far as both speed and tightness of timings. I wish AMD had made that clear prior to my purchase. By the way, that 3800mhz 4dimm 32GB Neo kit will automatically set flclock when you use it's xmp
setting out of the box.
os2wiz is offline
post #15 of 18 (permalink) Old 08-19-2019, 09:37 PM
Retired Staff
JedixJarf's Avatar
Well even if I use my old 3200cl14 kit the fclock will auto 1:1, it seems like it tries to 1:1 regardless of the memory speed even if it wont work, at least on my asrock board.
post #16 of 18 (permalink) Old 08-24-2019, 02:40 AM
Rep: 39 (Unique: 33)
Micron E-die can be easy to setup.
My kits do 3933/4000Mhz @ 1.200V XMP settings 4x8Gb (20.23.23.42.80) (1-3clicks OK)
3800Mhz 1:1 1900fclk was no issues what so ever. Though my kits aren't the best ones for main timings, there are newer better micron E-die today that do lower tRCDRD than mine do.
3800 CL15/16.23.17.32.66 580 1.450V possible
3800 CL14.23.17.32.66 580 1.550V possible.
These can run 4600Mhz 2x8Gb or as I've currently trying to fix up 4266Mhz 4x8Gb.(work in progress)
I've got some 16nm variants from Kingston.
Gigabyte X570 AORUS XTREME, Ryzen 7 3800X 4.4Ghz, 4266/1900 MEM/FCLK, 16.26.19.45.76.tRFC 650 1T 1.600V
4x8Gb Kingston HX434C19FB2K2/16 3466C19 1.2V (Micron E-die 16nm)
OLD: Biostar x470GT8 Ryzen 7 1700 @ ~4.0Ghz CPU, 3200Mhz RAM ...
Nighthog is offline
post #17 of 18 (permalink) Old 08-24-2019, 03:35 AM
Lexi is Dumb's Avatar
Rep: 42 (Unique: 32)
maybe this?
https://www.newegg.com/g-skill-32gb-...-857-_-Product
It's obscenely expensive with not a whole lot of reason to bother. I'd suggest finding a 3200 CL14 or 3600 CL16 kit and just overclocking it or tighten the timings.
I don't like the look or the RGB on it, but this is probably what I'd end up getting.
https://www.newegg.com/g-skill-32gb-...-850-_-Product
Panthera
(14 items)
Ryzen 7 3700X
Gigabyte Aorus X570 Pro Wifi
Msi Gaming X Trio RTX 2080
16GB 3200CL14 G.skill Trident Z
1TB Samsung 860 Evo
Corsair HX750 Platinum
AMD Wraith Prism
NZXT H700
Acer Predator XB271HU G-sync 1440p165hz IPS
Keyboard
CoolerMaster MK730 TKL w/ Cherry Reds
Mouse
Logitech G703 Hero
Mousepad
Glorious Extended
Audio
Presonus Eris 3.5
Audio
Audio-Technica M50xBT
Lexi is Dumb is offline
post #18 of 18 (permalink) Old 08-24-2019, 04:03 AM
rdr09's Avatar
Rep: 874 (Unique: 637)
This kit is b-die and only fills 2 slot. You can add 32GB more in the future but some would not recommend such even if same kit.
https://www.newegg.com/g-skill-32gb-...82E16820232263
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
