Best memory kit for X570 - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 08-15-2019, 01:00 AM - Thread Starter
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
Rep: 162 (Unique: 127)
So I'm researching around and can't really find the definitive answer for this.
Anyone care to chime in on which memory kit should I buy?
I'm aiming to
  1. Best memory speed and low latency
  2. 1:1 FCLK with 3900x
  3. Preferably low profile or non RGB. Doesn't have to meet this but would be good if it did.
  4. Can be used to run quad channel stuff in the future.
  5. If possible, 32GB or greater.
I'm also considering dual rank due to its advantages but can't really be sure if the disadvantages will outweigh the speed benefits. They'll run slower with looser timings afaik.
Money is not an issue. But I prefer not to spend on features that I don't need (rgb, corsair's cooling fan etc).
Hardware planned
3900x
Crosshair 8 Hero
Swiftech Drive X3 360mm
nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴ
TK421 is offline
post #2 of 18 (permalink) Old 08-15-2019, 01:47 PM
Rep: 1 (Unique: 1)
Sorry you've had this post up for 12 hours and no one has responded to try and help you out. Seems this website has alot of folks who don't care to help someone curious and new to PC like myself but instead boast about their things and rant about rumors or irrelevant things.
For the best memory kits on Ryzen 3000 anything Samsung B-die should do an excellent job. B-die is not guaranteed on any kits (atleast to my knowledge) but to get a good lead on what kits most likely are Samsung B-die look for kits with low latency. For example alot of G.skill 3200mhz -cl14-14-14-35 are B-die or 3600 cl16 '' " " are too.
To be more specific the recently launched g.skill neo DDR4 are specifically optimized for Ryzen processors. They are RGB, but nearly all "GTZN" with low latency stats are B-die the "GTZNC" also have very good timings but are slightly looser timings in ras/tras timing. I believe they are Hynix M-die.
If dead set on not wanting RGB, look at the G.skill tridentZ non RGB SKUS. Doing a quick search on Google for "which G.skill ddr4 are Samsung B-die" in one of those few top threads there is a great thread from reddit that a gentleman refers to most DDR4 modules and their die type.
Personally I went with G.skill neo recently. Very nicely priced and performance is spot on. Whichever RAM you decide on, I would reccomend looking into Ryzen DRAM calculator for tightening the timing and making the most out of your $. RAM won't be the most influential thing on your system, so get the good GPU/CPU/Mobo before the RAM. Hope that helps!
RedBlueHue4 is offline
post #3 of 18 (permalink) Old 08-15-2019, 02:05 PM
I can count to potato
Fluxmaven's Avatar
Rep: 40 (Unique: 15)
You can check the B-die finder to see what kits are actually B-die.
https://benzhaomin.github.io/bdiefinder/
Samsung is ending production of B-die though, so it may be harder to source a 2nd set if you want to add more down the line.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
TridentZ B-die 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #4 of 18 (permalink) Old 08-15-2019, 02:39 PM
⤷ αC
AlphaC's Avatar
Rep: 911 (Unique: 592)
Have you seen this thread in the subforum you posted in ?
https://www.overclock.net/forum/13-a...x470-x570.html
AMD recommendation is 3600C16 (FLCK 1800MHz).
If you're willing to fine-tune I've seen people with 1900MHz FCLK and I suppose that is what the Trident Z Neo 3800C14 kit is for at a hefty premium assuming your CPU can handle 1900MHz FCLK (not guaranteed).
If price/performance is a consideration and you're willing to put in effort , people have also had Micron E-die working with 3600MHz+.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #5 of 18 (permalink) Old 08-15-2019, 05:42 PM - Thread Starter
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
I'm looking at this one. Which is G.skill neo, and comes with 4 sticks so it should be pretty good to run? It's a 3600 and CL16-16-16-36 kit. 4x8GB so it's 32GB.
This is b-die right?
https://www.newegg.com/g-skill-32gb-...82E16820232862
Or should I seek dual rank kits with 2x16 instead?
Can 3600C16 be tuned with faster FCLK?
TK421 is offline
post #6 of 18 (permalink) Old 08-15-2019, 06:42 PM
Rep: 1 (Unique: 1)
I prefer 2×16gb kits if some day you want 64gb also memory controller of CPU not being stressed as much atleast from what I've heard.
Those should be B-die, there is also a 3600 cl14 " " " kit of the neo that are exclusively B-die chips. They are high priced and don't find them to be worth it considering the kit you picked out is more than likely also b-die and with some tuning can reach the same timings
post #7 of 18 (permalink) Old 08-16-2019, 03:14 AM - Thread Starter
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
not finding the cl14 3600 kits
any opinions on rev e 3000 C15 and manually tuning to 3600 C16?
I heard the secondary memory timings would be slightly worse, but offset by rank advantage if running 2x16.
TK421 is offline
post #8 of 18 (permalink) Old 08-18-2019, 04:21 PM
Rep: 1 (Unique: 1)
Neos coming out with a 3800mhz cl14-16-16-16 set
I have a dual mode 3200 cl14 trident royals cranked to 3733mhz cl-15-16-15-15 at 1.5 for the life of me I can only get like 80percent posts at 3800mhz not sure if it's the fclk causing bios resets or just improper ram timings. But it made it through stress tests just fine at 3800. I have a pretty good latency at 63 or 64 dual rank 2t not sure what advantagesw or disadvantages you get with dual rank
Dphotog is offline
post #9 of 18 (permalink) Old 08-18-2019, 05:02 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1265 (Unique: 689)
B-Die is B-Die is B-Die. Outside the really cheap trash-bins like the Antec 1/3 Series DDR4-2400, they all are going to be able to run roughly the same timings at roughly the same clocks.
Some people say that 3200 CL14 is the best and others say 3600 CL15 is the best and others say the >4000 frequency 1.35v kits are the best but until someone buys a huge truck load of RAM and bins it I'm convinced people dunno what they're talking about.
Anything but trash B-Die will be able to do CL15 @ 3600 at 1.4v. My ram is nothing special and at 1.45v will do 3600 CL13, 4000 CL15, and 4160 at CL16 with tight secondaries/tertiaries.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #10 of 18 (permalink) Old 08-18-2019, 05:17 PM
Retired Staff
JedixJarf's Avatar
Rep: 305 (Unique: 244)
Just get some good quality bdie. Currently rocking 2 of these kits @ 3666 cl14 1:1.
https://www.newegg.com/team-16gb-288...82E16820331244
JedixJarf is offline
